Thread started 14 Feb 2010 (Sunday) 21:21
Prev/next
how many pixels for 10" X 7.5" print?
DreDaze
DreDaze's Avatar
Gallery: 19 photos
S.F. Bay Area
Feb 14, 2010 21:21 |  #1
so i was thinking about entering a photo into a contest...the rules state that the photo must be able to be printed in high resolution at 10" X 7.5"...one of the shots that i was considering is cropped quite a bit...i'm not sure if I'd be able to print it at that size or not...is there a way to tell based on how many pixels wide, and tall the image is if it'd work or not?
thanks in advance
Andre or Dre
gear list
Instagram (external link)
my 366 for 2016 (external link)
dugcross
dugcross's Avatar
Palm Harbor, Florida
Feb 14, 2010 21:29 |  #2
DreDaze wrote in post #9610341external link
thanks in advance
Well for print when they say high resolution that is normally 300 dpi. Basically open your file in photoshop. Make the resolution 300 dpi and if the resulting dimension is 10 x 7.5 or larger you should be ok.
Doug Cross
Graphic Designer and Photographer
www.crossphotographics​.comexternal link
Stargazerfrank
Stargazerfrank's Avatar
Near ATL.
Feb 14, 2010 21:36 |  #3
I saved this from another web site.
maximum recommended file size will make a Photographic Print that is 300 DPI.
Print Size
MIN File Size - MAX File Size
4x6 600x900- 1200x1800
5x7 750x1050- 1500x2100
8x10 1200x1500- 2400x3000
8.5x11 1275x1650- 2550x3300
8x12 1200x1800- 2400x3600
11x14 1650x2100- 3300x4200
12x18 1800x2700 - 3600x5400
16x20 2400x3000- 4800x6000
16x24 2400x3600- 4800x7200
20x24 3000x3600- 6000x7200
20x30 3000x4500- 6000x9000
Canon T3I 6D 24-105L 100-400L Canon 430EX
my pics
https://www.flickr.com ...ms/with/72157669383​175216 (external link)
DreDaze
DreDaze's Avatar
Gallery: 19 photos
S.F. Bay Area
Feb 14, 2010 22:07 |  #4
dugcross wrote in post #9610398external link
o.k....sorry if this is a dumb question, but when i loaded the picture into photoshop it was originally 1,000 X 700 pixels or so @ 72ppi resolution...changed the resolution to 300ppi...and then it made the file larger...it became about 4,000 X 3,000...is that right? would it normally make the file bigger?
Stargazerfrank wrote in post #9610430external link
Print Size
thanks for the list
Andre or Dre
gear list
tonylong
...winded
tonylong's Avatar
Gallery: 60 photos
Vancouver, WA USA
Feb 14, 2010 22:41 |  #5
You will have a pretty bad result with that size photo. The size at 72 ppi is enough to display on the Web, but just enough -- enlarging even to an 7x10 will result in a pretty poor quality image.
If you want too see for yourself, in the Photoshop Image/Image Size dialog, go ahead and set the dimensions to 10x7 inches (which would give you a "native" resolution of 100 ppi. Then set the ppi to 300 and check the Resample to yes, and hit OK. then in Photoshop view the image at a few sizes -- 100% to be really scared, and try viewing at the Print Size to get some perspecive. I'd say as a next step, take it to a print shop and print it out at 7x10 and see how it looks to you.
You image after the resize would be 2100x3000 pixels (a 7 1/2x10 would be slightly larger) and so you can see that an image that would print a 7x10 at best quality should hit those pixel dimensions -- in other words about 6 MP after cropping (as opposed to the <1MP image you are dealing with). Doing the resampling thing for a contest entry may give OK results, but eyeball them for yourself so that you can be your own judge.
