Reply
Thread Tools Display Modes
Old 23rd of June 2005 (Thu)   #1
LightRules
"flat out embarrassing"
LightRules's Avatar
Exclamation Canon & Sigma 24-70 f2.8 Test (merged)
I just put this up at my site:
http://www.pbase.com/lightrules/2470exl
***Update Below***
Sept 22 2007
Well it's been some 2 years and 3 months since I posted this comparison (from June 2005). The update here is as follows:
*I had used 3 copies of the 2470L up through June of 2005, and the best copy was the one in this June 2005 comparison. The 2470EX DG Macro in the test was my only copy I had but it was calibrated at Sigma NY for front-focusing (obviously came back fine and good).
*Since the comparison, and after having used these 2470 lenses quite a bit, I came to the conviction that the 2470EX was at least as good, if not better, than the L optically. You can see my findings here:
*I eventually sold the 2470EX (reluctantly) to a good man in Missouri (Lincoln Westfall).
*Lincoln recently sent this copy of the 2470EX to Klaus at Photozone for a test (on a APS-C body).
*Here are the results:
http://www.photozone.de/8Reviews/len...0_28/index.htm
*You can see it's a solid performer, to say the least. Consistent with my own findings.
*And here you can compare PZ's findings with the 2470L they have used (count all FOUR of them):
*I think we can fairly conclude at this point that the EX is a complete "steal" of a lens (i.e., a properly functioning one, of course). It lacks the L's refined build and weathersealing and ring USM with FTM and "sexyness" (which is why so many buy the L ), but at $375, the EX remains a very solid bang for buck standard zoom.
*Note that both my tests and PZ's only consider APS-C bodies, so how these lenses compare at the edges on APS-H or FF is undetermined.
So consider this thread "updated".
LightRules is offline   Reply With Quote
Old 23rd of June 2005 (Thu)   #2
Loaded
Default Re: Canon & Sigma 24-70 f2.8 Test
i have the Sigma I was wondering how i can test for front focusing
Loaded is offline   Reply With Quote
Old 23rd of June 2005 (Thu)   #3
lost
lost's Avatar
Unfortunately I was not able to view most of the pictures. I have the Sigma and would like to know asside from the USM how they compared.
Canon 7D and Canon 30D - BG-E2
Canon EF 100-400L - Sigma EF 24-70 2.8 EX DG Macro Canon EF 50mm 1.8 - 580 EX
"Its all fun and games till the rent check bounces." Lost
lost is offline   Reply With Quote
Old 23rd of June 2005 (Thu)   #4
lost
lost's Avatar
Does any one know if a 67mm filter would do? I could get one for my 70-200 f4L and a step down ring. Hmmmm its a thought.
Old 23rd of June 2005 (Thu)   #5
Nightcrawler
Nightcrawler's Avatar
I am having problems seeing the pics too.
Nightcrawler is offline   Reply With Quote
Old 23rd of June 2005 (Thu)   #6
LightRules
LightRules's Avatar
It's pbase acting up again. Hopefully they'll have it working soon enough. As for focus testing, just shoot a lot at f2.8 and you'll know soon enough if your copy is fine or not. I should say also that many "focus problems" are user error, especially when working with narrow DOF or shooting against low contrast subjects. But fire off several hundred shots at f2.8 and you should be able to tell how your focusing is.
Old 24th of June 2005 (Fri)   #7
OceanView
OceanView's Avatar
Is the Sigma still having problems when using a 20D?
If so, that's a shame.
I would like to have tried it out.
Anyone know for sure?
OceanView is offline   Reply With Quote
Old 24th of June 2005 (Fri)   #8
LightRules
LightRules's Avatar
It's up now, re-loaded:
http://www.pbase.com/fstopjojo/image/45240719/original
Old 24th of June 2005 (Fri)   #9
blue_max
blue_max's Avatar
Let's get one thing clear before I comment. I like Canon lenses.
Now, I agree that in this test the Sigma more than competes with the Canon. In some of your shots it definitely is better (well done on not moving the camera!).
The only thing I would say is that the Sigma had special attention. All lenses are mass produced. Your Sigma was looked at on an individual basis and fine tuned by professionals. One could argue that the Canon may have been more able to compete on a similar basis.
I don't have either lens, but this shows that the Sigma has the quality in the actual glass – the trick seems to be getting the most out of it. That also goes for the Canon.
It's rather sad that it seems to be such a lottery.
Graham
Lamb dressed as mutton.
blue_max is offline   Reply With Quote
Old 24th of June 2005 (Fri)   #10
condyk
Africa's #1 Tour Guide
condyk's Avatar
As usual, a great contribution. Very nice test. This is such an important range for many and I am amazed by the results. I had fully expected the Canon L to win, not easily but by a notable margin. The Sigma is better throughout ... it's that simple.
