Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 8th of February 2010 (Mon)   #1
mitz444
Default lensmate adapter and sunpak polarizer
Hi Guys,
I just ordered a lensmate filter adapter for my sx20 and was wondering if the sun pak 58mm polarizer would fit into it?
Any feedbacks on this?
Thanks!
Tim
mitz444 is offline   Reply With Quote
Old 8th of February 2010 (Mon)   #2
duckduckdog
duckduckdog's Avatar
Default Re: lensmate adapter and sunpak polarizer
I would try to find the thread size - if they are the same, should work. I ordered the Bowman adapter and filter kit just to avoid any issues with compatability.
Canon SX20IS
Canon A720IS
duckduckdog is offline   Reply With Quote
Old 8th of February 2010 (Mon)   #3
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Yes, the Lensmate filter adapter for the SX1/10/20 takes any standard 58 mm filters. But if you haven't gotten the SunPak filter yet, I'd suggest you read the "Protective Filter FAQ" sticky - not all brands of filters are equally good.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 8th of February 2010 (Mon)   #4
mitz444
great. Thanks for the replies.
I'll read the FAQ
Old 11th of February 2010 (Thu)   #5
technogeek
Originally Posted by mitz444 View Post
Hi Guys,
Thanks!
Tim
If you are getting the adapter to allow you to install filters on your SX20, you don't need to go this route. I installed a 52mm screw in filter and it fits perfectly. No need for step-up rings.
technogeek is offline   Reply With Quote
Old 11th of February 2010 (Thu)   #6
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
The SX20's not actually threaded to take filters; you're pretty much relying on the soft plastic to hold the filter on and it'll be very easy to cross-thread and strip out the lens barrel.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 12th of February 2010 (Fri)   #7
Hasitha
Hasitha's Avatar
Forcing 52mm filters might damege the lens so I think its better go for Lensmate 58mm Filter Adapter or Janco 58mm Filter Adapter . Safer that way.
Canon SX10 IS + Raynox DCR-250 + Hoya 58mm S-HMC Filter + 58mm HMC Circular Polarizing Filter
My Flickr
Hasitha is offline   Reply With Quote
Old 12th of February 2010 (Fri)   #8
JustShootin'
JustShootin''s Avatar
Yep, a few people will swear to you that those are threads on the SX20/SX10, but they're not. Get the adapter.
Gary
Canon SX40, S100 and a Non Canon dSLR
“Any darn fool can make something complex;
it takes a genius to make something simple.”—Pete Seeger
JustShootin' is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Lensmate TC adapter for G10 MarkoPolo Canon G-series Digital Cameras 1 18th of January 2009 (Sun) 21:58
G9 and LensMate Adapter ModernPics Canon G-series Digital Cameras 7 1st of August 2008 (Fri) 19:47
Lensmate adapter help, please? teknofyle Canon G-series Digital Cameras 3 12th of May 2003 (Mon) 08:23
lensmate adapter vs. canon la-dc58 adapter skipperchong Canon G-series Digital Cameras 1 31st of January 2003 (Fri) 08:15
