Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 4th of June 2010 (Fri)   #1
fishbio
Default Newbie effort of a Pier in Venice, Florida
I would appreciate your comments and critiques of these photos of a pier in Venice, Fla. I was on vacation there last week and thought the pier made an interesting pattern. I'm a newbie to digital photography would appreciate any suggestions. Thanks!
fishbio is offline   Reply With Quote
Old 4th of June 2010 (Fri)   #2
sapearl
emailed Tim some prozac
sapearl's Avatar
Default Re: Newbie effort of a Pier in Venice, Florida
Hi fishbio and welcome to POTN. By any chance are you a marine biologist ?
Normally pier shots can be quite drab, repetitive and boring. But yours is none of that - it's a bit unique and eye catching in a special way. It's the way the "glowing water" laps around the piers at their bottoms. That's a type of highlight you normally don't see and you've captured it well. Some of the sand could stand a bit of cropping at the bottom - I think it detracts from the greater image.
The bottom shot is fair.... but #1 remains my favorite. Thanks for sharing. - Stu
sapearl is offline   Reply With Quote
Old 4th of June 2010 (Fri)   #3
corkneyfonz
corkneyfonz's Avatar
I like how you've captured the pattern and depth of the pier. However, the supports are not as aharp as I would have liked to have seen having the look of being denoised at too high a setting. On the other hand it could just be jpeg compression.
My Flickr
corkneyfonz is offline   Reply With Quote
Old 5th of June 2010 (Sat)   #4
Meaty0
Meaty0's Avatar
Hi Fishbio,
When you do a long exposure to get the softness in the water, you have to take extra precautions to maintain sharpness in the rest of the elements. Namely, you need to use a tripod and set your camera to Mirror Lock-up and use a remote release cable (or timer release) to minimise camera shake. It helps if you choose a breezeless day too.
To get your 1/15 sec (or more) exposure, use a very small aperture (also to get everything into focus too) and a low ISO. In very bright situations, you may still need to use a ND filter as well.
Now if you're going to include a human factor as well....then you have problems! I like the idea of the two people in your shot, but they aren't going to be still for the slow exposure time and they'll look fuzzy...so here's what you do: Find two 7' long lengths of reinforcing bar and hammer it in through the tops of their heads so it travels down their spines and out there behinds...then it has to be hammered a fair way into the sand as well! Guaranteed to keep them still and - Hey - their pain will pass, but a good image lasts forever!
JK of course. You could just get them to lean on each other (shoulder-to-shoulder) to help steady them.
I would also make sure your subjects are dead centre too.
EDIT: And I'd clone over those patches at the top of each pier leg.
Meaty0 is offline   Reply With Quote
Old 5th of June 2010 (Sat)   #5
fishbio
Thanks for the comments, everyone. I was going for the silky water look. Camera was a Rebel XSi with kit lens. The first pic was 4 sec, f/20, ISO 100, and the second pic was 5 sec, f/8, ISO 100. I like the first one better. It's sharper and the DOF is greater. Probably should have used f/20 or so on all the shots (I took several). I used a tripod and the delayed timer but didn't do the mirror lockup. It was pretty breezy and my camera strap was flipping in the wind so I started holding the strap in my hand to minimize the shake. I told the girls to be very still but I kinda like Meaty0's suggestion with the rebar. I'm a novice on photo editing and will have to get my daughter to show me how to clone out the patches on the pier legs--I agree it would look better without them. Sapearl--I'm a fisheries biologist but I stick to freshwater fishes. Thanks again guys!
Old 5th of June 2010 (Sat)   #6
joedlh
joedlh's Avatar
Location: Long Island, NY, North America, Sol III, Orion Spur of the Milky Way galaxy.
This shot makes a nice abstract. However, I would crop the sand completely out of the first and ditch the two women in the second. It just doesn't have visual interest to me.
Concur with others on softness in the pilings. However, the sand looks pretty sharp. I think maybe your camera was focused on that, which rendered more distant things out of focus rather than subject to movement blur.
