Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 27th of May 2010 (Thu)   #1
protest42
protest42's Avatar
Default Help please?
So I could really use some help, I'm really new to flashes. I got to shoot some skating and I can't figure out how to expose the background more, everything I tried would blow out the skater. I have searched and from what I've seen I should set up what I want the background to look like without flash and then bring in the flash once I have the background dialed? I could totally be wrong, any help would be great. thanks in advance
50D
protest42 is offline   Reply With Quote
Old 27th of May 2010 (Thu)   #2
theextremist04
theextremist04's Avatar
Default Re: Help please?
Use a longer shutter speed or add more strobes. WIth sports it's really tricky, as the conventional "dragging the shutter" (longer exposure) doesn't work too well.
-Michael
Gear - Flickr - Website - Facebook
theextremist04 is offline   Reply With Quote
Old 27th of May 2010 (Thu)   #3
SMBPhotography
SMBPhotography's Avatar
Photoshop.
Steve
Gripped 30D, Gripped 7D, G9, 24-70L F2.8, 100-400L F4.5-5.6, 50mm 1.8, 18-135mm 3.5-4.6, 430EXII and a whole bunch of other stuff.
I'm no Jay Beckman but I did sleep at a Holiday Inn last night.
SMBPhotography is offline   Reply With Quote
Old 27th of May 2010 (Thu)   #4
protest42
protest42's Avatar
thanks for the replies, yeah I guess I'll just have to try another strobe next time.
50D
Old 27th of May 2010 (Thu)   #5
namasste
namasste's Avatar
I'd have started by seeing how things looked bounced. Next, check your settings. You don't want to blow out your subject but f7.1 and 200ISO seems whack to me in a skatepark. Increase your shutter to max sync speed (or close to bring in more background), bounce the flash with the ISO around 400 and the lens as wide open as you can. Start there then adjust flash exposure, and aperture/ISO as needed to properly expose the skater. Then photoshop what you need to to get things looking good but using a layer mask and working over the background. Also, we careful that you a) get good focus which this one is missing and b) pay attention to your positioning so you don't wind up with the video shooters lens in your shot. Details can make or break ya.
namasste is offline   Reply With Quote
Old 27th of May 2010 (Thu)   #6
protest42
protest42's Avatar
Thanks for the feedback, I didn't think I'd be able to bounce it because the ceiling was pretty high, but looking back on it I probably should have at least tried. I also agree about the focusing as well as the positioning, but I wasn't really taking the shooting too seriously and at the time was just sitting on a bench because I wasn't sure if the flash would mess up the skaters if I got too close. I was really unprepared for this as it was a kind of spur of the moment thing I got to go to through work so I only got to shoot for about 20 minutes until my camera died, and it was the first time I had shot skating as well as only using my flash a few times. I really appreciate the advice and will try out what you suggested next time.
50D
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
