Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 8th of March 2003 (Sat)   #1
LittleG.
LittleG.'s Avatar
Default D60 & infrared
Is the D60 suitable for infrared shooting? Has anybody tried it, and how did they go about it? What were the results like? I am hoping to acquire a hoya R72 but do not know if I need anything else, or whether I should just forget it.
Happy Daze!
http://www.photo-art-gallery.com
LittleG. is offline   Reply With Quote
Old 9th of March 2003 (Sun)   #2
R055
Default Re: D60 & infrared
D60 is not very good for IR. it has a IR filter. most digital cams do. sony f707 is good for IR cuz you can flip the IR filter up by using the nightshot mode.
R055 is offline   Reply With Quote
Old 10th of March 2003 (Mon)   #3
Longwatcher
obsolete as of this post
Longwatcher's Avatar
This is not completely correct, the CMOS chip on the D60 itself does not record in the infrared portion of the spectrum. Or at least not far enough into it to make a difference.
From my research the Sony F7*7 series cameras mentioned are the best consumer digital cameras for IR. I am considering getting a F717 myself just to play with the IR capabilties. Alternatively there are some surveillance type systems that will mount to camera bodies that have even more IR spectral range, but tend to have less overall resolution. I can't remember right now which camera bodies they mount to, but I remember they are not the Canon body.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher.com/photoequipment.htm
Longwatcher is offline   Reply With Quote
Old 10th of March 2003 (Mon)   #4
LittleG.
LittleG.'s Avatar
Ah, bad news then since my camera is canon D60 with canon lenses. Maybe I will take IR into consideration if I ever invest in a new system. Thanks for the feedback anyway.
Happy Daze!
Old 28th of May 2003 (Wed)   #5
jens1204@earthlink.net
If you have photoshop there is a way to fake infrared using images from the d60 or any camera. I read about it in a magazine a while back and it works pretty well. Just go to the channels pallete and click on the green channel. Then go to the filter menu and choose gaussian blur and blur as much as you like. Then go to the image menu and choose adjust hue/ saturation and slide your saturation down to 0.
jens1204@earthlink.net is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Rebel xti/xt vs. D60 for Infrared? ve7clj Canon EOS Digital Cameras 2 29th of January 2007 (Mon) 14:32
Canon D60 for B&W and Infrared Photography shamrock838 Canon EOS Digital Cameras 1 22nd of June 2005 (Wed) 11:19
Infrared Photos with D60 Ellis Zacharias Canon EOS Digital Cameras 5 20th of December 2002 (Fri) 04:48
Simulate Infrared on D60 gorham Canon EOS Digital Cameras 0 31st of July 2002 (Wed) 13:16
D60 & InfraRed MrGarcia Canon EOS Digital Cameras 3 3rd of May 2002 (Fri) 13:46
