Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EF and EF-S Lenses > Lens Sample Photo Archive
Reply
Thread Tools Display Modes
Old 11th of February 2010 (Thu)   #1
CliffordPhotography
Default Best way to test for sharpness?
Title pretty much covers it guys....
Looking for the best way to test the sharpness of a lens. I just aquired a 70-200 2.8 IS and i really dont think its that sharp.
Any help greatly apprieciated.
CliffordPhotography is offline   Reply With Quote
Old 11th of February 2010 (Thu)   #2
CliffordPhotography
Default Re: Best way to test for sharpness?
Somebody move this out of the Sub-Forum. Totally didnt mean to put it in here.
Old 11th of February 2010 (Thu)   #3
James Thomas 1975
James Thomas 1975's Avatar
Can't help with the sharpness test I'm afraid.
But I'm also looking at a 70-200 for motorsport shots,so I'm thinking it needs to be the 2.8 version.
I was comparing both versions (f/2.8 and f/4) in these very sample threads here,and after looking at both I'm in the same frame of mind as you.
Don't get me wrong,the photos in the 2.8 thread were absolutely fantastic but the difference in sharpness of the 2 lenses seems quite significant
5D Mark III.
14mm II, 17-40, 24-70, 70-200 2.8 IS,100 L, 100-400.
James Thomas 1975 is offline   Reply With Quote
Old 11th of February 2010 (Thu)   #4
gordon67
gordon67's Avatar
Take a few shots with your camera and lens on a tripod, shoot something static, set the lowest iso, for example iso 100, I think set the aperture to somewhere between f4 and f8 (someone correct me if this is wrong), use the self timer or a cable release to trigger the shutter to minimise movement of the camera, turn off image stabilisation (when on a tripod), and then bump up the sharpness in dpp or photoshop.
gordon67 is offline   Reply With Quote
Old 11th of February 2010 (Thu)   #5
CliffordPhotography
Gordon ill check it out. I wanst using a tripod at the time...but I had the 70-200 resting on my table with the tripod mount and self time was on. ill run it through the f stops a bit. That i didnt do.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How to test sharpness chairmnofthboard Canon EF and EF-S Lenses 2 14th of October 2009 (Wed) 02:38
Sharpness test? Paul Li Canon EF and EF-S Lenses 1 7th of August 2009 (Fri) 02:39
85 1.2 mk2 sharpness test futura Canon EF and EF-S Lenses 33 20th of June 2007 (Wed) 05:54
Best Way To Test Sharpness Thordic Canon EF and EF-S Lenses 15 19th of May 2006 (Fri) 08:22
Sharpness, a how to test? oldradioman Canon EF and EF-S Lenses 11 27th of November 2005 (Sun) 01:07
