#1 |
Dear All,
I like to practice to make a shot like this/attached : (picture taken from www.axioo.com ) i have the radio transmitter (no TTL) and 430ex flash my questions: 1.how i set up my camera 50D 2.and how i set up my flash 430 ex 3. is adiffuser/ umbrella is a must?? thx hiri |
| sponsored links |
#2 |
Hiri, I am no expert but here is what I will do:
1. Set you camera in manual exposure mode to get the back ground the way you like. 2. Then use your flash off camera for the subjects. You can use bare flash, or with umbrella/softbox. You can increase/decrease flash power to get proper subject exposure.
Back to basics 5dc with 35L & Sigma 85mm f1.4 |
#3 |
yeah, just remember your setting 2 exposures.
1- ambient - use the camera meter to determine the background exposure 2- subject - flash will determine this exposure
| sponsored links |
#4 | |
#5 |
The image was shot just before sunset facing southwest on the Michigan Ave Bridge over the Chicago River. It looks like the ambient exposure was just about on and then the flash was used to light the subjects. Maybe +1/3 or +2/3 FEC if in TTL.
If manual flash then it is probably 1/4 to 1/8 power and relatively close to the subjects. Since there is no flash over exposure on the bridge railing, I suspect that the flash was off camera and snooted. Hard shadow under her arm implies direct flash without umbrella or other modifier.
David | digifotografi tutorials | dmwfotos website | testing & techniques blog Canon ETTL trigger sets for sale | Canon 300mm F4 IS L for sale Last edited by dmward : 27th of May 2010 (Thu) at 11:10. |
#6 |
You should link to that photo rather than post if if it belongs to someone else. Forum rules.
The advice you are getting here is good. Use the camera in manual mode to expose the background as you wish, a couple stops less than normal for dramatic effect, then ajust flash power to illuminate the subject properly. |
#7 |
When you have time you may want to read this thread.
http://photography-on-the.net/forum/...d.php?t=653964 It is the best 'all in one' source I have found ... and the examples are incredible. |
#8 |
I guess the thing to remember, with off-camera flash that you are suggesting, is to not go above the synch speed of your camera.
| Thread Tools | |
| Display Modes | |
| Off Camera flash question | fotojoem | Small Flash and Studio Lighting | 3 | 6th of February 2010 (Sat) 22:42 |
| On-camera flash question | Canonboi | Small Flash and Studio Lighting | 17 | 3rd of February 2010 (Wed) 17:29 |
| 30D, On Camera Flash question | oldom | Canon EOS Digital Cameras | 26 | 23rd of April 2009 (Thu) 11:02 |
| Question about off camera flash | umphotography | Small Flash and Studio Lighting | 6 | 12th of December 2008 (Fri) 14:37 |
| E-TTL II question -> is it the flash or the camera? | kafene | Canon EOS Digital Cameras | 1 | 4th of April 2004 (Sun) 18:21 |
