#1 |
After my camera and tripod blew over in the wind, I escaped with only a scratch on my filter, but it's quite bad and shows in the image.
Is there an easy way of buffing it out?
Photos from Iceland | Lake District | Isle of Lewis | Japan | Macros Canon EOS 40D | Canon 17-55mm f/2.8 IS | Canon 100mm f/2.8L Macro IS | Canon 70-200mm f/4L | Speedlite 430EX II | Canon Powershot G9 |
| sponsored links |
#2 |
How the heck did the wind blow your gear over? What is your tripod made out of, wood? Anyway, back to the question, if it is in the ND part then no you can't get the scratch out because it is a coating. If it is on the clear part then you can probably buff it put with the right equipment.
Take Care, Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS Click Here To See My Gear Click here to see my Flickr |
#3 |
The Lee filters are resin, correct? Depending on how deep the scratch is, you might have a hard time polishing it out. You may want to try some plastic polish anyway. I use Meguiar's Plast-X on the headlights and taillights on my Lincoln. It contains a small amount of abrasive to clear the plastic, but it may not work with a really deep scratch. You can get this stuff online at Amazon.com, or at Walmart or a good auto parts store. It works great on clear plastics, but I don't know how it will affect your ND filter overall -- I've never tried it on a filter before. Good luck.
http://www.meguiarsdirect.com/produc...?T1=MEG+G12310 |
| sponsored links |
#4 | |
#5 | |
#6 |
No it's a Manfrotto 190, but if you're in 50mph winds it doesn't matter what tripod you have.
#7 |
In very windy conditions, I make it a point to keep my camera strap around my neck while the camera is on the tripod.
"Fat, drunk and stupid is no way to go through life, son". - Dean Wormer GEAR LIST |
#8 |
I wasn't standing by the tripod, I turned around for a second to get something from my bag. In hindsight I should have released the camera from the head. I've also heard that hanging something heavy from the centre column can help, although that too may induce movement as it's blown in the wind.
| Thread Tools | |
| Display Modes | |
| WTB: Reverse Grad filter by Singh Ray - or regular grad NDs by Singh Ray | Needsnow | Classifieds: Buy | 0 | 9th of March 2010 (Tue) 12:29 |
| scratch on filter? what to do? | dmo580 | Canon EF and EF-S Lenses | 7 | 18th of December 2009 (Fri) 08:55 |
| WTB: B+W Grad ND filter and B+W CPL filter (77mm only) | jubu | Classifieds: Buy | 0 | 10th of December 2009 (Thu) 22:39 |
| What is your most used grad ND filter? | texshooter | Accessories & Storage | 10 | 23rd of September 2009 (Wed) 15:39 |
| Scratch on polarizer filter... | relux | Accessories & Storage | 5 | 31st of July 2007 (Tue) 09:54 |
