Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 19th of July 2005 (Tue)   #1
Curtis N
Master Flasher
Curtis N's Avatar
Default Comparisons of metering modes - an eye opener!
Credit goes to PhotosGuy (Frank C) for the M&Ms idea, which I have shamelessly stolen. A variety of colors, and most everyone knows what they should look like. I added white tic tacs and black licorice to maximize the color gamut.
The idea was to see how the various metering modes on the 300D would read various combinations of colors. Rather than bore you with my conclusions, I'll just tell you how I set this up and let you discuss.
The 300D has three metering modes:
35 Zone Evaluative Metering, the default metering in every shooting mode except Manual. For these shots, I used Av mode at f/8 and let the camera choose the shutter speed. Edit for clarification per discussion and testing later in this thread: All shots were taken in autofocus mode with the center AF point selected. Evaluative metering is weighted according to the active AF point in autofocus mode. In manual focus mode, it is apparently centerweighted, regardless of the active AF point.
Centerweighted Average Metering, the default metering in Manual mode. I set the aperture at f/8 and adjusted the shutter speed to put the exposure indicator needle dead-center.
Partial Metering, which is activated by the AE Lock (*) button, uses a center area comprising about 9% of the frame. These were taken in Av mode at f/8, just like the Evaluative Metering shots.
Before you look at the pictures, you need to understand two vital points. First, every single shot was metered according to what the camera considered to be the "correct" exposure. There was no exposure compensation, no post-processing adjustments. What you see is what I got.
Secondly, the same pieces of candy were used in every shot. I simply rearranged them and tried to keep every piece at least partially in the frame. I did not substitute dark ones for lighter ones or vice-versa.
Every image below is from the same lens at the same distance with the same lighting. I did not move the camera or the light. Every shot was at f/8 and ISO 100. Only the shutter speed was changed via the metering methods described above. Nothing has been cropped. These are full-frame images shot RAW with custom white balance, converted and resized to 260 x 390. No sharpening, no adjustments to hue, saturation, etc., etc.
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 19th of July 2005 (Tue)   #2
Curtis N
Master Flasher
Curtis N's Avatar
Default Re: Comparisons of metering modes - an eye opener!
The same M&Ms, tic tacs & licorice pieces, just rearranged.
Old 19th of July 2005 (Tue)   #3
PhotosGuy
Moderator
PhotosGuy's Avatar
Good job, Curtis! If this doesn't convince some people to try using "M", then I don't know what will!
Maybe someday the geek at Canon who programs the meter software will figure a way to compensate, but until then I'll carry a white sheet of paper in my pocket & shoot RAW!
I'm going to add a link to this in my "Gray Card" threads.
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 19th of July 2005 (Tue)   #4
jfrancho
jfrancho's Avatar
All the m&m's are making me hungry! Nice test, Curtis.
jfrancho is offline   Reply With Quote
Old 19th of July 2005 (Tue)   #5
Sathi
Sathi's Avatar
Thank you for doing this test. Very interesting.
20d / Tamron 28-75 2.8 / Canon 10-22 / Canon 100mm macro
Sathi is offline   Reply With Quote
Old 19th of July 2005 (Tue)   #6
Curtis N
Master Flasher
Curtis N's Avatar
Thanks, Frank. It was amazing to me how just rearranging the same colors changed the metering by a factor of ten in terms of shutter duration, about 3 1/3 stops! I was also surprised by how much the evaluative metering seems to be "center weighted." This could be quite problematic for those who try to follow the rule of thirds and compose with their subject off-center.
When I get a chance I will try to shoot some "real world" examples, like people in dark clothing in front of a bright background or vice-versa. This has really arroused my curiosity.
I think there are several lessons that could be learned from this. Anyone who shoots in JPEG mode with auto white balance really needs to see that first gray card shot.
Old 19th of July 2005 (Tue)   #7
AjP
AjP's Avatar
Great Job Curtis!!!!!!!!!!!!!!!!!!!!!!!!!!
"Photography takes an instant out of time, altering life by holding it still."
