#1 |
I have now used the G1 for about 10 days. I recall when I first used the flash, there was a preflash that occured after I pressed the shutter 1/2 way. Not the red eye reduction that occurs when the shutter is activated. This does not occur now. Is there a specific setting that I have changed, or is the camera malfunctioning?
Also If I am not dreaming that this was actually a function. I assumed that this was setting the flash exposure prior to taking the picture. |
| sponsored links |
#2 |
Hi Ted,
The pre-flash doesn't fire when you press the shutter half way...never did as far as I know! The focus assist lamp will fire though as the camera focuses on the scene. The preflash will happen only after you depress the shutter fully...quite fast depending on the available light. nahau |
#3 |
I must have been dreaming! Thanks nahau
Ted |
| sponsored links |
#4 |
Nahau,
any simple way to use the G1 flash or the 420EX to fire slave flashes that are not meant to accept pre-flashes ? I was looking for a simple electronic schema to either delay, or ignore the pre-flash... wondering also whether the image would be overexposed (the pre-flash won't record the additional lights of the slave flashes). nadim |
#5 |
You will get pre-flash when you press the "*" (AE/AF lock button), not the shutter and of course the flash is on.
Regards, Arturo |
| Thread Tools | |
| Display Modes | |
| A540: can you set it so it does not preflash? | picturecrazy | Small Compact Digitals by Canon | 3 | 14th of February 2007 (Wed) 14:44 |
| 580EX preflash | mikey707 | Small Flash and Studio Lighting | 4 | 9th of November 2006 (Thu) 22:29 |
| 580ex preflash | jkeo52 | Small Flash and Studio Lighting | 10 | 13th of November 2005 (Sun) 08:37 |
| E-TTL preflash | wintoid | Canon EOS Digital Cameras | 16 | 31st of March 2004 (Wed) 14:23 |
| G1 & 420EX preflash problem | danielchtong | Canon G-series Digital Cameras | 1 | 14th of December 2001 (Fri) 19:04 |
