Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 9th of May 2010 (Sun)   #1
bonaccord
Default Battery charging abroad
My Ixus camera uses NB-4L batteries and a Canon battery charger. My question is this.
Can I safely recharge these batteries in France using a simple socket plug adapter to enable the charger's standard 3-pin plug to be inserted? And if so, will charging take longer? Thanks for advice.
bonaccord is offline   Reply With Quote
Old 9th of May 2010 (Sun)   #2
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Default Re: Battery charging abroad
Yes. If you look at the charger, you'll see it says "100-240V 50-60 Hz", so essentially anywhere in the world. Charging will take about the same time.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 9th of May 2010 (Sun)   #3
Ronin1
I just got back from France and as stated above it will work. I did find though that if I used the aftermarket charger for my G10 it would not charge even though it stated it should work. The Canon Charger for my other camera worked just fine. So if you have an aftermarket charger just a caution that it may not work.
Ronin1 is offline   Reply With Quote
Old 9th of May 2010 (Sun)   #4
JRET
Yes, I was in France last November and had no problem charging the same battery type using the Canon charger. All you need is a plug adapter.
Canon S-90 | 50D | 28 f/1.8 | 40 f/2.8 | 50 f/1.4 | 85 f/1.8 | 12-24 f/4 | 24-85 f/3.5-4.5 | 24-105 f/4 IS | 70-200 f/4 IS | 430EX
JRET is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US G9 Battery charging in UK colinm85 Canon G-series Digital Cameras 3 16th of May 2008 (Fri) 17:05
Battery Charging in the UK b.d.bop Accessories & Storage 12 5th of April 2008 (Sat) 18:34
Battery charging Orange88 Canon EOS Digital Cameras 3 13th of October 2007 (Sat) 09:51
Battery charging dennisk Small Compact Digitals by Canon 4 3rd of August 2005 (Wed) 21:12
