Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 21st of April 2010 (Wed)   #1
racketman
racketman's Avatar
Default pricey MT-24 adaptor for new 100mm L lens
£32 for a step up adaptor ring - are they serious?
Canon 67c
Toby
Flickr collections
ipernity gallery
Gear
racketman is offline   Reply With Quote
Old 21st of April 2010 (Wed)   #2
themadman
themadman's Avatar
Default Re: pricey MT-24 adaptor for new 100mm L lens
By putting the name Canon on it, you elevate a small piece of aluminum or whatever it is to it's worth it's weight in gold!
Will | WilliamLiuPhotography.com | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
themadman is offline   Reply With Quote
Old 22nd of April 2010 (Thu)   #3
LordV
LordV's Avatar
Would a 67 to 58mm stepdown ring work ?
Brian v.
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is online now   Reply With Quote
Old 4th of May 2010 (Tue)   #4
ben_r_
-POTN's Three legged Support-
ben_r_'s Avatar
Brian v.
No because the MT-24 doesnt screw into a filter threading, but rather that macrolite adaptor give a proprietary lip that protrudes out that the MT-24 attaches to.
[ Gear List | Flickr | My Reviews ] /|\ Tripod Leg Protection /|\
ben_r_ is offline   Reply With Quote
Old 4th of May 2010 (Tue)   #5
LordV
LordV's Avatar
I was assuming you could then use the 58mm macrolite adapter it comes with ?
Brian v.
Old 6th of May 2010 (Thu)   #6
ben_r_
ben_r_'s Avatar
Brian v.
It doesnt come with one. The 100L uses the Canon MacroLite 67 which you have to buy separately for around $40. LINK
It is also not a 58mm filter size, but rather a 67mm.
Old 8th of May 2010 (Sat)   #7
Hodge
I think the price of the adapter sucks for what it is
I made my own, using a 67mm - 58mm stepdown ring, as mentioned earlier
then I screwed an old 58mm UV filter ring (minus glass) & an "A" series cokin adapter into it,
this has a nice groove that the locking pins on the MT24 can locate into, works with the MR14 as well
Bryan
Hodge is offline   Reply With Quote
Old 11th of May 2010 (Tue)   #8
orionmystery
orionmystery's Avatar
yeah...ridiculously pricey. I had to buy one for my Sigma 150 too...macrolite 72C.
Got mine from ebay. Not genuine and the fitting is a bit loose. After snapping the adapter on, it could still rotate a bit
Kurt, 40D, MP-E65 & MT-24EX for full flash, Sigma 150 +1.4x TC for natural light.
My Macro Rig
orionmystery is offline   Reply With Quote
Old 12th of May 2010 (Wed)   #9
harcosparky
I just ordered one for my flash ( MR-14EX ) from B&H.
Pricey?
Sure, but I realize Canon doesn't sell a lot of these flash units as compared to others and probably even less of the adapter rings.
harcosparky is offline   Reply With Quote
Old 13th of May 2010 (Thu)   #10
Cham_001
Cham_001's Avatar
Canon 67c
I've done a search, the cheapest I came across is at Amazon USA:
http://www.amazon.com/Canon-Macrolit.../dp/B002O3UOUW
$37.02 (equivalent to approx £22.00) - factor in the postage and it is about the same price.
Seems as though this is the going rate! - As others have pointed out, it is a rather specialist (non-commercial) item which is keeping the price high.
There may be cheaper alternatives out there, just beware of the quality of the threading.
"..with a clear perspective - the confusion is clearer.."
40D body, 580ex II x 2, MT24 macro flash, EF-S 10-22mm, 100 f2.8 macro, 50mm 1.8 II Pkt Wiz TT5 x 2, Sekonic L-758DR - 04/11/2011 = Camerisation Consultant
Cham_001 is offline   Reply With Quote
Old 13th of May 2010 (Thu)   #11
ben_r_
ben_r_'s Avatar
Yea Amazon is where I bought the one I had from. Overpriced indeed, but I wouldnt trust anything other than the official Canon version personally.
Old 14th of May 2010 (Fri)   #12
K2Stoneman
K2Stoneman's Avatar
Am wondering, since I already bought the 72mm adapter, if there is any reason a 67-72mm step-up ring wouldn't work (i.e., 67mm step-up adapter on the lens, the step-up adapter to the 72 adapter, to my MT-24EX)?
Given the focal length is 100mm on the "L", wouldn't think vignetting would be any problem.
Anyone agree / diagree / have a PoV to share?
Thnx
K2Stoneman is offline   Reply With Quote
Old 17th of May 2010 (Mon)   #13
ben_r_
ben_r_'s Avatar
Thnx
Yea usually the stepup rings are very thin and keep the filter as close to the lens as possible, I think you should be fine doing it that way, its just going to look a little funny because your lens will have a flare out from the step ring at the end.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Adaptor 67 for New 100mm IS USM Macro Ray.Petri Canon EF and EF-S Lenses 0 7th of September 2009 (Mon) 10:00
If the MkIII seems a bit pricey to some...try this... westernminnguy General Photography Talk 27 8th of May 2007 (Tue) 13:39
pricey filters, for each lens?? smasraum Canon EF and EF-S Lenses 24 4th of January 2007 (Thu) 08:35
Lens adaptor for canon lens on mamiya body zachthephotoguy Canon EF and EF-S Lenses 9 28th of June 2006 (Wed) 03:33
Good zoom lens that's not as pricey as the L series lenses? FlipsidE Canon EF and EF-S Lenses 19 22nd of October 2004 (Fri) 19:54
