#1 |
Hi All,
Is there a way to figure out how many clicks on my lightly used 7D? Thanks, Cal
Camera: EOS-7D | E-M5 Accessories: Olympus 45mm f1.8 | Panansonic 12-35mm f2.8 | 24-105mm f4L | Sigma 50mm f1.4 | 85mm f1.8 | 100mm f2.8L IS Macro | 70-200mm f2.8L IS | 24mm f1.4 || 580EX II
| sponsored links |
#2 |
If it has never been reset just take a picture and the image number is your counter.
Canon 7D l 40D W/BG-E2N l EOS 3 W/PB-1 l 17-40 4.0L USM l 24-70 2.8L USM l 70-200 2.8L IS USM II | 580 EX II W/CP-E4 l Bogen 3021N W/3047 l Bogen 680 W/168 l Bogen 3071 W/3091 l Alien Bees 2- B1600 2- B800 |
#3 |
unless you done 10.000 or more. on the 30d it resets back to 0 after 10.000
Canon EOS 30 D EOS 350 D canon eos 5d mk1, 100-400 L / 24-70 L / 70-200 ,canon eos 17-40 LL F4 / 10-22 /50 1.8, Sigma 105mm 2.8 http://markbarnes.fotopic.net/list_collections.php |
| sponsored links |
#4 |
that was changed one the 40D and later.
#5 |
The 7d has a shutter count thing under battery info and it will tell you the shutter count, now I don't know if it changes when you reset or whatever.
#6 | |
My Gear List
#7 |
When you charge the battery it resets the battery info shutter count
#8 |
Try EOS Info:
http://astrojargon.net/EOSInfo.aspx
Canon 7D
10-22 f/3.5-4.5 • 28-75 f/2.8 • 50 f/1.8 II • 60 f/2.8 70-200 f/2.8L IS II • 300 f/2.8L IS |
#9 |
EOS info does not work on the 7D or T1i/500D. Probably won't work on any other newer cameras that Canon might release. At least not until the EOSInfo software is updated.
Mike Sowsun.......... G1x / 5D Mk III / EF 40mm 2.8 STM / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF Extender 1.4x II / 580EX II / 430EX II (x2) Full Current and Previously Owned Gear List over 40 years |
#10 |
#11 |
No their is a watch battery that retains the info. If you have to change that watch battery (about every 5 years) put a fully charge camera battery in. Memory stays.
#12 |
The "watch battery" does not retain battery shutter count info. On the 7D, the battery shutter count is re-set when you change the battery.
#13 |
The battery info shutter count is reset when you charge the battery. It is specific to each battery.
My Gear List
#14 |
This software might work http://www.opanda.com/en/iexif/
www.borrowlenses.com |
#15 | |
So for software developers, to be able to access the newer models you need to use later versions of the SDK (2.6 and 2.7) but in versions after 2.5 they won't let you get to the ShutterCount data. Sucks.
Walt Canon Xti and 5Dc And bag full of stuff Last edited by WaltA : 2nd of February 2010 (Tue) at 17:57. |
| Thread Tools | |
| Display Modes | |
| Shutter Count | Rey.dos | Canon EOS Digital Cameras | 22 | 7th of July 2010 (Wed) 16:36 |
| shutter count | goatydude | Canon EOS Digital Cameras | 2 | 7th of December 2009 (Mon) 22:21 |
| 40D shutter count | riyazi | Canon EOS Digital Cameras | 96 | 4th of July 2009 (Sat) 16:19 |
| Shutter count/actuations....excessive worry about count? | HeathNC | Canon EOS Digital Cameras | 34 | 13th of May 2009 (Wed) 01:41 |
| Shutter count | *Sonic* | Canon EF and EF-S Lenses | 1 | 10th of February 2007 (Sat) 19:06 |
