Reply
Thread Tools Display Modes
Old 2nd of February 2010 (Tue)   #1
PMan0
Default FTM Focus - When do you use it?
I own and love my Canon 70-200 F4 L but just started realizing that I don't use its FTM focus feature. When does this feature typically come in handy?
Where do you find yourself most often using it?
Am I missing out by not using it?
PMan0 is offline   Reply With Quote
Old 2nd of February 2010 (Tue)   #2
tfd888
tfd888's Avatar
Default Re: FTM Focus - When do you use it?
It's a very handy thing to have. For people that AF using the * button, they can just MF at anytime without having to flip the MF switch and instantly start AF if need be.
Alexander R.O.
1D-Mark III ~1D-Mark II ~ 60D ~ 20D (Gripped)
(70-200mm L 2.8 IS) ~ (17-40mm L 4.0) (Sigma 24-70mm 2.8 EX DG Macro RIP) ~ (50mm 1.8 MKII) ~ (Alpex 35mm f/2.8 M42 mount) ~ (430EX II) ~ (Yongnuo YN-560 III)
My Website - My Blog - My Flickr
tfd888 is offline   Reply With Quote
Old 2nd of February 2010 (Tue)   #3
crn3371
crn3371's Avatar
I really don't think you're missing out on much. With the dim viewfinders and lousy focus screens on most dslr's manual focusing is kind of a pain. The only lens I manually focus with is my macro.
crn3371 is offline   Reply With Quote
Old 2nd of February 2010 (Tue)   #4
PMan0
Okay, so I do use the * buttom to AF - would I AF first with this button and then 'tweak' using the focus ring? Then lock exposure with half shutter press (recompose if necessary) and shoot?
Paul
Old 2nd of February 2010 (Tue)   #5
BlueTsunami
BlueTsunami's Avatar
Paul
Exposure locking and Auto Focusing can be interchanged (as far as what goes first) but its usually the Manual Focusing that's done after Auto Focusing (one case being Focus and Recomposing, and adjusting the focus for the slight change in focus).
One may want to exposure lock first (like the sky... so half press the shutter first), Auto Focus on the subject (using whatever focus points), if the composition calls for the subject to be outside the AF points thats when you recompose and touch up via Manual Focus.
BlueTsunami is offline   Reply With Quote
Old 2nd of February 2010 (Tue)   #6
phreeky
On my lenses without full-time MF I've NEVER missed it. That's not to say that others don't find it useful, but I really do think people overstate its importance.
In fact I also think that of AF speed. Cheap consumer telephoto zooms have very little trouble tracking a jet zipping past in my experience. Ironically I think the slower focusing lenses are the ones that need full-time MF more as you can then easily twist the focus to near-enough and then AF quickly from there.
phreeky is offline   Reply With Quote
Old 2nd of February 2010 (Tue)   #7
bohdank
bohdank's Avatar
I only MF with my MF lenses or when shooting macro or near macro. The importance of MF override on USM lenses is highly overstated, imho.
Montreal Concert, Event and Portrait Photographer
Flickr
bohdank is offline   Reply With Quote
Old 2nd of February 2010 (Tue)   #8
tfd888
tfd888's Avatar
Paul
That or not even AF at all and MF the whole shot without ever touching the * button.
What I'm getting at is that it's very easy to switch back and forth between AF and MF if need be using this method or to correct the focus after AF'ing if need be without having to fumble for the switch in tough lighting conditions or take your eye away from the viewfinder.
Alexander R.O.
Old 2nd of February 2010 (Tue)   #9
PMan
This makes absolute sense - I've never tried it. Next time I get outside with my camera (a bit cold and snowing right now) I'll certainly test drive the FTM focus.
Paul
Canon Rebel XT | Canon EF 70-200 f4L | Tamron 17-50 F2.8 XR DiII | Canon EF 50 f1.8 | Tamron 28-80 f3.5-5.6 | Canon Speedlite 430EX
Manfrotto 190XPROB + 804RC2 Head | Lowepro Orion Trekker II
PMan is offline   Reply With Quote
Old 2nd of February 2010 (Tue)   #10
KCMO Al
KCMO Al's Avatar
Air shows with my 100-400. I can zoom in to 100 to pick up the plane as it begins it's cross, then zoom out and compose and focus with the push/pull focus ring. Very handy and works very well. Also as stated, macro. I set the magnification I want, then use the focus rail to isolate what I want in focus. (I also use M exposure for both of these situations as well.)
Film: Leica M-4, Elan 7E, Rolleiflex 2.8f, Pentax 645 -- Digital: Canon Pro-1, EOS 5D Mk III
EOS Lenses: Sigma 24-70 f2.8 EX - Canon EF 17-40 f4.0L - Canon EF 24-105 f4.0L - Canon EF 35 f1.4L USM - Canon EF100-400 f4.5-5.6L IS USM - Canon EF100 f2.8 Macro - Other stuff: MR 14EX - 430EX - 580EXII - ST-E2 - TC1.4x - TC-80N3
KCMO Al is offline   Reply With Quote
Old 2nd of February 2010 (Tue)   #11
elader
elader's Avatar
only when I have an extension tube on my 85 do I MF.
Eric
FJR1300 rider
5D mkIII and 1D MkIII
16-35L | 24-105L | 70-200L f/2.8IS | 85 f/1.8 / 50 f.1,4
elader is offline   Reply With Quote
Old 2nd of February 2010 (Tue)   #12
Sean
Sean's Avatar
I have been using FTM on my 300 F4L IS with spectacular results. I have a feeling my AF Micro Adjustments are off, and just haven't re-brickwalled that combination to my satisfaction. Manual focus has been stellar however. Can't get enough of it.
Canon 50D - 17-55mm F2.8 IS - 300mm F4L IS - 70-200mm F4L IS - 50mm F1.8 - 580EX II & 430EX - Full Gear Listing
Flickr - C&C Always welcome.
Sean is offline   Reply With Quote
Old 3rd of February 2010 (Wed)   #13
artyman
artyman's Avatar
It's very useful for tracking or getting initial focus on birds hidden in foliage before hitting the AF button.
Art that takes you there. http://www.artyman.co.uk
Ken
artyman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
D|Focus V2 - New affordable FOLLOW FOCUS system announced - VIDEO DSLR Pablov Accessories & Storage 0 27th of November 2009 (Fri) 02:14
Manual Focus, Auto Focus, Grid Focus Screen POTN Head Canon EOS Digital Cameras 17 6th of August 2009 (Thu) 07:22
Do front (or back) focus issues persist if manual focus is used? Maxdave Canon EF and EF-S Lenses 4 23rd of September 2008 (Tue) 06:47
Is my lens/camera back focus? here is my focus test picture highroller Canon EF and EF-S Lenses 6 8th of January 2008 (Tue) 18:43
Focus speed vs focus ability/camera focus vs lens focus timmyquest Canon EF and EF-S Lenses 8 2nd of April 2004 (Fri) 10:56
