Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 27th of January 2010 (Wed)   #1
EastCoast Captures
Default Automotive
I predominately do automotive photography so here is a few from a receont photoshoot i did with my car club.
Cheers Retta
EastCoast Captures is offline   Reply With Quote
Old 28th of January 2010 (Thu)   #2
vk2gwk
vk2gwk's Avatar
Default Re: Automotive
I like all the shots. Properly lit and composed and focus where it should be. They demonstrate clearly the appreciation you have for cars. I can appreciate the technique you put into taking these shots. But cars do not do anything for me. They provide the means to get from A to B and should be comfortable and reliable (and nowadays use not too much fuel). I don't give a toss what they look like
Cheers from Henk.
It is all in the eye of the beholder.....
5DMkIII, 50D, 24-105/1:4L IS USM + 100-400/4-5.6L IS USM + 50mm 1.4 USM + 580EXII + 430EX(as slave), reflectors, umbrellas and some more bits and pieces...
Have a look at my photos on Flickr!
vk2gwk is offline   Reply With Quote
Old 28th of January 2010 (Thu)   #3
PhotosGuy
Moderator
PhotosGuy's Avatar
These are OK "meet shots" where you don't have the option to move the car, but as images that make each car look as good as possible, they don't do it for me. For instance, the clouds reflecting in #s 1 & 3 interfere with the nice gradation of light that you should have in the body. And what was it that you liked about the pole growing out if it in #4?
See the links in my Sig for some ideas if you're going to "predominately do automotive photography".
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 28th of January 2010 (Thu)   #4
EastCoast Captures
Thanks for your tips i will certainly take them on board for the next shoot.
cheers Retta
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Best automotive lense Welby Canon EF and EF-S Lenses 8 26th of January 2008 (Sat) 14:45
Automotive Question:: InfraRed Transportation 10 11th of January 2007 (Thu) 22:25
Just Some automotive shots B-Unit Transportation 6 7th of January 2007 (Sun) 00:16
First try at automotive... Gienek Transportation 1 14th of June 2006 (Wed) 09:18
