Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 5th of January 2010 (Tue)   #1
robertnzana
robertnzana's Avatar
Default Your best 50mm 1.8 macro shots thread
INSPIRE the "photographer on a budget" who can't afford dedicated macro lenses...
Please post what you consider to be your best macro shot(s) using the 50mm 1.8 lens (with extension tubes is ok). If possible can you post your EXIF data and which extension tubes you used. Or, just post the pic.
Thanks for the inspiration!
View My Portfolio Here
T1i/500D, 17-55 2.8, 70-200 F4L IS USM, 100-400L - More Gear
Feedback: 1, 2, 3, 4, (and 230+ 100% ebay)
5 out of 4 people can't do fractions.
robertnzana is offline   Reply With Quote
Old 6th of January 2010 (Wed)   #2
themadman
themadman's Avatar
Default Re: Your best 50mm 1.8 macro shots thread
Well, my photos are FAR from inspiring, but I'll post a couple. All mine at with 48mm of tubes (36+12)
1.
2.
3.
4.
Will | WilliamLiuPhotography.com | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
themadman is offline   Reply With Quote
Old 6th of January 2010 (Wed)   #3
robertnzana
Awesome! Inspiring indeed!
Old 6th of January 2010 (Wed)   #4
LordV
LordV's Avatar
Not quite what you asked for- these were taken with an old pentax manual 50mm lens on 75mm of ext tubes I cobbled together with a canon Tmount. ISO 100-800, 1/200th ETTL flash, F11
Brian V.
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is offline   Reply With Quote
Old 6th of January 2010 (Wed)   #5
themadman
themadman's Avatar
Amazing photos as usual Brian! Those ARE inspiring.
Old 6th of January 2010 (Wed)   #6
robertnzana
LordV I hereby annoint you MacroKingV! Nice shots as usual.
Old 6th of January 2010 (Wed)   #7
weeatmice
weeatmice's Avatar
Taken with ebay tubes and popup flash
Twopixel.co.uk | 500px | flickr | Twitter | Pinterest
weeatmice is offline   Reply With Quote
Old 6th of January 2010 (Wed)   #8
robertnzana
Wow great results!
Old 6th of January 2010 (Wed)   #9
Techuser
Techuser's Avatar
With the DCR250
didnt used it much after these shots, I ended liking better the kit lens for macros as it gets closer
Canon XSi | 18-55 IS | 50 1.8 | 70-300 IS | 300 2.8 FD
Techuser is offline   Reply With Quote
Old 6th of January 2010 (Wed)   #10
robertnzana
Techuser: Amazing shots! Did you use the 50 1.8 with tubes?
Old 6th of January 2010 (Wed)   #11
polobreaka
since you have to focus much closer with tubes, if taking waterdrop, is it much difficult? seems like it would splash all over the front of lens?
polobreaka is offline   Reply With Quote
Old 6th of January 2010 (Wed)   #12
themadman
themadman's Avatar
5. Tiny flower, grows in clusters (think a tiny bunch of grapes). Photo is uncropped, almost 1:1.
Old 6th of January 2010 (Wed)   #13
Techuser
Techuser's Avatar
I shot that on my first days with the DSLR and I didnt had the tubes yet, used just the DCR250, the distance was around 10cm I think, the front element was safe
robertnzana I did just some tests after I bought the tubes but never got to try them in the field, using the close-up on my 18-55 gives up pretty much the same results and is more practical without having to put the tubes on
Old 6th of January 2010 (Wed)   #14
LowSpark420
LowSpark420's Avatar
Those shots with water droplets on the flowers, etc...I assume those are setup shots? Where you drop water on the flower prior to taking the shot?
http://codphotography.blogspot.com/
___________________________________
Canon EOS Rebel XSi ~ Canon EF-S 18-55mm IS ~ Canon EF-S 55mm - 250mm f/4-5.6 IS ~ Canon EF 50mm f/1.8II ~ Canon 430 EXII Flash ~ Canon Off-Shoe Flash Cable ~ Kenko Extension Tubes (Full Set) ~ Delta Flash Bracket ~ Lowepro Flipside 400AW
LowSpark420 is offline   Reply With Quote
Old 6th of January 2010 (Wed)   #15
themadman
themadman's Avatar
/looks at the photos posted
me?
If you are referring to my pictures, none of them are setup. Number 1 and 3 were taken just at my apartment complex. Number 1 was after it had rained and number 3 and 4 was before sunset at 28 degrees f (so not much much water had evaporated from overnight condensation)
Number 2 and 5 were taken at an arboretum.
All shots were handheld except for number 1 which I used a tripod.
If you are not referring to me, just ignore this post =)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sigma 18-50mm f/2.8 EX DC - Macro Shots? MichelleRegner Lens Sample Photo Archive 3 2nd of September 2010 (Thu) 00:18
Sigma 50mm f2.8 macro first shots! Eat rice z33 Macro 3 18th of August 2009 (Tue) 12:29
50mm 1.4- capable of macro shots? kekoa Macro 4 19th of January 2008 (Sat) 14:42
<< Canon 50mm f1.4 - shots archive thread >> aridan Canon EF and EF-S Lenses 2 12th of December 2007 (Wed) 12:44
Butterfly Shots w/ 50mm macro azccw999 Macro 2 16th of August 2005 (Tue) 18:35
