Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 27th of May 2010 (Thu)   #1
lrailing
Default Macro/Wide Angle Attachment issue
So, I recently got a nifty macro attachment for my Canon 50D. It is smaller than I realized. What would I need to fix this? I've seen several thread adaptors but have no idea what size would work. I have a 28-135 mm lens.
lrailing is offline   Reply With Quote
Old 28th of May 2010 (Fri)   #2
mike_d
Default Re: Macro/Wide Angle Attachment issue
Exactly what did you buy? Is it the 500D closeup lens that looks like a thick filter? I believe that's a 77mm. According to Amazon, your 28-135 has 72mm threads so you'd need a 72mm to 77mm step up ring to make it fit.
mike_d is offline   Reply With Quote
Old 28th of May 2010 (Fri)   #3
lrailing
This is what I bought:
http://www.amazon.com/Angle-Converte.../dp/B0025Z7MAE
I have a friend who also has it and uses it but it turns out they use it with lenses from their Rebel and that works fine.
Old 28th of May 2010 (Fri)   #4
mike_d
That thing says it fits an 18-55 lens which has 58mm threads. Its too small for your 28-135 with 72mm threads. That really looks like a cheap gimmick. Wide angle and macro are opposite goals. Even if it fit your lens, I wouldn't expect much from a $21 item.
Old 28th of May 2010 (Fri)   #5
lrailing
wouldn't an adaptor ring work for it?
Old 28th of May 2010 (Fri)   #6
mike_d
You could get a step down ring to make it fit. But you'd still be sticking a small piece of glass in front of a larger piece of glass. That's not good.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
wide angle/macro add on Erik_L Canon EOS Digital Cameras 2 19th of November 2009 (Thu) 00:35
wide angle lens - attachment?? inthegarden Canon EF and EF-S Lenses 3 23rd of May 2009 (Sat) 08:42
wide angle with macro racketman Macro 25 25th of January 2008 (Fri) 06:22
Which wide-angle macro for me? tkd Canon EF and EF-S Lenses 11 1st of February 2007 (Thu) 11:36
