Thread started 07 Jan 2010 (Thursday) 19:02
7d hard reset question
zooxanthellae
Jan 07, 2010 19:02 |  #1
Hi all
After playing with the settings on my 7d for the last couple of months i decided to do a hard reset as i wanted to default to factory.
I removed both batts and left the camera for around 10mins, installed both batts again and was met with the set date/time screen.
Sweet except my picture style settings were still stored and my name was still registered in the copyright info screen,
Custom functions were reset though,does this sound right as i thought a hard reset totally wiped the camera clean?
Many thanks for your help.
Canon 5D MK II,7d,70-200 L F2.8,24-70L,100mm Macro usm F2.8,sigma 150-500 OS,50mm 1.8 mk II,580 ex II. :D
John ­ the ­ Geek
Jan 07, 2010 19:15 |  #2
You reset the volatile memory. There is a custom function to reset the settings. My 7D isn't in front of me, but it's in the menu somewhere.
Canon Gear: 7D Gripped :: 16-35mm ƒ/2.8L II :: 24-70mm ƒ/2.8L :: 70-200mm ƒ/2.8L IS II :: 28mm ƒ/1.8 :: 50mm ƒ/1.4 :: 85mm ƒ/1.8 :: 200mm ƒ/2.8L II :: 180mm ƒ/3.5L Macro :: Extenders 1.4x II and 2x II :: Speedlites 430EX II (x2) and MT-24EX Macro Twin Lite
www.focalmagic.com (external link) (Under construction)
zooxanthellae
Jan 07, 2010 19:20 |  #3
Yep i have reset the other functions now although it still retained my copyright info, i would have thought there would be a way to totally default a fresh set up but it would seem not. So the camera has a flash memory?
In that case all those that attempt to hard reset to get rid of gremlins etc dont really achieve or change anything?
Tim ­ Kostka
Jan 07, 2010 19:33 as a reply to  @ zooxanthellae's post |  #4
"Clear all camera settings" is in the menu, which might be what you're looking for.
Zenfolio (external link) | Picasa Web (external link)
Canon EOS 7D | EF 24-105mm L | EF-S 10-22mm | EF-S 18-135mm | Sigma 50-500mm | 580EX II | Feisol CT-3441SB Tripod
zooxanthellae
Jan 07, 2010 20:50 |  #5
Hiya, yes that cleared the settings but left info such as copyright and a couple of other bits and bobs intact. I was expecting some kind of master reset to total default so it was kinda minty box fresh reset, that would be handy from a resale point of view especially if copyright info didn't get manually cleared as an over sight.
L.Morey
Jan 07, 2010 20:58 |  #6
Did you try taking out thr little cr132 batt in the battery compartment for 5-10 min and see what that does good luck
7d gripped,40d gripped,G9,17-40f4L, 24-70f2.8 L, 70-200f2.8 mkll L, 100-400 f4.5-5.6 L, 50f1.4 , 85f1.8 , Sigma 24-70f2.8
Sigma 150-500 , Sigma 18-200f4-6.3 , Canon Ste2 , Canon
580mki , Canon 580mkllx2
http://lwmorey.zenfoli​o.com/ (external link)
John ­ the ­ Geek
Jan 07, 2010 21:14 |  #7
L.Morey wrote in post #9348068 (external link)
AH! When I read "both batteries" I thought that, but he has a grip! That could mean either.
Also, Canon told me 30 minutes without batteries, not 10. Not sure if they were just being cautious though.
zooxanthellae
Jan 08, 2010 06:08 |  #8
Hiya , sorry yes I mean I removed the time/date button batt plus the power batts.Perhaps I should leave the camera longer.
Thanks all
20,021 views & 0 likes for this thread
version 2.0 /
Latest registered member is Angester
683 guests, 304 members online
