Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography
Reply
Thread Tools Display Modes
Old 12th of March 2010 (Fri)   #1
Eggwhite
Default First home studio, how is muslin hung / used correctly?
Title says it all... I'm trying to setup my first home studio. I want to experiment with portraits and still life studio setting and controlled lighting.
I've purchased background stands and 3 muslins BLACK, WHITE, GREEN. These are 10x13 and wow these are bigger than I was expecting.
What is the correct way to hang these for portrait work? Should they have "bunched pleats" (like room dividers an conventions) or should they be drawn tight with slack collected at one end of the bar? Should the extra at the floor be pulled forward or tucked behind?
Is it really true that these should be balled up in a bag for storage?
I searched for help on this but couldn't find a thread that had the basics.
Much thanks to those who share their knowledge.
Ed
- eggwhite -
The Box --- Canon 5DII, 50D The Glass --- EF 24-70 2.8, EF 28-135 IS USM, EF 70-300 IS USM, EF 50 1.8, EFs 18-55, Tamron SP 17-50 F/2.8 VC.
The Gear --- Manfroto 055xprob Tripod with 322RC2 Head, Canon 580EXII, Sunpak PZ42X Speedlight.
Eggwhite is offline   Reply With Quote
Old 16th of March 2010 (Tue)   #2
Lori Putman
Lori Putman's Avatar
Default Re: First home studio, how is muslin hung / used correctly?
It is more about how you want the backdrop to look. I have been practicing head and shoulder shots recently so I just threw my muslin over the top of the bar and don't even care about the bottom. When I progress to 3/4 length or full body, I intend to have the muslin tight and the excess forward in the front.
Lori Putman
Gear & Feedback
flickr
Lori Putman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
DiscountBulbs or Cowboy Studio Muslin? mdruziak Small Flash and Studio Lighting 1 24th of July 2009 (Fri) 21:45
Paper or Muslin for my backdrop (amateur studio set up) ClickClick Small Flash and Studio Lighting 18 1st of March 2007 (Thu) 13:56
