Thread started 14 Feb 2010 (Sunday) 05:38
External flash and 7D sometimes work?
Aznattic
Feb 14, 2010 05:38 |  #1
I got a 7D about a week ago, and i have a strange problem with my external Sigma EF-500 DG Super flash and the 7D.
The problem is that sometimes the Sigma works, sometimes it does not. The flash could be charged and ready but it still won't light up. The flash's light meter checks all the time, but yet the flash still doesn't fire sometimes. When it does, most of the time the pictures are greatly over exposed even with the flash set at +-0 and the shutter speed high and the iso low on the camera. The Sigma's flash shoe horn lock is messed up, but the flash always worked on my XTI and currently works great on an XT body with no issues.
Is there something i missed in the 7D manual? I currently don't have another external flash to test whether it is the body that has a problem.
Ideas? Thanks.
7D II - Canon 24-70 II F2.8 - Sigma 85 1.4 - Sigma 30mm 1.4 - Canon 18-135 STM
oldvultureface
Gallery: 67 photos
Feb 14, 2010 06:35 |  #2
Without having a Canon branded flash available, the only thing I can suggest is to clean the contacts on the hot shoe and flash.
Aznattic
Feb 14, 2010 07:05 |  #3
I am trying to borrow one today, i just find it would be extremely odd for it to work fine in an XTI, XT, body but a 7D body it refuses to work on properly? =/
When i go through the 7D's menu and disable flash altogether, the flash doesn't work at all, which is good.
I just tested out some shots both same shutter speed, iso, F stop; only difference was a -+0 and a +3 setting on the flash. Both looked equally overexposed, as if the level of flash power means nothing.
swjim
Feb 14, 2010 08:30 |  #4
My money says that the IR signal was getting interrupted in some way. Where were you shooting when you had the problems?
Jim
Aznattic
Feb 14, 2010 08:53 |  #5
Today i took it out to mardis gras at night. External flash wouldn't work at all. Had some time to play with it in the car, worked sometimes or over exposed. Tried it in my house with medium amounts of light, didn't work or over exposed. Tried it with the XT, works perfectly, i could control the flash exposure and actually have it work once again.
I had this problem earlier this week while messing around with the 7D, and i thought the shoehorn lock was just acting up again but it works fine on the XT.
Still trying to get my hands on a Canon flash to fully confirm, i just don't see why the Sigma flash wouldn't work though.
eosphotomanoftennessee
Feb 14, 2010 09:55 |  #6
From what I can see from the Sigma specs your 500 model is TTL but NOT E-TTL as would be required for automatic metering for new Canons.
Doug, osphotoman@yahoo.com (external link)
7D
;), Canon SX1 IS, Film Rebel for history
300L, 70-200L, 50 1.8, 28-105 EF, Sigma 18-50 EF-S
580Speedlite, AB Ring Flash, Excalibur 320, 2- Morris Optical Slaves
Adobe CS5 Extended, Wacom Graphics Tablet
Aznattic
Feb 17, 2010 07:57 |  #7
The flash does support ETTL II though. Now i am starting to think it is the camera.
Even though the flash isn't Canon, shouldn't i be able to adjust it's settings in the Menu Flash option? It does not let me.
agv8or
Gallery: 10 photos
Feb 17, 2010 09:07 |  #8
Aznattic wrote in post #9626148 (external link)
The cameras flash menu only works with the 580EXII and 430EXII. Even the older 580EX, 430EX and 550EX will not work with the cameras flash menu for adjusting flash settings.
Rand
Gear
msowsun
Gallery: 14 photos
Feb 17, 2010 09:56 |  #9
Aznattic wrote in post #9606411 (external link)
That is probably the problem.
The 40D, 50D, 7D, 5D Mk II, 1D Mk III and Mk IV, all have a slightly different hotshoe to accommodate the 580EX II weather seal rubber boot.
This may be enough to cause contact problems with your "Messed up" Sigma flash.
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Newer/40_5D2.jpg
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Newer/40D_40D2.jpg
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Newer/40Dshoe.jpg
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Newer/40_30Dshoe.jpg
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Newer/40_500D.jpg
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Newer/40_450D.jpg
Mike Sowsun / S110 / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 18-135mm STM / EF-S 18-135mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 1.4x II
speedline_fc
Feb 17, 2010 16:06 |  #10
There's an update for for the Sigma EF 500 DG flash to make it compatible with the 50D and 7D. I can't find the original posts that I read a few months ago, but here's a thread that refers to it
http://photography-on-the.net …/showthread.php​?p=9529364
I contacted Sigma a couple months ago and asked them about the existence of a fix for the EF 500 DG and the person that wrote back said:
Thank you for choosing Sigma products.
The update is only available for the flash designated with the EO ETTL II on the back of it.
You would send the flash to the address below with a note describing why you are sending it in with your contact information.
Sigma Corporation of America
15 Fleetwood Court
Ronkonkoma, NY 11779
ATt: Service Department
My Flickr (external link)
http://photography-on-the.net …php?p=9822373#p​ost9822373
astrocrab
1 post
Joined Nov 2010
Nov 25, 2010 16:47 |  #11
Ideas? Thanks.
i just have upgrade my 7d with a new 1.2.3 version firmware and this sigma flash +7d issue has gone. i have tryed 70 shoots and there is no missed flash at all. (i have sigma 530 super and 7d)
5,015 views & 0 likes for this thread
version 2.0 /
Latest registered member is Chris1978
815 guests, 449 members online
