Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 25th of April 2010 (Sun)   #1
picard
picard's Avatar
Question is it necessary to use a softbox when shooting macro ?
When is the softbox used during the day ?
What flash setting should the 430 EX II be calibrate to ?
picard is offline   Reply With Quote
Old 25th of April 2010 (Sun)   #2
LordV
LordV's Avatar
Default Re: is it necessary to use a softbox when shooting macro ?
I'll try to answer your questions
#1 - not a necessity, depends on what type of shot you want to achieve but a naked flash as the main light source gives a high contrast image similar to shooting in bright sunlight with lots of specular reflections
#2 If you are using flash as the main light source and doing shooting at 1:1 or higher magnification then yes. A bit more debatable for lower magnification shots or just using the flash for a fill effect (ie most of the light is natural). Odd as it may seem , in strong sun I often try to shade subjects so that the flash is the major light source, with a good diffuser the result is much softer light.
#3 I just use the flash in ETTL mode for both full flash shots (camera in manual 1/200th ISO 100, say F11) or Tv or Av shots. You need to get used to adjusting FEC though in scenes where the brightness/darkenss will fool the exposure. eg small subject against a dark or no close background needs negative FEC and vice versa for a subject on a bright /light background.
Brian v.
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Which softbox should I get for macro pictures? minh2pac Macro Talk 7 23rd of December 2009 (Wed) 15:03
Using softbox for outdoor shooting FullStop Photography Small Flash and Studio Lighting 4 6th of June 2009 (Sat) 22:27
WTB: Canon 100mm f2.8 Macro and AB800 + Giant Softbox AndreaBFS Classifieds: Buy 9 19th of January 2009 (Mon) 02:38
folks i need to make a quick softbox or method for shooting some small packages TRM Small Flash and Studio Lighting 2 5th of March 2008 (Wed) 18:57
My DIY Softbox for Macro photography, with Ant pic! jlw82 Macro 1 9th of April 2007 (Mon) 10:25
