#1 |
I try to connect the 350 to Apple G5 running OS X 10.4 but the Canon's Camerawindow can't detect the 350.
However, it works find with OS X 10.3. Any solution with 10.4? |
| sponsored links |
#2 |
Have the Mac up and running, have your canon in the OFF posistion, Plug Canon into Mac, and turn the Canon on. This is how I attach my 20D and 1DMKII to both my Macs running 10.4.1 and my Winbloze XP Pro box.
Mike
------------- Canon 1DMKII Canon 20D Canon 10-22, 18-55, 16-35L, 24-70L, 70-200 f4L, 70-200 f2.8L IS, 50 f1.4, 85 f1.2L, 100 f2.8 M/USM, 300 f4L, 400 f5.6L, Bigma. Mac and PC, PhaseOne C1 LE, Photoshop CS2 and FLEXSharp (Which is an Incredible sharpening tool!) And a whole bunch of other stuff... |
#3 |
And just for your info, get a firewire CF card reader. It will download your images in a tenth of the time, compared to hooking direct to the camera.
Mike
| sponsored links |
#4 | |
Which Mac you are using, G3, G4, or G5? |
#5 | |
#6 |
Oh, so you are tethering the Camera to the Mac to view immediately? Know idea, probably a setting is turned off somewhere on the Mac side. Wish I could be of more help. Did you check the Canon website for any upgrades that may have came out for their software?
I'll poke around and see what I can find out. And I have G4s. Mike
#7 |
The following setting is working fine with Camerawindow's remote shooting:
- Win XP, always rock - G3 with 10.3 is OK G5 with 10.41 is not working with Camerawindow's remote shooting. Call Canon tech, and they have not solution so far. |
#8 |
HK,
Have you looked at Image Capture? It is in your applications folder. I read over at DPR that you can use this. I am looking at it right now, but don't know much more then that. It looks like it may be an alternative to view your work in real time. Mike
#9 |
I reinstall the G5 with 10.3 then it works fine. So Canon need to upgade the Camerawindow ASAP.
#10 | |
#11 |
Throw away the preferences in your home folder/Library/Preferences. That will fix the problem 95 % of the time. For many other apps also. If a preference file gets corrupted, many OS X apps simply refuse to go any farther.
Works fine on my G5 with 10.4.1. But I did have it refuse to see my camera. New preference file and all was well. |
#12 |
Are you running OS 10.4? Here is what Canon says about Tiger as of 7/11/05:
"We do not yet have any updates available for Mac OS 10.4. Unfortunately, we do not have any information available regarding when an update will be made. You should be able to download your images using a memory card reader or iPhoto. I apologize for the inconvenience that this causes you. Please write to us again if you have any questions." This means EOS Capture and Camera Window WILL NOT WORK. Imagebrowser and DPP will, though, but you need an alternate way of getting your images loaded. Nice, huh? This whole debacle made me discover PS CS2 and ACR and Bridge. Much better than EOS Capture, etc. Sure would like to be able to remote csapture, though. Last edited by dmwierz : 11th of July 2005 (Mon) at 21:12. |
#13 |
I am using CameraWindow on 10.4 with no problems. Did you do a complete reinstall or just do an upgrade? Make sure that you have the camera set to PTP mode and that the Canon tools installed correctly. The first time I installed them after upgrading to Tiger there was an error and I had to install the individual tools separately.
#14 |
Hello,
I found a way to use CameraWindow with Rebel XT 350D and Tiger 10.4.2 in 'PC Connection' mode and control the camera from my iBook. Here is the procedure I had to modify a configuration file (NEED TO BE ADMIN) 1. go to directory /System/Library/Image Capture/Devices/Type4Camera.app/Contents/Resources/ 2. edit the file DeviceInfo.plist with Textedit or even better with 'Property List Editor' if you have XCode installed. (Admin privileges needed) In the XML tree you must delete : - in the devices section the input for 'Canon EOS 350D' et 'Canon EOS DIGITAL REBEL XT' - in the USB / IOUSBDevice section remove input 38 which is linked to the 'Canon EOS 350D' 3. reboot le Mac Now if you connect your Rebl XT in PC Connection mode you will be able to download pictures from your camera and to use EOS Capture! Have fun. Vox.
PowerMac biG5 2.0GHz - 2.5Gb - OSX Tiger 0.4.2 + iBook G4 1.07GHz - 768Mb - OSX Tiger 10.4.2 iPod Color 60Gb Canon EOS Rebel XT 350D - EFS18-55 - EF 28-135 USM IS + IXUS DIGITAL 400 Last edited by Voxmac : 18th of July 2005 (Mon) at 16:37. |
#15 |
I'm having the same problem. Using MAC OS 10.4 "Tiger" and a 20D with the latest firmware (as well as upgrades to the Utility Viewer and EOS Capture) still results in "can't detect camera" even though I can see the camera icon in the window. What gives?
| Thread Tools | |
| Display Modes | |
| Unresponsive CameraWindow | just spanky | Small Compact Digitals by Canon | 15 | 29th of May 2008 (Thu) 22:21 |
| Camerawindow error | oakmeadows | Canon EOS Digital Cameras | 7 | 1st of January 2008 (Tue) 21:38 |
| Apple Aperture to Smugmug step in work flow? | yoyoboy | RAW, Post Processing and Printing | 2 | 6th of January 2007 (Sat) 16:24 |
| Apple for Photography work? | MrWills | RAW, Post Processing and Printing | 56 | 30th of December 2006 (Sat) 19:01 |
| CameraWindow | MacksQu | Canon EOS Digital Cameras | 12 | 8th of July 2006 (Sat) 08:02 |
