Reply
Thread Tools Display Modes
Old 13th of July 2005 (Wed)   #1
Candi lynn
Question What makes a fast lens a fast lens?
Lenses are really starting to confuse me! I understand the focal length of a lens and the maximum aperture of a lens, but when people talk about a fast lens what number are they talking about. Or is is even a number? What makes a fast lens a fast lens? And when a lens has USM, does that mean it is quieter? Sorry for so many dumb questions all at once.
Candi
Candi lynn is offline   Reply With Quote
Old 13th of July 2005 (Wed)   #2
blue_max
blue_max's Avatar
Default Re: What makes a fast lens a fast lens?
In essence, lots and lots of glass!
A really big hole for the light to travel through. Simple as that. USM is the focussing mechanism and has nothing to do with it, although having it can make it quicker to focus.
Graham
Lamb dressed as mutton.
blue_max is offline   Reply With Quote
Old 13th of July 2005 (Wed)   #3
AjP
AjP's Avatar
aperture (bigger is better 1.4, 2.8...), quiality of glass, motor..... L
more light comoing through, faster lense see the point of focus the rest up to mecanical stuff
"Photography takes an instant out of time, altering life by holding it still."
AjP Photography | SportsShooter | WPJA Member
AjP is offline   Reply With Quote
Old 13th of July 2005 (Wed)   #4
Keiffer
Keiffer's Avatar
Normally a fast lense is 2.8 or below. A wide aperature allows for a "faster" shutter speed in turn allowing you to shoot in low light and also handhold instead of using a tripod.
USM is quieter but also faster focusing.
No such thing as a dumb question, That's what everyone is here for, the exchange of information and ideas.
Oh yeah, Welcome to the forum
http://kcschoeppler.fotopic.net
Keiffer is offline   Reply With Quote
Old 13th of July 2005 (Wed)   #5
ddelallata
ddelallata's Avatar
Fast refers to the Aperture. ex (f/2.8 ) etc. I would say that fast is any number lower than f/2.8 .
the lower the f/number the faster the shutter speed. this allows the light to record the image on the sensore faster.
Dr. David de la Llata
_____________
Canon 20D
BG-E2 Battery Grip
Canon SpeedLite 430 EX
Canon EF 1.4X II
Canon EF-S 10-22mm F/3.5-4.5 USM
Canon EF 50mm F/1.4 USM
Canon EF 100mm F/2.8 MACRO USM
Canon EF 24-70mm F/2.8 L USM
Canon EF 70-200mm F/2.8 L USM
Olympus C-2020 (for infrared work)
ddelallata is offline   Reply With Quote
Old 13th of July 2005 (Wed)   #6
ayotnoms
Perfect Anti-Cloning Argument
ayotnoms's Avatar
It usually refers to lens performance in low light conditions
f/1.2 = Fast
f/5.6 = Slow...at least compared to the f/1.2
Allowing more light through the lens means faster shutter speeds while still getting an acceptable exposure.
...the Cliff Notes version.
Steve
Gear
ayotnoms is offline   Reply With Quote
Old 13th of July 2005 (Wed)   #7
gasrocks
gasrocks's Avatar
Fast and Slow are relative terms. What was fast years ago is probably slow now. What is fast for an 8X10 camera is slow for a 35mm camera. F/8 is faster than F/11 but slower than F/5.6. I see people complain about their f/4 lens not being fast - sigh, you can tell they aren't very old. Not too long ago f/4 was fast. Get the fastest lenses you can afford - is the real answer.
gasrocks is offline   Reply With Quote
Old 13th of July 2005 (Wed)   #8
CorruptedPhotographer
CorruptedPhotographer's Avatar
I also h ad this Q in mind, so an aperture of 2.8 or below is considered a fast lens, allowing for faster shutter speeds and hand held shooting. But when would you really need an aperture of 2.8 or below? Isnt the DOF going to be very minimal? Woulndt using an aperture of between f/4 and f/8 the best?
Member since 2005 ^_^
CorruptedPhotographer is offline   Reply With Quote
Old 13th of July 2005 (Wed)   #9
Keiffer
Keiffer's Avatar
When your in low light your choices are limited. F4 or 8 would be great for outdoors, not indoors.
Old 13th of July 2005 (Wed)   #10
ayotnoms
ayotnoms's Avatar
Huh?
The FD mount lens that came with my Canon-AE1 25 years ago was an F/1.8
I'm fairly certain that fast lenses in the sub-f/2.8 range have been around for long time and f/4 was as slow then as it is now--for some circumstances, of course.
discuss amongst yourselves....
Steve
Gear
Old 13th of July 2005 (Wed)   #11
Candi lynn
So the L means better quality of lens right? And if i was shooting a picture at let say an f-stop of 8 (outside) then the 2.8 lens would/not matter?
Old 13th of July 2005 (Wed)   #12
ayotnoms
ayotnoms's Avatar
It depends.
If I'm using a long focal length lens to photograph a baseball pitcher from a good distance, the F/2.8 may allow me the shutter speed I need to freeze his/her arm motion; and at that distance, the f/2.8 will still allow for an acceptable Depth of Field.
Someone here at in the POTN forum used the phrase "The Trinity" to describe the components of a good photograph; Focal Length, Aperture, and Shutter Speed.
Check out the Stickies at the top of this forum. There are tons of reference/resource sites where you can learn of other factors such DoF, FOVCF, etc.
Cheers
Steve
Gear
Old 13th of July 2005 (Wed)   #13
blue_max
blue_max's Avatar
The L moniker refers to the professional range. It has met certain quality standards that generally exceed those of the consumer range. A faster lens will give you the option of shooting at a faster speed. It is not compulsary! If you always shot at f8 for example, there might not be such an advantage in using an L lens. Other factors such as saturation and detail may still make the image better with an L though.
Graham
Old 13th of July 2005 (Wed)   #14
SkipD
SkipD's Avatar
You are correct in understanding that if you are shooting in bright light where f8 is your normal setting there would be little advantage in a "fast" lens. BUT..... There are other characteristics that the "fast" lenses often have. Many are of the "professional" caliber, such as Canon's L series lenses, and that brings with it a number of things.
Typically the sharpness, contrast, and color of images produced with the professional grade lenses will be better than those made with a cheapie lens. The physical build and handling properties are usually better as well. Are these factors worth the (usually) significant price difference? That's something you will have to decide. There are also many middle-of-the-road lenses that are much better than the cheapies and not quite as good - when considering all the variables - as the professional grade lenses.
Bottom line - huge maximum aperture alone is not the only measure of a great lens. There are many variables to consider. Keep on reading here and elsewhere and keep on asking the questions. That's the only way to be able to make an intelligent decision that you'll be happy with when it comes to buying glass for your cameras.
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 13th of July 2005 (Wed)   #15
Candi lynn
Thanks for all the help. I'm sure i will have more questions furture on down the road.
candi
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Fast lens??? Kiddo Canon EF and EF-S Lenses 7 23rd of June 2007 (Sat) 22:02
Lens too fast???????? tinpusher General Photography Talk 20 28th of May 2006 (Sun) 10:43
When do I need a FAST lens? stangster Canon EF and EF-S Lenses 10 26th of April 2006 (Wed) 07:18
A Fast Lens? - The 17-40 Wazza Canon EF and EF-S Lenses 4 4th of January 2006 (Wed) 18:07
Fast Lens vs. Slow(er) Lens - Benefits of Flash??? Glen Blanchard Small Flash and Studio Lighting 5 23rd of November 2005 (Wed) 14:41