Now full! Great African Photo Safari 2013 - Kruger National Park, South Africa click
condyk is online now   Reply With Quote
Old 24th of June 2005 (Fri)   #11
LightRules
LightRules's Avatar
Graham, your comments are well-taken. It should be noted though that my previous 24-70L actually went to Canon Irvine for calibrating as it was horrendous out of the box; I couldn't get a single shot in focus, it seemed. After I got it back, they replaced the main circuit board, adjusted the front element, and it was quite good. But "quite good" was about equal to this 3rd L I currently have. Regardless, QC is a serious issue today with many makers, and my Sigma did get a hands-on inspection. But again your comments are well-taken.
Old 24th of June 2005 (Fri)   #12
blue_max
blue_max's Avatar
And this is the Canon lens that I suggest has a quality control issue – and get slated for perpetuating an urban myth!
The lens IS capable of being fantastic – many say so. It IS horrendously expensive for what it achieves (24-70). I can not imagine spending so much on a lens and finding it so poor. It is no wonder that the likes of Sigma and Tamron have capitalised. It is the focal length that is ideal for a general purpose lens and the battleground has never been hotter. It's great to have such a choice, but I am disappointed to hear, yet again, that this particular Canon lens has not performed. I so want to buy it, but it has to be clearly better than the opposition and it obviously isn't always.
Thanks for posting the test. Just maybe Canon will listen and it will up the quality for everyone.
Graham
Old 24th of June 2005 (Fri)   #13
LightRules
LightRules's Avatar
The L costs about $1200 and the EX costs $365. If it were simply optics, either the L is overpriced or the EX is way underpriced. But the $800+ difference is going to be in overall build refinement, weathersealing (rubber O-ring), and the excellent USM. For some this is worth it, for others it isn't at all. In terms of AF speed they are actually very close, except that the EX makes noise while the L is ninja silent. I don't like the L's hood as it feels flimsy and is too bulky; IMO a solid, flower-petal one like the EX is both smaller and will provide plenty flare protection.
There's no doubt that the L is still "the standard" of this zoom range. But IMO it isn't for its optics; it's for the other areas of build and refinement. The new Sigma is definitely a serious contender for those looking for a "bang for buck" lens. Optically, it's arguably second to none in this focal range.
Old 24th of June 2005 (Fri)   #14
Tom W
Canon Fanosapien
Tom W's Avatar
Nice test, fstop. I think that in terms of sharpness, the Sigma has a slight edge at 70, but it seems that the Canon holds the corners better at 24 mm. They are very close, though. The Sigma seems to have a little bit more fringing at 70/2.8, but not much. By f/5.6, they're both very good.
I think that the Canon exhibits a little bit more contrast, but this is hard to discern since even 1/10 of a stop of difference inexposure can give that appearance. And I'm not sure if more is better or not. Both are really looking good.
Good bokeh on both lenses - I don't seem to find the telltale Sigma color cast that I've seen in the past, though a complete, uncropped image with known colors would help there (of course, post-processing can usually take care of minor casts anyway).
Given that I like having 24 mm available, the Sigma would make a good alternative, if I didn't have a really nice Canon 24-70 in my possession already.
Tom
5D III, 7D, & various lenses
Tom W is offline   Reply With Quote
Old 24th of June 2005 (Fri)   #15
Tom W
Canon Fanosapien
Tom W's Avatar
In regards to the hood, JoJo, does the front element extend within the shroud of the hood on the Sigma, or is the hood attached to the front of the lens? Curious as I like that part of the Canon design where the angle of lens exposure changes with the focal length to provide deeper hood coverate at 70 mm while allowing wider views at 24 mm.
Also, is this Sigma a full-frame 35 mm lens?
Tom
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon 28f1.8 v Sigma 30f1.4 Test LightRules Canon EF and EF-S Lenses 65 8th of January 2007 (Mon) 23:27
Canon 10-22 vs Sigma 10-20 Test Tee Why Canon EF and EF-S Lenses 15 22nd of November 2006 (Wed) 05:26
Canon 50mm 1.8 v Sigma 35-70 2.8 v Tamron 35-70 2.8 Sharpness Test rickydiver Canon EF and EF-S Lenses 7 23rd of March 2006 (Thu) 11:24
Test Photos - Sigma 18-200 v Canon 17-85 GovtLawyer Canon EF and EF-S Lenses 0 27th of August 2005 (Sat) 21:47
Sigma 30f1.4 v Canon 35f2 [Test 1] LightRules Canon EF and EF-S Lenses 8 10th of July 2005 (Sun) 07:44
