Reply
Thread Tools Display Modes
Old 21st of February 2003 (Fri)   #1
xxlt
Default New BreezeBrowser v2.5a beta
There is a new release for you G3 Raw junkies...I am in no way connected with this company...btw. There is also a BreezeBrowser v2.5. I downloaded the BreezeBrowser v2.5a beta version *Sweet* just my 2 cents. Happy Dark-rooming. BreezeBrowser v2.5a beta 1 contains fixes for the custom white balance and linear raw conversion problems and can be downloaded from here: http://www.breezesys.com/BreezeBrowser/index.html#new
bill from bill
xxlt is offline   Reply With Quote
Old 21st of February 2003 (Fri)   #2
gandini
POTN's April Fool!
gandini's Avatar
Default Re: New BreezeBrowser v2.5a beta
I have already tested it, and it appears to perform linear conversions as required, and also "combined" conversions. We have it all...
cheers
gandini is offline   Reply With Quote
Old 21st of February 2003 (Fri)   #3
KarlJones
Nice heads-up, Bill. So far, it does look schweet!
KarlJones is offline   Reply With Quote
Old 23rd of February 2003 (Sun)   #4
drisley
"What a Tool I am"
drisley's Avatar
I notice that combined versions look a little washed out compared to normal. Is this the desired effect?
drisley is offline   Reply With Quote
Old 24th of February 2003 (Mon)   #5
marcel wouters
It appears that there is no one "best conversion".
I tried the combined conversion and it works very well!
To benefit from this conversion you must have very bright areas in your image ( sky or very clear surfaces).
The normal conversion gives a "flat aspect" due to the loss of details in these area.
By using the combined version you save the "delicate nuances" by using the linear conversion result giving you more highlights.
But you know there is only 255 levels to see on your screen! So you must steel levels somewhere!
marcel wouters is offline   Reply With Quote
Old 24th of February 2003 (Mon)   #6
drisley
"What a Tool I am"
drisley's Avatar
Thanks. Makes sense, and it does work nicely on blown out images.
So far it BB beta works great in both Linear and Custom White Balance of the G3.
Now, to work on a G3 ICC profile and linear workflow!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
BreezeBrowser ? Boswell RAW, Post Processing and Printing 12 1st of March 2004 (Mon) 10:45
1.5 beta 1 to beta 3 updater Pekka Version 1.0-1.5 discussion 4 5th of October 2003 (Sun) 17:41
EE 1.5 beta 2 fix pack 11 (i.e. beta 3) Pekka Version 1.0-1.5 discussion 1 4th of October 2003 (Sat) 16:16
BreezeBrowser AndyDe RAW, Post Processing and Printing 3 19th of May 2003 (Mon) 22:06
Latest Breezebrowser beta adds Zoombrowser-style renaming op dbookbinder Canon G-series Digital Cameras 5 3rd of November 2001 (Sat) 09:27