Tony
Tony Long Photos on PBaseexternal link
Wildlife project pics hereexternal link, Biking Photog shoots hereexternal link, "Suburbia" project hereexternal link! Mount St. Helens, Mount Hood pics hereexternal link
DreDaze
DreDaze's Avatar
Gallery: 19 photos
S.F. Bay Area
Feb 15, 2010 00:33 |  #6
tonylong wrote in post #9610753external link
thanks, yeah i'm not sure on how the quality would be...that's what led me to ask
just out of curiosity how do you figure the image would be less than 1MP...my images are normally 3888 X 2592 from my 10mp 40D...if i'm at 1,000 X 700...it'd seem like the image would have to be at least 2.5MP equivalent or so...i'm still not suggesting the quality would be good enough
but I don't know what i'm talking about here...just trying to figure how you got that #...:D
thanks again
Andre or Dre
gear list
tonylong
...winded
tonylong's Avatar
Gallery: 60 photos
Vancouver, WA USA
Feb 15, 2010 01:28 |  #7
1 MP is 1000x1000 or the equivalent. This is an image that would fit on your screen at 100 ppi (10x10 inches). Your close crop will struggle though with a print -- what you have to realize is that printing typically needs more resolution than screen resolution when printed/viewed at a "normal" size/distance.
But, like I said, give it a try, do the resizing and be sure to sharpen the image afterware, then have a print shop run off a 7x10 and you should be able to see the outcome.
Tony
JoePhotoOnline
JoePhotoOnline's Avatar
Central Valley, California
Feb 15, 2010 02:30 |  #8
8 x 10 @ 300dpi = 7.2MP
Beginners talk about cameras, Pros talk about lenses, and Masters talk about light.
Feedback: 1 2 3 4 5 eBay UserID: 1969fordtruckman
tzalman
Fatal attraction.
tzalman's Avatar
Gesher Haziv, Israel
Feb 15, 2010 03:28 |  #9
I hope this doesn't offend anybody, but I have to rant a little. Doesn't anybody ever do simple math in their heads? Plug it into Photoshop? I have very little problem knowing that 300 dpi x 10 inches is 3,000 pixels. 300 x 7.5 takes only slightly longer. If you don't have 3000 x 2250 pixels a 10x7.5 won't be "high resolution".
I also don't have much trouble figuring that 1000 x 700 is 700,000 or that that is 0.7 Mp., all without a calculator. Sheeyit, I guess there really is a generation gap. At this moment I'm glad to be on my side of it.
Elie / אלי
René ­ Damkot
René Damkot's Avatar
enschede, netherlands
Feb 15, 2010 06:11 |  #10
The ppi has nothing to do with it. It's the size in pixels that counts (and 1000x700 is way too low for anything bigger then about 4x6")
Why Color Management.
Color Problems? Click here.
MySpaceexternal link
Get Colormanagedexternal link
Twitterexternal link
DreDaze
DreDaze's Avatar
Gallery: 19 photos
S.F. Bay Area
Feb 15, 2010 10:06 |  #11
tzalman wrote in post #9611747external link
i can do simple math in my head...but i know nothing about printing...i have no clue really about 300dpi(or is it ppi?), and all that...I'm an amateur, and rarely print that much right now
hence why i asked the question, i knew it was going to be a simple question to answer and I could get the answer quickly here
the 2nd question about the getting <1mp i knew was dumb from the outset if you look at the way i posed it...however i figured that one out before any responses came, but didn't see the point in editing my post
Andre or Dre
gear list
René ­ Damkot
Feb 15, 2010 10:08 |  #12
ppi = Pixels per inch ;)
agedbriar
agedbriar's Avatar
Slovenia
Feb 15, 2010 17:32 |  #13
Thanks to the slide-ruler. ;)
DreDaze
DreDaze's Avatar
Gallery: 19 photos
S.F. Bay Area
Feb 15, 2010 18:17 |  #14
René Damkot wrote in post #9613084external link
i take it dpi is 'dots per inch'...?
anyways, so this leads me to another question...which is probably totally obvious to all but me:)
so 72ppi is good for web viewing, and things of that nature...and 300 ppi is good for high resolution printing...what ppi is the minimum in your opinion for good printings
also i've only done one large print with my 40D...a 20X30 landscape...but since i knew nothing of ppi, and all that then i'm sure it was done at 72ppi, as that seems to be the resolution all my shots are in when i load them into photoshop
if i were to increase the ppi(i think i'd have to resample it in order to still have that same size) would i notice a difference between the two?...I guess i could just try this myself, but figured I'd see if i could save some $$
thanks for putting up with me again:)
Andre or Dre
gear list
tim
Light Bringer
tim's Avatar
Wellington, New Zealand
Feb 15, 2010 19:09 |  #15
300ppi is ideal, 50ppi will work as long as you're not too close to the image.
10,964 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00328 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is Balco
636 guests, 470 members online
