#1 |
So, after I received the Cotton Carrier system for Christmas, I've come to realize just how much of a pain it is to detach and reattach my camera straps every time I use the CC. Now, being a somewhat poor college student, I didn't want to buy two new straps for my camera, so I went off looking for an alternative solution. In the end, I decided to make my own, using my Canon straps.
All you need are two of Optech's "Adapt Its" ( $3.95 for 4 at B&H http://www.bhphotovideo.com/c/produc...dapt_Its_.html ) and 2 stainless steel quick links (or other fastener of your choice), which can be anywhere from $0.50-1.00 individually, or cheaper in bulk at your local hardware store. I bought my in sets of three at Home Depot for about $1.50. All together, it cost me a little less than $10 to create a quick release system for my Canon straps. First. Attach the adapt-its. They are kind of a pain to put on, you can soak them in hot water to soften them, then use pliers to squeeze them in. Here is a pic of what they look like on my 20d. ![]() Next, attach the quick links (or fastener of your choice) to your existing strap. I attached my strap to the link just like I attach my strap to the camera. Sorry for the slightly oof pics, my nifty fifty is not aware it actually has AF ![]() ![]() Finally, all you need to do is attach the quick links to the adapt-its. ![]() ![]() ![]() And presto! Cheap and easy quick release. My only concern so far has been whether or not the quick links will scratch the body/screen on my 20d, but seeing as it is already a few years old, what's a little more wear and tear? I looked at plastic hooks, especially plastic swivel hooks, but I just couldn't image that they were hardy enough to trust with my camera gear. In reality, I much rather prefer a few surface scratches than watching my camera and glass snap of my neck and shatter on the ground. *shudders* So, just thought I would share my little project, feel free to question or comment. |
| sponsored links |
#2 |
isnt there a carabiner that is rubber coated
#3 |
Great idea, and those Adapt Its seem cool and are reviewed as being exceptionally strong.
Not sure I'd want to use bare metal links, though.
Craig SP 28-80 AD2|SP 60-300 AD2|Soligor 75-260 M42|Soligor 400 T4|Soligor C/D 500 T2 cat|Zuiko 50 1.8|Vivitar 28 2.8 OM|Hanimar 135 3.5 13-blade M42|Even more Manual-Focus Glass Of course I'm all right! Why? What have you heard?!?
| sponsored links |
#4 |
I imagine you could use a little bit of rubbery tape to cover most of the bare metal, one or two layers should keep the scratches away.
Great idea! Could also work with pacsafe straps too as they have quick releases as well.
7D | XSi + Phottix Grip | 400 F/5.6 | 70-200 F/4 | Sigma 30 f/1.4 | Sigma 10-20 f/4-5.6 |430ex | Horusbennu C-2830V | Photo Clam PC-33 flickr gallery |
#5 |
I'm not too concerned about scratches, but I thought a bit of electrical tape would probably work well. I may add some if it bothers me, just haven't gotten around to it yet.
#6 | |
1GRPhotography |
#7 |
I'm a huge fan of DIY and this is an awesome project I like it. I was going to recommend the plastidip as well. I hate having to remove my camera strap it's a pain to say the least. I might have to try this one.
Run it's the big bad amateur GEAR & FEEDBACK Help Support POTN My Blog http://www.hooddesigns.com |
#9 |
I was just trying to figure out a quick release system and this idea looks great.
Would this system also work with a handstrap? I am always going back and forth between hand and neck strap.
1D MKII | 28-80mm 2.8-4.0 L | 80-200MM 2.8 L | 400mm 5.6 L| 50mm 1.4 |
#10 |
Has anyone figured out another way of doing this but without the metal pieces? Are there any other secure plastic pieces that can be used?
l Mario l AE-1P l EOS 5 l 5Dc l 5DII l 17-40L l 35L l 50 1.4 l 100L l 70-200L II l |
#11 |
Why not use the Op-Tech "mini QD loops" instead? Same concept, quick release but without the issue of metal scratching things up.
http://optechusa.com/system-connecto...-qd-loops.html
Canon 50D - - - - - Canon 300D [IR] AF : Tamron 17-50mm f/2.8 | Sigma 30mm f/1.4 MF : Super-Takumar 28mm f/3.5 | Mir-1 37mm f/2.8 | Super-Takumar 50mm f/1.4 | Industar-50 50mm f/3.5 | Petri CC Auto 55mm f/1.8 | Jupiter-9 85mm f/2 | Carenar 135mm f/2.8 | Jupiter-37A 135mm f/3.5 | SMC Takumar 200mm f/4 |
#12 | |
#13 | |
#14 |
There is a post on here where a guy tested the Adapt Its and was unable to break them and as far as the quick links go, I've used all different sizes for everything from tow chains to dorg chains to hanging planters and bird feeders and have never had one of them fail either.
Personally though I would look for a fastener type that allows a quicker release. |
#15 |
Looks like OP/TECH's Utility Loop would keep the carabiner far enough away from the body to prevent scratching... Also, I think the Mini QD Loops are for small P&S cameras...
http://optechusa.com/system-connecto...lity-loop.html |
| Thread Tools | |
| Display Modes | |
| quick release camera strap | tkbslc | Accessories & Storage | 29 | 26th of April 2012 (Thu) 20:24 |
| quick release camera strap? | tkbslc | Accessories & Storage | 3 | 17th of March 2009 (Tue) 19:37 |
| quick release strap | puggle | Accessories & Storage | 7 | 9th of July 2008 (Wed) 00:18 |
| POTN strap quick release?? | DEMO | Accessories & Storage | 8 | 31st of October 2006 (Tue) 13:22 |
