Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 5th of January 2010 (Tue)   #1
ergaticus
Default Please help me choose a couple of external HD
Hi everyone,
I've been backing up my archive to DVDs only so far, but I've finally managed to save some money in order to buy a couple of external hard drives for storage and backup purposes.
I live in Mexico and I currently have the following two options available through the local market. I'd like to receive your input in order to make a decision please.
Option # 1:
The Seagate FreeAgent Go 500GB are available at the local Sam's Club. I've been reading the reviews on Amazon and most of the people seem to be happy. Some users though report very early failures, during the first months or weeks.
http://www.amazon.com/Seagate-FreeAg...2706660&sr=8-2
I wouldn't be able to get a warranty replacement here in Mexico so that concerns me.
Plus, the price is about 2320 pesos X 2 = 4640 pesos. Quite expensive, it almost doubles the price in USD.
Option # 2:
This is a link to a product that is for sale on the local Ebay equivalent:
http://articulo.mercadolibre.com.mx/...serial-ata-_JM
Basically it's an external enclosure with this HD inside:
http://www.seagate.com/ww/v/index.js...00f5ee0a0aRCRD
So basically a 1TB drive, instead of a 500GB and the price is much lower too: 1659 pesos X 2 = 3318 pesos. I would have twice the storage for a lower price. There's a 1 year warranty directly with the vendor.
I'm leaning towards the second option, I'm unsure though about the external enclosure, which looks pretty cheap and I'm not sure wether it could cause possible heating problems with a 7200rpm drive.
What would you advise me to do?
Thanks in advance for your help!
UPDATE: I think I posted this on the wrong section of the forum, I guess it should belong in the computers section. I apologize for the mistake and if a moderator could help moving this I would be most grateful, thanks!
ergaticus is offline   Reply With Quote
Old 5th of January 2010 (Tue)   #2
rameshiyer
Default Re: Please help me choose a couple of external HD
If you are ok having an external power supply, I suggest you look for a Seagate FreeAgent 1Tb instead of the The Seagate FreeAgent Go 500GB. Here in India, both cost almost the same. The difference between FreeAgent and FreeAgent Go is that "Go" doesn't require an external power source (works with USB power and hence more portable and expensive).
rameshiyer is offline   Reply With Quote
Old 5th of January 2010 (Tue)   #3
mitch2k1
I would strongly recommend a Raid system, similar to a Drobo or LaCie setup for backup. Especially if you are profiting from your images. I have the Drobo and it's simple to configure and you can have a 3Tb drive fairly inexpensively. That way you do not have a single point of failure.
Gear List:
5D MkII 7D (both gripped) 17-40mm f4L 24-70mm f2.8L 70-200mm f2.8L 100-400L 14mm 2.8L Zeiss 50mm 1.4 100mm 2.8 Macro USM Lensbaby Composer 580ex Gitzo 1348 RRS BH-55 S90
mitch2k1 is offline   Reply With Quote
Old 6th of January 2010 (Wed)   #4
ergaticus
Thanks for the suggestions. I spent a few hours searching through previous posts regarding external storage here on POTN and I think I might have found a better solution. I will buy a docking station and a couple of good internal hard drives. It's cheaper and I hope it will be a more practical solution in the long term.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
VOTE: Help choose a Logo! (7 to choose) NickSimcheck The Business of Photography 13 23rd of March 2009 (Mon) 21:20
HELP! Mac with External HD issueI am using a MacBook Pro and have an external hard dr August 15 Photography The POTN Lounge 1 3rd of July 2007 (Tue) 23:23
If you could choose your lens set from the very beginning WHAT WOULD YOU CHOOSE? Cool-cat Canon EF and EF-S Lenses 67 23rd of December 2006 (Sat) 08:15
Found a couple to choose from to buy? Help 79TAKid Canon EOS Digital Cameras 12 28th of April 2006 (Fri) 22:05