AjP Photography | SportsShooter | WPJA Member
AjP is offline   Reply With Quote
Old 19th of July 2005 (Tue)   #8
jfrancho
jfrancho's Avatar
I have always used the "white-gray-black" card included as a pullout in the Kelby book. I assume that is sufficient? I don't think I have any problems, but if there is a better way....
Old 19th of July 2005 (Tue)   #9
PhotosGuy
Moderator
PhotosGuy's Avatar
I don't see where it wouldn't work the same. Except that I'd always have to carry the book. I can get white (enough) paper anywhere, & it comes in handy for taking notes, too.
Why did you think I started using them? Tax deductible, too!
By now, most of you know that I don't like having the cam "evaluate" anything for me & interpret the results. I make enough misTaKes of my own without compounding them with those with what I'd call a false evaluation.
YES, you can learn how to set up the cam to compensate. So you're compensating for the compensation? I want to spend my time looking at the subject & free up my brain to look for possibilities & think of variations & see what's happening in the background & forground & is this a better angle & maybe try for less DOF &... &... &..., Get the idea?
Manual settings work for me. When they don't, it's because I screwed up, & RAW will usually save me (again). There's too much going up in my brain to wonder what the cam is thinking THIS time. I want it to do JUST what I tell it to do. No more. No less.
www.FrankCizek.com
Old 19th of July 2005 (Tue)   #10
Curtis N
Master Flasher
Curtis N's Avatar
I'm curious how the three colors are arranged on the card. Are they like three pieces of pie meeting in the center, or are they side-by-side? The shots above seem to indicate that would make a difference.
Old 19th of July 2005 (Tue)   #11
jfrancho
jfrancho's Avatar
Side by side. But it is only really useful as a WB tool or metering close ups, since it is so small.
Old 19th of July 2005 (Tue)   #12
Tom W
Canon Fanosapien
Tom W's Avatar
Unless you have spot metering.
This thread is driving me to give manual a workout - I used to shoot manual by necessity with nothing but a center-weighted match-needle light meter built into my FT-QL. I would meter around the scene a bit and get a good educated guess at what I wanted to be right. More recently, I've gotten spoiled by auto-exposure, I guess.
Tom
5D III, 7D, & various lenses
Tom W is offline   Reply With Quote
Old 19th of July 2005 (Tue)   #13
Curtis N
Master Flasher
Curtis N's Avatar
Auto exposure doesn't spoil me, it frustrates the bejeebers out of me. If it weren't for being able to adjust the RAW images later, 90% of my shots would be crap.
I haven't carried a gray card with me yet, but I have learned to find neutral targets to meter on. Since we haven't had any rain this summer, there's always brown grass around somewhere. I've also used old (not new) blacktop and brick walls if they're not too dark. This isn't a perfect solution but it gets me a lot closer than auto metering most of the time.
Old 19th of July 2005 (Tue)   #14
PhotosGuy
Moderator
PhotosGuy's Avatar
...but I have learned to find neutral targets to meter on.
I've done that. Green grass & blue sky can work too, but here's a bit of trivia: The palm of your hand doesn't tan! So it's always the same tone. Take a reading of it & figure out the appropriate compensation & you'll always have something to use for a reading. Not too hot for WB, though.
EDIT to update my palm of your hand comment: Manual exposure the quick & easy way.
First set the f-stop & shutter speed you need. Then adjust the ISO.
Need an exposure crutch?
www.FrankCizek.com
Old 19th of July 2005 (Tue)   #15
jfrancho
jfrancho's Avatar
I hear it get hairy, though.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Eye Opener SoaringUSAEagle Small Flash and Studio Lighting 7 20th of January 2007 (Sat) 23:06
The MP-E65, A Real Eye-Opener!! Bald Eagle Macro 11 2nd of January 2007 (Tue) 22:48
Understanding metering and metering modes. Some help please? TMR Design Canon EOS Digital Cameras 3 21st of October 2006 (Sat) 23:49
Dodgy 20D Grips - An Eye Opener Inspired Photography Accessories & Storage 7 24th of September 2006 (Sun) 22:07
Eye Opener Freff Canon EF and EF-S Lenses 9 10th of November 2005 (Thu) 02:10
