#1 |
Hi,
I want next week to buy a macro lens, I state that I have no experience in macro photo but my choice fell on these two lens: - Sigma EX 180mm f/3.5 APO DG Macro - Macro Canon EF 100mm f/2.8L IS USM could you recommend a lens? Tnx __________________________________________________ __________________________________________________ ________________________________________________ CANON 5D Mark II | BG-E6 | SIGMA 12-24 f/4.5-5.6 DG | Canon EF 24-70 f/2.8 L | Flash Speedlite 580EX II | Manfrotto 055MF4+488RC2 | Canon PIXMA PRO9500| Canon EF 1.4X II Extender __________________________________________________ __________________________________________________ ________________________________________________ Last edited by mave1976 : 1st of May 2010 (Sat) at 03:40. |
| sponsored links |
#2 |
I am not a pro by any means, but I had the same quandary as you a few months ago. I tried my friends canon 100 mm macro lens, had no real problems with it, thought it was easy. So i figured i would get the sigma 180 f/3.5 APO DG Macro and that it would be easy to use. Wrong!!! It is a somewhat harder to use than the 100 mm. I found it harder to hold still because it is a lot longer than the canon 100mm. Also for me it is harder to get the correct focal point than with the canon. I would recommend that you get the 100mm first, then if you are successful go for the Sigma 180. LordV seems to be the macro guy around here, so check his Macro thread for ideas:
http://photography-on-the.net/forum/...d.php?t=807056 Of course this all depends on your skill level and seeing as you have a Canon 5D Mark II I would guess you have a good to pro skill level. The 180 can take beautiful pictures in the correct hands. Hope this helps, AcidBurn003
Canon EOS 50D, 18-200mm Kit lens, Sigma 180mm Macro, Sigma 150-500. |
| Thread Tools | |
| Display Modes | |
| help me choose! (macro lens options) | bakatari | Macro Talk | 2 | 27th of January 2009 (Tue) 00:14 |
| Macro Photography...Help me choose the right Lens to compliment my Canon 17-55 f/2.8 | oak3x | Canon EF and EF-S Lenses | 18 | 2nd of February 2008 (Sat) 12:52 |
| Macro lens choices: why choose 60mm ef-s over 100mm ef | JoeW | Canon EF and EF-S Lenses | 15 | 8th of October 2007 (Mon) 14:48 |
| If you could choose your lens set from the very beginning WHAT WOULD YOU CHOOSE? | Cool-cat | Canon EF and EF-S Lenses | 67 | 23rd of December 2006 (Sat) 08:15 |
| Help needed to choose a macro lens | Radioham | Macro | 5 | 24th of July 2005 (Sun) 12:58 |
