#1 |
I'm looking for a compact head for travel that has the ability to do panning (simple video shots) with my Rebel.
http://www.bhphotovideo.com/c/produc....html#features The description on B&H's site claims that the 496RC2 can do 360 panning yet I've read in the forums where people suggest the bulkier 498RC2 instead. Can the 496 do panning at all or is there a mistake in the description? Or is it just an issue of needing more steps to do it? I just want to know if I can pan in a straight horizontal line for video without it going all over the place like a normal ballhead would. Thanks.
-Paul Canon EOS 5D Mark III x2 | Canon EF 24-105mm f/4L IS USM | Canon EF 16-35mm f/2.8L II USM | Canon EF 70-200mm f/4L IS USM | Canon EF 50mm f/1.4 USM | Canon EF 85mm f/1.8 USM | Canon Speedlite 430EX II x2 | B+W filters | Black Rapid R-straps | Gitzo/Markins flickr Last edited by s2kdriver80 : 30th of May 2010 (Sun) at 01:00. |
| sponsored links |
#2 |
I just got a 496RC2 because I was on vacation and needed a tripod/head and that's all they had.
There isn't a separate lock for panning. You can however set the friction relatively tight so it will hold the camera in place unless you move it. |
#3 |
Thanks for your feedback. So are you saying that you can pan reliably without much trouble? I'm looking to do mostly quick simple video pans and not panoramic photo stitches, so I don't think I'll need the head to firmly hold the camera in place for too long.
| sponsored links |
#4 | |
You need the 498RC2 to have the controlled one-axis panning capability. Besides, the 498RC2 is MUCH more suited to EOS cameras on a tripod. The 496 will, more than likely, creep more than the 498 head. I know for certain that the 486 (the forerunner to the 496) creeps more than the 488 (the forerunner to the 497), as I have both. I use the 486 on a monopod only these days.
Skip Douglas A few cameras and over 45 years behind them ..... ..... but still learning all the time. |
#5 |
Ms Moderator and Grandma
Yes, the 498RC2 is the one you want for panning. I have had no issues with the 488 or the 496 I have. But for something like video, the 498 is a good choice. Get what you really want and need, and not what you think you can get along with, if you can afford it. I've done that too often and regretted it.
Suzie - Still Speaking Canonese! 5D2 My children are the reason, but it's the passion that drives me to get the perfect image of everything. My Gear and Wishes Last edited by SuzyView : 30th of May 2010 (Sun) at 18:25. |
#6 |
Oh ok - thank you all for your input. So it seems like the 496RC2 is not much better than a normal ballhead? I wonder how that model differs at all to the built-in normal ballhead found on the 7302YB. And Manfrotto should really remove the 360 panning from the 496RC2 description - that's false advertising.
#7 |
Moderator
Cocker Spaniel Mod Join Date: Jun 2004
The 496 is a normal ballhead. It's not false advertising; you can pan with it. It just doesn't permit optimum panning. There's a difference. And one major difference between the 496RC2 and the ballhead on the 7302 is the head capacity; the 496 is able to cope with about twice the load.
Jon ---------- EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan Cocker Spaniels Maryland and Virginia activities DC Cherry Blossoms Image Posting Rules and Image Posting FAQ Report SPAM, Don't Answer It! (link) PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED. |
#8 | |
#9 |
Moderator
Not Manfrotto. If you want to look at the Arca-Swiss mounts Adorama's Flashpoint F-2 and F-3 heads both offer a separate panning control and are smaller than the 498RC2.
![]() Left to right. Flashpoint F-2, Flashpoint F-3, Manfrotto 486RC2, Manfrotto 488 converted with RRS LR-40 (Arca-Swiss) clamp. The F-2 is about a 486 equivalent in specs; the F-3 the 488 equivalent.
#10 | |
#11 |
Moderator
This is the F2 holding a 1D3 and 70-200 2.8 IS off kilter and mounted to the body, not the lens, to increase likelihood of torque. Seems solid enough to me.
#12 |
"I'm the original idiot"
Before I moved to an M10, I used a 486. Panning was never a problem but control of it moved from the head to the centre column lock. Simply set up the tripod exactly upright and leaving the head fully locked down, rotate the whole column. I used to leave the lock so that it created a little drag and left it alone.
#13 | |
Moderator
#14 |
Thanks Jon, just picked up the F2 today. It fits the bill - compact, yet can pan.
#15 |
Moderator
Must be nice!
I'm glad I can't just run into town and hit Adorama or B&H. I'd be broke.
| Thread Tools | |
| Display Modes | |
| Manfrotto 190CXPRO4 with 496RC2 HEAD vs. 055CXPRO4 with 498RC2 | Dustman | Accessories & Storage | 6 | 24th of May 2010 (Mon) 23:36 |
| Help - Manfrotto 190xb/496rc2 or Benro A169 | ofafeather | Accessories & Storage | 7 | 8th of March 2010 (Mon) 15:11 |
| Manfrotto 486RC2 vs 496RC2 ballhead | andykee | Accessories & Storage | 18 | 18th of January 2010 (Mon) 12:17 |
| Question about panning | jaxson5 | General Photography Talk | 11 | 18th of December 2006 (Mon) 20:43 |
| Question about fstop and AF ability | 05Xrunner | Canon EOS Digital Cameras | 9 | 20th of May 2006 (Sat) 19:54 |