Joe
Gear: Kodak Instamatic, Polaroid Swinger
http://photo.joedlh.net
joedlh is offline   Reply With Quote
Old 5th of June 2010 (Sat)   #7
Meaty0
Meaty0's Avatar
Oh yeah, that's right! You'd probably do better with manual focus and f/11 or f/16 and focus about 1/3rd of the way into the image (3rd or 4th pylon). That will ensure a reasonable depth of focus. F/20 can cause diffraction effects and softness. Most lenses top out in sharpness at around f/8 to f/11.
Old 6th of June 2010 (Sun)   #8
fishbio
Thanks for your suggestion, MeatyO.* I'll keep that in mind for next time.* I've made a few edits (based on suggestions received) of my original image and would like some input.* Which edit do you think is better, the cropped sand or no sand.* Both images have been sharpened a bit.Thanks for your help.
Old 8th of June 2010 (Tue)   #9
ekorff
that water is beautiful
ekorff is offline   Reply With Quote
Old 8th of June 2010 (Tue)   #10
alyson
alyson's Avatar
hi fish bio! great image! id like to go there someday!
honesty is easy, fiction is where true genius lies
alyson is offline   Reply With Quote
Old 10th of June 2010 (Thu)   #11
fishbio
Thanks alyson and ekorff. It's a nice spot and there's a great restaurant (Sharky's) right next to the pier. Highly recommend!
Old 11th of June 2010 (Fri)   #12
GorgeShooter
GorgeShooter's Avatar
The one without people is the best IMO. Since this type of image is all about symmetry, I think you need to get it spot on regarding this. You're close but not quite there. (1) it seems a bit off level and (2) there's a gap between 2 piers on the right that's not there on the left.
1DX | 5D MkII (gripped)
16-35 f/2.8L | 24-70 f/2.8L | 24-105 f/4L IS | 70-200 f/4L IS | 100-400 f/4.5-5.6L IS | 24 f/3.5L TS-E | 45 f/2.8 TS-E | 40 f/2.8 Pancake | 15 f/2.8 Fisheye | Tokina 100 f/2.8 Macro | Canon 1.4x TC | 580 EX II | 430 EX II | Manfrotto 055CXPRO4 | Kirk BH-1
:: Smugmug :: | :: Photography BLOG :: | :: Workshops and Classes ::
GorgeShooter is offline   Reply With Quote
Old 11th of June 2010 (Fri)   #13
dwarrenr
dwarrenr's Avatar
Love what you are trying for. I like your last crop better, but think it could still be better (for my eye anyway.) Here are to examples.
This first one is like you last, but I included some beach for grounding:
The problem with this crop, to me, is the light coming through the first set of piers, so here is the other option...just tighter:
D. Warren Robison
"All guys feel the need to compensate. Most compensate with sports cars. I compensate with a 400mm 2.8"
Flickr - Home Page - MaxPreps Gallery - Razzi
Equipment List
dwarrenr is offline   Reply With Quote
Old 11th of June 2010 (Fri)   #14
Flo
Gimmie Some Lovin
Flo's Avatar
even with the sharp added it still feels soft for me?
Flo is offline   Reply With Quote
Old 11th of June 2010 (Fri)   #15
GorgeShooter
Regarding sharpness. Not knowing what your settings or setup were, I'd suggest focusing at the hyper focal distance while using a sharp aperture (f/8-f/11) and using a tripod.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Pier in Venice, Florida fishbio Critique Corner 3 1st of June 2010 (Tue) 20:05
Fishermen & Friends, Venice Pier sideeffects People 2 23rd of July 2008 (Wed) 18:18
Another newbie effort wallisj Still Life, B/W & Experimental 1 28th of January 2007 (Sun) 06:19
Second effort at pier pic! baldybaldstock Nature & Landscapes 9 14th of October 2006 (Sat) 07:19
A different view-Venice Rookery, Florida 7AM kr88 Wildlife 3 18th of March 2006 (Sat) 18:00
