Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 9th of June 2010 (Wed)   #1
matoshi
Default focal length Equivalent to footstep
Hello all,
just wondering if there are some general rule of thumb measurement for focal length and footstp. for example. 1mm = 1 footstep away?
thanks guys..
Canon 7D. Canon 50mm f/1.4 USM . Canon 28-135mm IS USM . Tokina 12-24mm f/4 . Tamron 17-50 f/2.8 . Canon 70-200mm f/4L . Canon 24-105mm f4/L IS . Kenko Extension Tube Set . Nissin DI622.
flickr: http://www.flickr.com/photos/myat78/
matoshi is offline   Reply With Quote
Old 9th of June 2010 (Wed)   #2
SkipD
SkipD's Avatar
Default Re: focal length Equivalent to footstep
Originally Posted by matoshi View Post
Hello all,
thanks guys..
No.
Please read our "sticky" (now found in the General Photography Talk forum) tutorial titled Perspective Control in Images - Focal Length or Distance?.
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 9th of June 2010 (Wed)   #3
philwillmedia
Location: Sittin on the beach, drinking rocket fuels - Oh yeah
Hello all,
thanks guys..
How big is a footstep
Regards, Phil
2011/12 CAMS Gold Accredited Photographer | 2010 & 2011 V8 Supercars Aust. Accredited Photographer | 2008, '09, '10 South Aus. Rally Photographer of the Year | Catch Fence Photos - 2009 Photo of the Year
"A bad day at the race track is better than a good day in the office" | www.freewebs.com/philwillmedia
philwillmedia is offline   Reply With Quote
Old 9th of June 2010 (Wed)   #4
Wilt
Wilt's Avatar
((subject distancein footsteps + n footstep toward subject) : subject distancein footsteps) = FL(after): FL (before)
So if subject distance = 10 footsteps, and you take one addition footstep toward subject, and you start with 100mm lens, then...
(10+1):10 = FL after : 100mm, so 110mm = FL after.
IOW, in this example, starting with 100mm lens at 10 footsteps away, then moving forward one footstep will change subject size the same as if you stood at original position and mounted a 110mm lens.
The above 'equation' totally ignores the issue that there is a change of perspective (relationship of subject to the surroundings) if you moved camera position!
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 9th of June 2010 (Wed)   #5
matoshi
Wow...thank you.
Now i really need a calculator to figure this out....
Originally Posted by Wilt View Post
((subject distance in footsteps + n footstep toward subject) : subject distance in footsteps) = FL(after): FL (before)
Old 9th of June 2010 (Wed)   #6
philwillmedia
Yes, but whilst the focal length remains constant, the size of your footstep is probably different to mine and everyone elses.
Regards, Phil
Old 9th of June 2010 (Wed)   #7
Wilt
Wilt's Avatar
Wow...thank you.
No, simple proportionality!
If you started 100' away with a 60mm lens, moving yourself to 50' away is like mounting a 120mm lens
to 50': from 100' = from 60mm: to 120mm
If you started 75' away with a 30mm lens, moving yourself to 112.5' away is like mounting a 20mm lens
to 112.5': from 75' = from 30mm: to 20mm
Old 9th of June 2010 (Wed)   #8
Wilt
Wilt's Avatar
But the proportionality applies, regardless if you are a Lilliputian or a Giant of Brobdingnag
Old 9th of June 2010 (Wed)   #9
matoshi
Thank you. Now it make mroe sense to me....
Old 9th of June 2010 (Wed)   #10
Thalagyrt
D'OH. I need to wake up some more.
Thalagyrt's Avatar
Wilt already said it's still valid but didn't fully clarify why it's still valid. The units (footsteps, meters, feet, miles, astronomical units, distance from the earth to the sun, height of my mom, distance you can throw an iPhone 4, arm span of a lawn gnome) cancel out and leave only focal length when the calculation is performed. You can even do this with different units of course, so long as you convert to one standard base unit.
d = distance
v = distance added
a = FL after
b = FL before
(d+v)/d=a/b
((d+v)/d)b=a
10 meters, step forward 1 meter, original focal length 100mm:
((10m+1m)/10m)100mm = (11m/10m)100mm = (1.1)100mm = 110mm.
James
Gallery
Thalagyrt is offline   Reply With Quote
Old 10th of June 2010 (Thu)   #11
SkipD
SkipD's Avatar
Wow...thank you.
While the calculations shown in several posts above allow you to choose a focal length that will keep a "primary subject" framed roughly the same at different distances, the image will NEVER be the same if the camera is used at different distances. The perspective (relationship in sizes between elements in the scene that are at different distances from the camera) changes whenever you change the camera's position.
As I mentioned in a previous post, please read our "sticky" (now found in the General Photography Talk forum) tutorial titled Perspective Control in Images - Focal Length or Distance?. You may just learn a lot that will help you improve your photo composition.
Skip Douglas
Old 10th of June 2010 (Thu)   #12
RichSoansPhotos
RichSoansPhotos's Avatar
Originally Posted by SkipD View Post
No.
Something I have been looking for, made my day, hopefully I will get a grip on it soon
Bodies: Canon 50D, Canon 5DMKII
Lenses: Canon 50mm 1.8, Canon 85mm 1.8 USM,
Canon 16-35mm 2.8L USM II Canon 24-70mm 2.8L USM, Canon 70-200mm 2.8L IS USM II
Compact: Canon G12
RichSoansPhotos is offline   Reply With Quote
Old 10th of June 2010 (Thu)   #13
Thalagyrt
Thalagyrt's Avatar
Yep, absolutely correct of course. That calculation only applies for the exact plane of focus - anywhere else and you start having to apply various non-linear algorithms that explain the mathematics behind the lovely thing called perspective... I don't think that math lesson is short enough for this thread though.
James
Gallery
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
REAL focal length vs. ACTUAL focal length on lenses ilumo Canon EF and EF-S Lenses 40 18th of April 2011 (Mon) 08:22
Focal Length equivalent at different zoom positions ahorel Canon G-series Digital Cameras 2 4th of April 2008 (Fri) 01:20
50mm Focal Length Equivalent JoeFriendly Canon EF and EF-S Lenses 18 21st of October 2007 (Sun) 10:44
RSE changing equivalent focal length in EXIF EOSAddict RAW, Post Processing and Printing 0 28th of August 2005 (Sun) 18:24
Lens focal length versus camera focal length. 2Hog Canon EOS Digital Cameras 10 2nd of October 2003 (Thu) 20:36
