Thread started 27 Dec 2009 (Sunday) 17:28
Prev/next
Hoya UV(O) and UV(C) filters -- what's the difference?
shaftmaster
shaftmaster's Avatar
above 5000 feet
Dec 27, 2009 17:28 |  #1
I recently purchased a couple Hoya HMC UV filters online. I thought I was getting HMC UV(O) filters but was shipped HMC UV(C) filters. I checked the Hoya web-site, this forum, and also did a Google search but couldn't find anything to explain how a UV(O) filter differs from a UV(C) filter. Anybody know the difference? Should I return the UV(C) filters and ask for replacement UV(O) filters?
Thanks!
Paul
Gear -- Flickrexternal link
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Dec 27, 2009 17:53 |  #2
I infer from what Google turns up that UV(C) may be what it's called outside the US. Note - I infer this; I can't find a positive statement of the fact. Possibly your vendor imported the filters on his own for less than it would have cost to have gotten the "official" ones from THK, the US marketing arm of Tokina-Hoya-Kenko.
Jon
Cocker Spaniels
shaftmaster
above 5000 feet
Dec 28, 2009 20:10 |  #3
Thanks Jon. I will see if I can dig up any more information.
Paul
ejicon
ejicon's Avatar
Hollywood, California
Apr 26, 2010 21:12 |  #4
Good question. I just bought one and was thinking the same thing. In some countries C can also refer to Zero as in Cero which is Spanish for Zero.
oh and found this:
"xthunder, I just received a shipment of filters from Spotlight Photo, a company that I have been buying filters from for the past 6 years. The Hoya HMC UV(0) have now been replaced by Hoya HMC UV(C) filters. Slim frame, multicoated. The UV(0) no longer made (except where old stock is left) and now replaced by the UV(C). Same filter, now says Digital on the left side top of box compared to the old box I have. Also the older UV(0) box shows the filters were made by Tokina Ltd. in Japan. The new UV(C) boxes show made in the Phillipines by Tokina Ltd.
Hope this helps.
Best Wishes!"
http://www.rangefinder​forum.com ...php?p=1243333&postc​ount=5external link
5D & 30D| Canon 16-35ii f/2.8 L USM| Canon EF 50mm f/1.4 USM | Canon 70-200mm f/2.8L USM | Canon EF 100 f/ 2.8 Macro USM
Revup67
Joined Jun 2010
Jun 29, 2010 12:53 |  #5
I just spoke with Glenn in support at Hoya regarding this same issue (O) vs (C). Glenn stated physically the (C) series is a slimmer design than the (O) and that is to reduce vignetting even further and that is the only difference betwen O and C. Technically they will provide the exact same results and are the exact same quality. I had asked what the "O" or Zero represented and also the (C). He stated Japan has never advised him as to what the symbols reflected. I asked is it possible the (O) is for Original and the (C) is for compact? He stated he had never heard that before and probably just a rumour. You can call any time for more info or verification at hoyafilters.com - I called their 714 phone number.
Brand's ­ Camera
1 post
Minneapolis
Aug 16, 2010 16:34 |  #6
Revup67 wrote in post #10448069external link
I just got one of each (O) and (C) Hoya UV filter. Positioned next to each other I see no difference.
Joel Brand
Brand's Camera Craft
Minneapolis, MN
nonobaddog
nonobaddog's Avatar
Joined Jul 2011
Jul 15, 2011 20:02 as a reply to Brand's Camera's post |  #7
I believe this filter difference calls for a bit of caution. I'm sorry this is so long but my experiences below certainly cleared up some things in my mind.
I did not know the difference in these filters except I could usually find the HMC UV(C) version cheaper than the HMC UV(0) version, that is when I could even find both versions for sale. Also I saw a filter test at http://lenstip.com ...icle-UV_filters_test.htmlexternal link and that made me think the HMC UV(0) was the filter I wanted. I am most interested in filtering out the most ultraviolet frequencies right up to 390nm or 400nm where the visible light starts so the frequency transmission charts in their tests were very revealing for me.
I went to the Hoya web site at http://www.hoyafilter.​com/external link They listed an email address for USA support at support@thkphoto.com I sent an email asking what the difference in these filters is. They seemed quite willing to help. I received a prompt reply from Glenn Nash saying...
"The HMC UV(0) has the UV protection in the glass, the HMC UV(C) has the UV protection in the multi-coatings."
Now I decided the HMC UV(0) was definitely the one I wanted.
I ordered a Hoya HMC UV filter from Crutchfield on 6/21/2011 for what seemed to be a pretty good price. In the text of the description it did not state which version the filter was but the picture of the item 'Very Clearly Showed' it was an HMC UV(0). So I ordered it thinking I was getting an HMC UV(0) filter but they sent an HMC UV(C) filter. I called them and they said to return it and they would send the HMC UV(0). After several days I received a phone call saying they only have the HMC UV(C) version and that it replaced the HMC UV(0) version. I didn't totally buy this so I went to the Hoya on line catalog and I could only find the HMC UV(0) version and no mention of the HMC UV(C) version, not sure what that means, maybe I just didn't find it. I told Crutchfield over the phone that their web site clearly showed the HMC UV(0) version in the item picture. They said again they did not have it and to return mine. I checked their site for other Hoya HMC UV filters and found more cases where the text did not say which version it was but the picture 'Very Clearly Showed' the item to be an HMC UV(0). This was true for the size I ordered, 77mm, and it was also true for 82mm, 72mm, 67mm, 62mm, 58mm and 52mm. I didn't check any smaller sizes. This has not been corrected as of 7/15/2011. I don't know which version they would send for these other sizes but I certainly do not believe the HMC UV(C) version is replacing the HMC UV(0) version. I believe the HMC UV(C) version is a cheaper filter - this is my personal opinion. I didn't bother to dig any further. I will just order my filter from another source. However I do know that searching will find quite a few instances of people ordering HMC UV(0) filters and receiving HMC UV(C) filters instead. One might think these are just honest mistakes but I could not find one instance of anyone ordering an HMC UV(C) filter and receiving an HMC UV(0) filter. Go figure.
