#1 |
I'm looking for a sturdy tripod that I can get a lot of height out of, and after looking around several websites, I'm not sure what to get. I currently use a cheap plastic tripod, which is not suitable for what I am doing. I shoot a lot of low light situations, with slow shutter speeds and the movement in the tripod is causing blurring. I also have a Velbon SX-681K which I use for video work, but the panhead is fixed so I cannot shoot portrait using this tripod, which I often have to do. Should I just look for a different panhead for the Velbon? Is this possible, or is there a great new Tripod that I'm missing?
Thanks in anticipation
300D, Canon 18-55mm, Canon 100-300mm, PowerBook, iMac, Adobe |
| sponsored links |
#2 |
I have Bogen 3221 Wilderness Tripod & Bogen 322RC2 Grip Action Ball Head and I love it. but it is up to you what tripod do you want and for what type of photography
"Photography takes an instant out of time, altering life by holding it still." AjP Photography | SportsShooter | WPJA Member |
#3 |
I use a Bogen 3021BN with 3047 3-Way head. It's heavy, but very sturdy. I use it for indoor and macro work. Setting up scenes, low light, product photography for magazines, etc. Max height on mine 75.8".
If you plan to hike or walk around with a tripod a lot, you might want to look at lighter stuff. Mine weighs about 10 pds... |
| sponsored links |
#4 |
Thanks, I'll have a look at those. I'm shooting archive shots for live theatre, and at the moment I'm climbing on seats and balancing the tripod across three seats to get the height I need. If I can get a taller tripod, then at least that will be sturdy, and I'll just have to concentrate on not falling off the seats as I try and look through the viewfinder! Weight is not really a factor for what I'm doing. I'll have a look at the Bogens.
#5 |
If you want a tripod that will position the camera in all sorts of weird ways, not necessarily straight over the center, and also able to splay the legs at odd angles to fit into uneven setups, consider the Gitzo explorer -- it's extremely versatile, and rigid, and fairly quick to set up and move around. I love mine. Carbon Fiber ones are more expensive.
#6 |
I use the Manfrotto 055 Professional with 141RC head, and I'm very happy with it
----- Bernt-Inge ----- Choose a job you love, and you will never have to work a day in your life. www.bernt-inge.com My gear My Flickr stream Twitter |
#7 | |
5DMII w/BG-E6 -- 7D w/BG-E7 -- G15 15mm F2.8 Fisheye -- 50mm F1.4 -- 85mm F1.8 -- 100mm F2.8 Macro 135mm F2 -- 16-35mm F2.8L -- 24-70mm F2.8L --70-200mm F2.8L IS 300mm F2.8L IS -- Sigma 50-500mm f/4-6.3 EX -- Canon 1.4x & 2x II TC Speedlite 580EX (3x) w/CP-E3 -- Speedlite ST-E2
#8 |
obvious its pointless
If you are looking for a conventional setup with a fairly good level of flexibility for most 'regular' shots, look at my setup - I'm very happy with it.
The advanced ones allow flexibility for specialized uses - macro or in extreme conditions where a regular 3 legged tripod will be a pain to setup.
Canon 7D , Canon 20D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender My Gallery |
#9 |
King Duffus
Whatever tripod you decide to get I hope you know that in windy situation you will need to add ballast to weight down the lower part of the tripod.
I have the Action Grip and I like it on my Monopod but it is limited to only 5lbs. |
#10 |
Just a thought as to the hight of the tripod, it would be very easy to make an extension to the center column so as to increase hight. Some tripods even have this feature so as to remove part of the center column so the tripods can go lower.
Cheers Wayne EOS 30D+350Dx2+BG-E2+BG-E3+18-55MkII+EF 70-300IS/USM+EF 75-300IIusm+Sigma 50-500DG+Tamron SP90 f2.8Di+Sigma 17-70+Kenco MC7 2x+580EX+430EX POTN Aussie club Feel free to visit my image galleries www.mitconphotographics.com |
| Thread Tools | |
| Display Modes | |
| Lightweight but sturdy tripod | bettyn | Accessories & Storage | 5 | 20th of March 2007 (Tue) 19:18 |
| cheap, sturdy macro tripod...possible? | layout1109 | Accessories & Storage | 15 | 2nd of January 2006 (Mon) 03:57 |
| best sturdy tripod | mknabster | Accessories & Storage | 23 | 9th of July 2005 (Sat) 23:40 |
| best choice for sturdy tripod | ctgoldwing | Accessories & Storage | 6 | 24th of August 2003 (Sun) 13:38 |
