Reply
Thread Tools Display Modes
Old 1st of July 2005 (Fri)   #1
ghunter
Default Best compliment to XT & 70-200 F4L?
I've just bought a Digital Rebel XT w/o lens hoping to add a few higher quality lenses instead of moving up to the 20D and the default lens to get better (lens) quality, more versatility, and have great lenses when I inevitably upgrade the body in a few years. The XT will see a wide range of uses, but mainly pics of my one year old son, family, and the odd landscape/wildlife/astronomy here and there.
I've found a local 70-200 F4L for a good price, so I'd like to ask what
*one* lens would best compliment this for my purposes? I'd like to stick in the $200-$500 range.
I've read a lot of good things about the 50 1.8 II being a cheap versatile lens, so that might get thrown into the mix as well (unless the 50 1.4 USM could work as my "one other lens")
Thanks!
Graham
ghunter is offline   Reply With Quote
Old 1st of July 2005 (Fri)   #2
tim
Light Bringer
tim's Avatar
Default Re: Best compliment to XT & 70-200 F4L?
Tamron 28-75 F2.8, or since the Tamron is so hard to find right now, the Sigma 24-70 F2.8 is meant to be as good.
I sold my 50mm F1.8, it's an old cheap design that doesn't focus accurately on my 20D, even after calibration. The tech told me to get the USM 1.4 lens, I did, and it's much better.
tim is offline   Reply With Quote
Old 1st of July 2005 (Fri)   #3
ghunter
So if I wanted to stick with Canon would you say the EF 24-85mm f/3.5-4.5 USM is the closest to those? My last film SLR was a Minolta and I loved the Tamron lens I had hooked up to it, but with the digital world and all the potential problems I'd rather stay with one manufacturer for support reasons.
I've also read that the 50 1.8 II may have a cheaper plastic feel but better digital compatibility. Was yours a mkI or mkII?
Old 1st of July 2005 (Fri)   #4
blue_max
blue_max's Avatar
Whilst I would prefer Canon lenses myself, if you buy a new lens, then there is no real reason not to buy third party. Even a second hand lens can be checked with your camera. I don't think that I would worry about the support issues.
If you are buying the 70-200L, that sets a pretty high standard. If you consider the consumer range, I think you may end up comparing and feeling dissatisfied.
The 50mm lenses are optically, extremely good. Both are pretty fast and very useful in low light conditions. The 1.8 is rather cheaply made and the 1.4 is rather more expensive – your choice.
If you like to use the wide end – do consider the 17-40L, which gives a fairly good spread and might do you at a pinch. It is not a cheap lens, but will compliment the 70-200 very well. A walkabout lens in the 24-70 region is also very useful, but you don't even want to know what Canon charge! There are cheaper alternatives as has been suggested.
I would probably suggest you take the time to get used to the 70-200 and see what it is capable of, whilst saving for a good quality lens in the mid or wide angle range.
You will be impressed with the 70-200!
Graham
Lamb dressed as mutton.
blue_max is offline   Reply With Quote
Old 1st of July 2005 (Fri)   #5
ed rader
"I am not the final word"
ed rader's Avatar
Default the 50 1.8 is recommended for.........
everything because of price. it's a great lens but a portrait lens. sure it's fast for indoor use but it's also long.
and my tamron 28-75 does portraits just as good if not better.
since you have a small camera the tamron 28-75 and 17-35 would be a better fit than most other zooms because they are about the smallest and lightest going.
and a quality zoom does not limit you in range like a prime and is just as sharp (in many cases).
ed rader
ed rader is offline   Reply With Quote
Old 1st of July 2005 (Fri)   #6
condyk
Africa's #1 Tour Guide
condyk's Avatar
The SIgma DG Macro Tim mentioned would dovetail nicely and give a few useful extra mm's on the wide end. If you want to stick with canon on this range you will either have to pay a LOT more or accept poorer performance. You could also buy a Kenko Pro 1.4x for your 70-200mm to give some extra length. The Tamron Sp 1.4x is the same. Go for Canon if you like again, but it will cost more for minimal performance gain, if any.
The 50mm II 1.8 is a great around the house snapshot and portrait lens, at least for the money, and so why not have it in your bag for the times when you need the lower light performance or just want a super lightweight lens on the camera. They lose minimal value on resale so you can't go wrong.
Tools:
Click - Recent images: Click - Facebook: Click
condyk is offline   Reply With Quote
Old 1st of July 2005 (Fri)   #7
Andrea_T
I'd highly recommend the Tamron 28-75mm as a perfect mate for your 70-200 f4L.
Andrea_T is offline   Reply With Quote
Old 1st of July 2005 (Fri)   #8
ghunter
Hmmm, some very interesting perspectives here. Thanks to all of you - this is great info.
