#1 |
I've noticed when I register settings on C1, the shooting style defaults to P. Is there anyway to set this to M or Av?
I'd like a quick button to use to save all of my hockey settings. I shoot in the same arena for each game and the lighting is always the same so it would be nice to have this feature. For the most part, C1 does this for me except in P mode, the aperture and shutter speed bounce around as they see fit. This is annoying. Any advice? Thanks in advance. (I looked in the stickies and couldn't find this)
Dave 7D, 70-200mm 2.8 L IS, 24-70mm 2.8 L, 50mm 1.4, Tokina 11-16mm 2.8, 580EXII My Flickr |
| sponsored links |
#2 |
I"m curious about those settings too.
Canon 5D MkII | Canon 5D MkIII | Canon 60D | 16-35L MKII | 24-70L | 70-200L MKII | 85L MKII | EF 50mm 1.4 | EF 100mm 2.8 | 100-400mm L | EF-S 17-55mm 2.8 | Full gear list |
#3 |
Silly question. But are you registering your settings via menu? Or are you just adjusting your settings in C1 and hoping it'll remember?
You can set your setting in whatever mode (Av/Tv/M) and then go into the menu, and register your setting to C1/2/3, and then whenever you dial the knob to C1/2/3, the settings are then ready for use.
Julian Gear/Feedbacks | SmugMug Founding member and President of the OGUS Photo Club (Over-Geared, Under-Skilled) |
| sponsored links |
#4 | |
#5 |
Can someone point me to a resource that can show me how to set these?
edit: nevermind I found it.
#6 |
#7 |
I also thought it would be nice to "save" my indoor sports settings (which I shoot in Manual Mode) by registering them to C1. I'm not sure about the camera reverting to Program Mode, but whenever I tried to change a setting on the fly (i.e. shutter speed) the camera seemed to go back to the original presets. I was confused (fog of war) and didn't have time to mess with it (in the heat of battle) so I put it back to M and I haven't tried it again (too many other thinks to try to master first).
Parenthetically speaking, I love this camera.
EOS 7D l EF-S 10-22 l EF-S 15-85 l EF-S 17-55 l EF-S 60 Macro l EF 70-200 f/2.8L IS l EF 85 f/1.8 l 430EX x2 |
#8 | |
If your exposure numbers change while you're in C1, could it be because you set the C1 to use safety shift? Just a thought.
_______________________________________________ Canon Electro-Optical System Last edited by actprivate : 10th of February 2010 (Wed) at 16:01. |
#9 |
Page 223 of the manual says it quite clearly. A good place to START is always in reading the manual that comes with a camera
Doug, eosphotoman@yahoo.com 7D 300L, 70-200L, 50 1.8, 28-105 EF, Sigma 18-50 EF-S 580Speedlite, AB Ring Flash, Excalibur 320, 2- Morris Optical Slaves Adobe CS5 Extended, Wacom Graphics Tablet |
#10 | |
#11 |
I get it now. If for the very first time, you went to C1 and then registered the settings, you're probably right that the camera has saved the default exposure mode (which seems to be P). The correct way to set any of C1-C3 for the first time is to choose the exposure mode on the main dial first and then, set all CF, AF, drive, flash, metering etc. settings and then register the bunch. Once you have the C1-C3 set up, it is easier to fine tune the settings by selecting them on the main dial first and re-registering after changing the required settings. Obviously, this can be done for every settings except for the exposure mode because to change that, you'd need to turn the dial out of C1-C3. By this, camera will reinstate whatever settings you had in your creative zone last time.
_______________________________________________ Canon Electro-Optical System |
#12 |
Thanks. The instruction manual, which I did go to first, fails to address my situation - where I mistakenly started programming all of the desired settings in C1 and then registering. Now it appears I will have to start all over because there is no way to switch the shooting mode to M or Av without turning the dial at the top.
#13 |
The default is in P. If you set it while in C1, it will go to P.
Set up the camera however you like it (if M is what you want, have the dial on M) and then register it to C1 from the menu. Don't have it on C1. Once you have it set, you can make adjustments while in C1. |
#14 | |
| Thread Tools | |
| Display Modes | |
| Indoor sports lens question AND forum question | Adam Hicks | Sports Talk | 13 | 24th of May 2009 (Sun) 14:22 |
| Question RE: Portrait Lens Question on a 40D (1.6x crop) | DeCeccoNET | Canon EF and EF-S Lenses | 6 | 30th of January 2008 (Wed) 23:30 |
| PS2-FotoFusion_Asuka question (dumb question warning) | TXLEBER | Weddings and Other Family Events | 9 | 30th of June 2007 (Sat) 02:50 |
| David Jay Showit slideshow question and imovie question | islandphoto | Weddings and Other Family Events | 25 | 13th of May 2007 (Sun) 23:20 |
| Powershot S40 Software Question (and battery question) | mrhicks | Small Compact Digitals by Canon | 1 | 8th of May 2003 (Thu) 14:06 |
