#1 |
Here is what I am thinking of buying. I found a good used price for both the lens and tubes, so I would like to buy both and learn, and compare which I like better … and maybe use both together.
Should I get the regular softbox, or the mini? I think I am leaning towards the regular. Is the Opteka sync cord ok? Or should I get a different one? I just got my first flash, a 430ex ii. Please let me know if I am leaving anything out... maybe a ballhead? 100mm 2.8 macro (non IS) Kenko extension tube set Manfrotto 330 bracket LumiQuest ProMax Mini SoftBox or ProMax SoftBox Opteka E-TTL / E-TTL II Off-Camera Flash Sync Cord Thanks
FUJI Users Unite Fewer options leads to more creativity “Photos are everywhere. You just have to know how to look.” -- Chris Weeks |
| sponsored links |
#2 |
Go for the regular softbox - overall the larger the area of the flash the softer the light you get so it will give you softer light to work with and is not an unmangiable size to work with.
As for the rest of your setup is looks solid - flashbracket, cord, softbox, lens, tubes. I would say don't get a ballhead. Unless you get a top of the range ballhead you will get headcreep with most of the rest which whilst not noticable for regular photography, it is very noticable and a pain to work with in macro. Tripod macro work is slow macro work - ie when you have time to setup - and hte ideal head is a geared head. It's slower to use, but is rock solid and lets you adjust each of the 3 axis with very fine adjustments that macro calls for. The Manfrotto Junior geared head is the one I use and comes well recomended from other macro shooters who do tripod work.
Tools of the trade: Canon 400D, Canon 7D, Canon 70-200mm f2.8 IS L M2, Sigma 120-300mm f2.8 OS, Canon MPE 65mm f2.8 macro, Sigma 150mm f2.8 macro, Sigma 70mm f2.8 macro, Sigma 8-16mm f4.5-5.6, Raynox DCR 250, loads of teleconverters and a flashy thingy too My flickr The Wildlife Project |
#3 |
agree geared head is more suited to macro.
| sponsored links |
#4 |
Thanks for the replies, I appreciate it.
I stayed up late reading many macro threads and tutorials and when I posted this thread I was on the verge of passing out ... I could have structured my post a little better. Thanks again.
#5 |
I will add an answer to the other question you asked: yes, the opteka flash sync cord is good/good enough.
are you planning on using the 330b bracket for a two flash set up?
EOS 7d - Canon 100 macro USM, 10-22, 24-105, 70-200 f4IS, 55-250, 50 f1.8II - Tamron 28-75 f2.8 - Kenko extension tubes - 430 exii, 540ez - 055xprob/488rc2 |
#6 |
Not sure how you were planning to use the ballhead, But I do have a smallish one on the arm of the 330B which the flash camera cord is attached to- allows easier flash positioning.
Brian v.
http://www.flickr.com/photos/lordv/ http://www.lordv.smugmug.com/ Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056 Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits |
#7 |
You have nearly the same gear as I do, although I opted for the LordV coke-can diffuser. =)
My first legit camera is a Canon AE-1 Program, given to me as a birthday present from my best friend. And so my obsession begins... Canon EOS-30D: 35-80 f/4.0-5.6 | 18-55 f/3.5-5.6 IS | 50 1.8 |
#8 |
Do I need a LumiQuest Cinch Strap or HonlPhoto Speed Strap to use the ProMax SoftBox with my 430ex ii?
http://www.amazon.com/LumiQuest-LQ-1...d_bxgy_p_img_b http://www.amazon.com/HonlPhoto-Spee...ref=pd_sim_p_3
#9 | |
So if using a ball head on the 330B for the flash, what would be the cheapest I could get that would work well? I only know which ball heads are good for dslr / tripod use, not 330B / flash use. Thanks
#10 |
http://www.bhphotovideo.com/c/produc...Mini_Ball.html
That's what I use.. I have a 580 exII and it works just fine.. every now and then it comes a little loose, but for about 95% of the time it stays put.
#11 | |
| Thread Tools | |
| Display Modes | |
| starting to get into macro | mrbojangles13 | Macro Talk | 7 | 26th of January 2009 (Mon) 09:13 |
| I'm starting to really like Macro.. | bromm | Macro | 7 | 10th of May 2007 (Thu) 21:08 |
| NHRA Top Fueler leaving the starting line | Got Gates? | Motorsports | 3 | 23rd of February 2007 (Fri) 16:50 |
| Starting Macro | Billginthekeys | Macro | 6 | 13th of April 2006 (Thu) 08:03 |
| Curious...is Macro season leaving us (in the US)? | FlipsidE | General Photography Talk | 7 | 22nd of June 2005 (Wed) 01:17 |