Right now I'm thinking of just picking up a 50mm Canon lens now. I'm still unsure between 1.4 and 1.8 but not for lack of info out there. Then I'll start exploring my options a little more. The Tamron and Sigma lenses are looking better all the time unless I can find a good deal on a used L...
Old 1st of July 2005 (Fri)   #9
Jwreich
Jwreich's Avatar
Do look at the Tamron, it was purchased instead of the "kit" lens with my XT. I love it and it is VERY sharp. I also have the 70-200/4 L and it is nice however I'm learning how to put the lense to good use. I'm a huge fan of my 50mm /1.8 (Can you tell I read this forum a lot and take their advice?). All I can say is these guys and gals won't steer you wrong.
L is nice, but my Tamron ROCKS!.
--JWR
EOS5D + Grip, 1D MkIII
Tamron 28-75 2.8, EF 70-200 L f2.8 IS EF 16-35 L
EF 24-105 L f4 IS, 50mm 1.4, 35 L, 85 1.8, 580EX x4, SB28 x6
www.jessereich.com
Jwreich is offline   Reply With Quote
Old 1st of July 2005 (Fri)   #10
EOSAddict
Book Committee Immortal
EOSAddict's Avatar
I bought a 50mm 1.8 Mk 1 13 yrs ago on a whim in the US. IT sat in my bag for years waiting to be used and I considered selling it many times. On a recent visit to an aquarium which allowed cameras but no flash pghotography I used it to great effect (with ISO400/800) to get some great pics. Its going no-where now! For size/price you can't beat it in your bag.
Al
My Gear, My Website: www.e-ScapePhotography.co.uk
EOSAddict is offline   Reply With Quote
Old 1st of July 2005 (Fri)   #11
skyphix
I find the 50mm to be too long for my "one other lens". It doesnt leave my camera, mind you, but I'll soon have something a bit shorter that wont leave my camera.
If I were to get one other lens besides the 70-200 you've got now, it'd probably be the 17-40L, or Sigma 18-50 2.8 (more likely because Im poor).
I am going a different route, 17-40L, 50mm 1.8 (1.4 eventually), 85 1.8, 135 2.8 SF, then the 70-200F2.8L and 1.4TC
I like primes.
Eric
Digital:
Hacked 300D, BG-E1
Film:
Lost, broken, beat Rebel G that was my first SLR - FOUND!!
EOS 650
Yashica Electro 35 GSN
Lenses
18-55 EF-S
Surprisingly good 35-80 F4-5.6 III
50mm 1.8 Mk1
70-210 F4
skyphix is offline   Reply With Quote
Old 8th of July 2005 (Fri)   #12
ghunter
The camera arrived today and I've been playing around with the 70-200/f4. What an amazing setup! I've ordered the 50/f1.4 and it can't arrive soon enough.
I'm now giving some serious thought to the Tamron 28-75/f2.8 and the Canon 17-40/4L. Completely different lenses, to be sure, but I'd like to see what I'm missing with the 50+70-200 combination before moving on another lens. Saving money and wanting more flexibility, I'll go for the Tamron. Better quality and craving better wide angle shots, I'll get the Canon.
My wife is also a little sick and tired of seeing packages arrive... not that anyone else here has that problem I'm sure
Old 8th of July 2005 (Fri)   #13
rklepper
Dignity-Esteem-Compassion
rklepper's Avatar
Location: Iowa, USA - The Center of the Known Universe. It even makes that sound.
I am thinking about ordering the 70-200f/4L today. Can you post something as I also have the XT.
Doc Klepper in the USA
I
I do not have a humble opinion, so do not look for IMHO.
rklepper is offline   Reply With Quote
Old 8th of July 2005 (Fri)   #14
ghunter
What would you like me to post? It's a phenomenal lens, with amazing clarity across its entire range and incredibly quick focus. Of course, it's limited when used at anything closer than 5 feet but you have a 28-135 for that.
I have absolutely no hesitation in recommending it.
Old 8th of July 2005 (Fri)   #15
93octane
93octane's Avatar
Yep same here I'm not a pro but you can't go wrong with Tamron 28-75,Canon 70-200 F4L if you are getting a zoom and don't want to spend for the 2.8 IS this is the best bang for your buck, 50mm F1.8, and the Kit lens 18-55mm, With these 4 lenses you are pretty much covered until you find out you need more ZOOM
Canon EOS 5D
Canon 70-200 F4 IS L
Canon 24-105 F4 IS L
Sigma 50mm 1.4
Canon 100mm F2
93octane is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
compliment the 70-200 newfly5 Canon EF and EF-S Lenses 0 14th of June 2006 (Wed) 20:00
70-200 f4L -- B&H return............ ed rader Canon EF and EF-S Lenses 3 26th of June 2005 (Sun) 12:55
Thinking about selling my 17-40 F4L & 70-200 F4L.Please help! Kelv2888 Canon EF and EF-S Lenses 39 26th of May 2005 (Thu) 12:44
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
