| sponsored links |
Thread Tools | Display Modes |
#1 |
I just can't justify spending $130+ for a tripod collar for a 70-200 f4 IS. Has anyone tried this one? I'm looking for color matching and build quality (obviously you get what you pay for, but MANNNNN.....).
Link Here: http://www.amazon.com/Cowboystudio-T...5171763&sr=8-3 Anyone have any other recommendations if not?
5D Mark III 35L • 24-105L • 70-200L • 17-40L • 85 photos: http://photos.thegfxman.com/ |
| sponsored links |
#2 |
I don't think you're going to get "build quality" for $12.95...
If I had that lens I'd probably buy the canon collar. I learned a long time ago not to scrimp on purchases, especially when the safety of an expensive lens is at stake.
John |
#3 |
+1 can you imagine if the collar failed, potentially both your camera body and lens would be on the ground, unless you had the strap tied off somewhere.
1Dx, 1DM4, 5DM2, 7D, EOS-M, 8-15L, 17-40L, 24 TSE II, 24-105L, 50L, 85L II, 100L, 135L, 200L f/2.8, 300L f/4, 70-200L II, 70-300L, 400Lf/5.6 Last edited by lannes : 1st of June 2010 (Tue) at 08:23. |
| sponsored links |
#4 |
I don't mind using Chinese knock-off lens hoods and lens caps or virtually any other item which will neither impact on image quality nor camera safety.
I bought a Canon OEM tripod ring long before the Chinese knock-off items arrived. I am glad that I did because I don't have to make your decision, The Chinese rings may be just fine because the technology of manufacturing this item isn't up there with rocket science but, I would always worry about the integrity of my camera/lens when using a knock-off ring. I will often carry my camera/lens mounted on my tripod head when I have the tripod over my shoulder. I don't know if I would have the confidence in a knock-of ring to carry the camera/lens in that fashion.
See my images at http://rpcrowe.smugmug.com/ EQUIPMENT: Two Canon 7D cameras plus Canon D60 camera modified for full-time IR; Tokina 12-24mm f/4, 50mm f/1.8 Mark-I, 17-55mm f/2.8 IS, Tamron 90mm f/2.8 Macro, 135mm f/2.8 Soft Focus, 70-200mm f/4L IS, 300mm f/4L IS, and 400mm f/5.6L lenses; |
#5 |
I've been using my 70-200 4L IS with the Opteka ring. The color isn't 100% the same, but mechanically, it works quite well. I haven't had any issues with it. I'm not too sure how badly the Chinese could screw up 2 curved pieces of metal, a hinge, and a thumbscrew. I would love to see how much it costs Canon to make those tripod rings. I can only imagine how much markup is on those!
I have a 100-400mm with the OEM canon ring, and i can't really tell the difference in the mechanical quality of the OEM and the Chinese knockoff.
7D | 5D II | 85L II | 24-70L | 70-200 2.8L IS II | 100-400L | 100 2.8 Macro | 50 1.8 II | 10-22 | Tokina 16-28 2.8 | Sigma 15 2.8 FE | 430EX II (x2) | Genesis lights | YN RF-602s |
#6 | |
5DMkIII, 1DMkIII, GPS-E2, S90, 2x580EX, 430EX, Sigma DC 8-16, EF17-40L, EF24 f/2.8, EF24-105L IS, Sigma EX DC HSM 30, EF50 f/1.4, EF85 f/1.8, EF70-200 f/4L IS, EF100-400L IS, Kenko DGX 1.4X TC, RRS L-Bracket, Sirui 306/K-20, Giottos MT-7371/MH-3300/VR, Velbon El Carmagne 530, Phottix and Canon Remotes, Lowepro Backpack, ThinkTank Modular System Belt/Pouches, Lexar and San Disk Cards. |
#7 | |
#8 |
it is made by plastic, it flex alot so spend some money on ebay get a Metal one, don't get JJC brand. By the way mine broke on the first day, plastic cracked. =(
#9 |
My Opteka is definitely metal. It's quite solid, actually.
#10 | |
I do and it's fine, just curious if you actually have it and yours is made of plastic, 'cause the one that I have is metal and very good. sometimes (not your case of course) ppl say things with no direct experience and still wanna say it. |
#11 |
well, i ended up getting it -- even though I usually stick to brand name products. However, I couldn't justify spending the amount canon wanted for this little piece.
I got the metal one, it fits great, color matches perfect, and don't see my lens/camera going anywhere soon on a tripod. Haven't used it too much, but first impressions are great.
#12 |
I bought one of those Chinese knockoffs. Cast aluminum. Don't know the brand. I'm sure I paid less than $20 on Ebay. I don't know what the difference between this one and a Canon would be, but this one works fine. Fit and finish are no problem.
I bought it when I first got the lens. Figured I'd use it more than I do. Turns out I hand hold that lens pretty much always and the ring sits in my secondary bag with other stuff that doesn't get used much. Glad I didn't fling a Benjamin at it. |
#13 |
i can see them not including one for the non IS version. you'd technically need it more often with the lack of IS, but the lens itself is relatively cheap, so i can understand cutting costs. with the IS version, though, you're spending roughly $1200 on it. i'd appreciate canon including the tripod collar with it.
#14 | |
they wanna sell the overpriced accessories!! now $140 vs. $8 for the same thing is embarrassing (for Canon) . kinda revealing their obsession with da money and the fact that they must see us like monkeys. da same when you compare the overpriced pocket wizards to the RF-602. Embarrassing too. no? before we enter a debate about the fact that the Chinese production is disgusting because they treat their own people like animals, but you must admit that 140 against 8 is tough to sell (and justify). really tough. |
#15 | |
So which one is the metal one? I got the JJC one from eBay and even though I thought it was metal, it's now clearly now. The pilot screw that holds in the fastening assembly cracked the cylindrical plastic tube that houses the tightening thing. It only lasted 4 days. I'm going to complain to the seller on eBay, but I'm not expecting much cooperation. Got a link to where you got your metal one? Problem with mine was it wasn't tight enough so my lens kept rotating slightly off center, so I tightened it slightly more (I'm not BamBam) and I heard "SNAP!" and that was it.
Canon Digital Rebel T1i (500D) with back-up Rebel XS (1000D) Canon EF-S 10-22mm F3.5-4.5 USM | Canon EF 70-200mm F/4 L | Canon EF 28-105mm F/3.5-4.5 II USM | Canon EF 28mm F/1.8 USM | Canon EF 35mm F/2.0 | Canon EF 50mm F/1.8 II | Canon EF-S 18-55mm F/3.5-56 IS | Canon EF 28-80mm F/3.5-4.5 USM | Canon EF 100-300mm F/4.5-5.6 | Canon BG-E5 Battery grip | Canon 580EX II |
| Thread Tools | |
| Display Modes | |
| WTB: Canon Tripod Mount Ring A II (W) for 70-200mm f/4 L IS | 71sbeetle | Classifieds: Buy | 0 | 1st of November 2007 (Thu) 08:54 |
| WTB: Canon Tripod Mount Ring A II (W) for 70-200mm f/4 L IS | 71sbeetle | Classifieds: Buy | 0 | 27th of October 2007 (Sat) 23:17 |