Personally I would not tolerate any substituting of HMC UV(C) filters for HMC UV(0) filters.
shaftmaster
above 5000 feet
Jul 19, 2011 10:16 |  #8
Sounds like (O) means optics and (C) means coating. I don't worry about how well a UV filter blocks UV since UV doesn't negatively affect digital images like it does film from what I understand. Assuming that's true, then the only thing to worry about when buying a UV filter for use with digital cameras is how it affects the image quality (light transmission, flare, contrast, sharpness, etc.).
Paul
nonobaddog
nonobaddog's Avatar
Joined Jul 2011
Jul 19, 2011 14:55 |  #9
This is all my opinion but I am still concerned about UV because I am not willing to accept the digital camera immunity to UV as a universal truth. I don’t believe it is that simple.
The UV spectrum goes from a wavelength of about 1 to 5 nm on the high energy end to about 390 nm on the low energy end and then visible light starts. The camera sensors themselves are very capable of detecting UV over a good chunk of that range, maybe from about 200 nm to 390 nm. (All these frequency cutoffs are typically gradual rather than real sharp steps.)
I think there are potentially 4 things that block that undesirable UV.
1 – an internal UV filter on the sensor or right in front of it
2 – the glass in the lens
3 – the coatings on the glass in the lens
4 – an external UV filter on the lens
#1 is a variable that has the potential to block most or even all undesirable UV. Whether it does or not is up to the sensor/camera manufacturer. Some cameras are more ‘UV friendly’ than others, the Nikon D70 is frequently mentioned.
#2 there are many types and qualities of glass with a wide variety of UV blocking properties. I have heard this frequently but to simply say glass blocks UV is naïve at best. However the optical glass in most camera lenses will block UV up to about 300 nm or 320 nm. There are glass lenses designed for UV photography that pass a lot more UV.
#3 is a variable that has the potential to block most or even all undesirable UV. Whether they do or not is up to the lens manufacturer. Some lens coatings are more ‘UV friendly’ than others. I hear there are some lenses that actually don’t have coatings, but I don’t know anything about them.
#4 is a variable that has the potential to block most or even all undesirable UV. Whether it does or not is up to the filter manufacturer.
So the UV in the 320 nm to 390 nm range is the area of my interest. This is in the UVA range and will affect the sensor if not blocked somewhere. I would guess that most camera/lens combinations block some portion of this, maybe a lot if I am lucky. Now add a UV filter that doesn’t help by blocking any more UV, there seems to be plenty of these regardless of price, and that is wonderful evidence for people that don’t like UV filters. It’s all logical and correct for them but it may not apply to the next bloke.
For me, #4 above is really the only one I have a lot of control over so I just add a filter that tests well at blocking UV up to 390 nm and I forget about it. (I went by the tests at lenstip.) I automatically get lens protection too. If I ever feel that the filter is causing flare or other problems for a shot, well I know how to take it off.
nonobaddog
nonobaddog's Avatar
Joined Jul 2011
Aug 04, 2011 18:36 |  #10
In addition to the Crutchfield purchase mentioned above, I bought a Hoya filter from B&H. It was titled "77mm Ultraviolet UV(0) Haze Multicoated Filter". Their 'Overview' describes it as a UV(0) filter. Their 'Specifications' lists Grade as UV(0). And then they sent a UV(C) filter. I called them and Isaac said they were the same filter and his supervisor, Aaron said they were the same filter. I asked them why they clearly advertised it as UV(0) if they knew it was a UV(C). They said the manufacturers' code, A77UVC, means it is a UV(C). Pretty lame. They seemed like it was perfectly acceptable to have a conflict between the description and the manufacturers' code and put the burden on the customer to try to find out what the manufacturers code means. Oh and then one has to guess which item you are actually going to receive, the item in the description or the item in the code. I sent it back.
nakiege
nakiege's Avatar
1 post
Nov 17, 2011 10:36 as a reply to nonobaddog's post |  #11
At the end, I found out the difference between UV(0) and UV(c) filters at Hoya web site.
I also found the comparison chart between UV(0) and UV(c) on the Hoya Catalog Page 56. It is obvious that UV(0) cuts more UV than UV(C) does.
You can download the catalog from here, to read more.
www.hoyafilter.com/pdf​/HOYACatalog.pdf
EOS Rebel T2i
Wilt
Wilt's Avatar
Belmont, CA
Nov 17, 2011 15:48 |  #12
nakiege wrote in post #13413006external link
www.hoyafilter.com/pdf​/HOYACatalog.pdfexternal link
It is also worth pointing out the the Hoya HMC (which is muticoated, but not super multicoated) is the lower performance UV(C), while both the HD and the SHMC use the UV(0)...in other words 'less expensive' = C, 'more expensive = 0 filter.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
Stein47
1 post
Joined Feb 2012
Feb 27, 2012 07:57 |  #13
The difference is explained by the we page attached
www.hoyafilter.com/pro​ducts/hoya/coatings.ht​ml
Hope this helps
Stein47
Nomad77
1 post
Joined Jul 2013
Jul 10, 2013 11:30 |  #14
Canon 5D ISO 200 F8 1/200 100mm 24-105 L
http://shout.smugmug.c​om ...560009&k=WDm5Dxt&lb​=1&s=Oexternal link
UV(0) has better detail. C = UV is coated to the glass 0 = UV is built into the glass
78,905 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00276 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is TheSandValor
978 guests, 533 members online
