Reply
Thread Tools Display Modes
Old 7th of April 2001 (Sat)   #1
Novice
Default Lens adaptor for G1
I have seen an aftermarket lens adaptor ror the G1, it is a 2" straight barrel design, the price is $20, Ilost track of it. Can anyone help please?
Thanks in advance.
Novice is offline   Reply With Quote
Old 7th of April 2001 (Sat)   #2
Del K
Default Re: Lens adaptor for G1
You probably saw the Lensmate. I have one I leave on may G1 all the time, and many others have appreciated its use on the Canon Forum at DPReview. You can find it as well as filters and close-up adapters at http://www.lensmateonline.com
A very nice-to-do-business-with company.
Del K
Del K is offline   Reply With Quote
Old 11th of April 2001 (Wed)   #3
nllewis
Is the LensMate long enough to accomodate the camera's lens when fully extended? The Canon lens adapter, when fitted with a UV filter, isn't long enough. The only way around it is to add a step-up ring as a spacer to avoid the two from touching each other.
Thanks,
Nancy
nllewis is offline   Reply With Quote
Old 15th of April 2001 (Sun)   #4
Alan
I have the Canon adaptor and have not been aware of any problem with the lens hitting the filter. Have you experienced this actually happening?
Alan
Alan is offline   Reply With Quote
Old 15th of April 2001 (Sun)   #5
Del K
I don't have the Canon adapter. The Lensmate is long enough to have filters clear the end of the lens.
Old 18th of April 2001 (Wed)   #6
nllewis
I went to a local camera shop to buy the canon adapter and a UV filter in order to protect the G1 lens. My brother has a UV filter on his 35mm for protection so I thought this would be good for the G1 too. When the G1 was fully extended it touched the UV filter (barely) but it did touch and I didn't feel comfy with that kind of setup so I purchased a step-up ring for added length. Perhaps this wasn't the best way to go, especially now that I've just heard about the LensMate. I'm a novice so if this wasn't the best way to go, please let me know. Thanks!
Old 26th of April 2001 (Thu)   #7
DeanO
Although my camera doesn't arrive until tomorrow (I'm praying!), I already received my Lensmate. Their customer service rocks! They had it out to me the same day -- and I got it a day later for only $4.50 shipping. It was packed VERY well.
As far as I have heard, the Canon lens adapter obscures the port that the remote talks to for remote shooting, which the Lensmate doesn't. I also read that the Lensmate clears the lens when fully extended. This was what I found when I researched the camera and Lensmate -- but I have NOT actually tested the products yet.
This was a good Lensmate link with lots of info:
http://www.students.tut.fi/~vahonen/...1lensmate.html
DeanO is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Lens adaptor twinx Accessories & Storage 7 17th of February 2007 (Sat) 12:09
Lens adaptor for canon lens on mamiya body zachthephotoguy Canon EF and EF-S Lenses 9 28th of June 2006 (Wed) 03:33
I need help regarding a lens adaptor for my G3 cjsolomon Canon G-series Digital Cameras 7 15th of March 2005 (Tue) 18:43
Lens adaptor for G2 FlyFishNC Canon G-series Digital Cameras 6 29th of January 2004 (Thu) 04:03
Lens Adaptor canonbill Canon G-series Digital Cameras 6 27th of December 2002 (Fri) 03:26
