Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 13th of June 2010 (Sun)   #1
alwyndavies
Default A1100IS ISO changing problem
Hi folks,
Just bought a Canon A1100 IS and, on looking at the manual instructions for changing the ISO settings, I see I need to press Function Set then use the up/down arrows to select ISO Auto. When I press the up/down arrows I can only move between the quality settings and continuous shooting. The up/down arrows won't take the option up to the ISO Auto icon.
I tried this on my Canon A710 IS and am able to select the ISO Auto but not with the A1100 IS. I have tried to access the ISO Auto setting whilst the camera is in Auto mode and also in landscape, portrait etc.
Is it me or is there a problem with the camera?
Thanks for all help.
Alwyn
alwyndavies is offline   Reply With Quote
Old 13th of June 2010 (Sun)   #2
alwyndavies
Default Re: A1100IS ISO changing problem
Found it now folks.
Though I didn't see it in the downloaded manual, I find on the Canon Support site that the A1100 IS camera has to be in P mode to change the ISO setting. That is not the case with the A710 IS.
See:
ATTENTION
* As the actual locations of buttons / switches on cameras vary depending on the camera model, the illustrations that appear on this page may differ from your camera.
* Screens or menu listings may differ depending on the camera model being used.
* The following explanations are provided based on the assumption that the [Shooting Mode] is set to [Program AE] ().
* To set the [ISO Speed], it is necessary to set the [Shooting Mode] to one of the following modes.
- [Program AE] (), [Long Shutter] () in [SCN] ().Ends.
This may help someone else who has the same issue.
Cheers
Alwyn
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon G11 problem ... changing settings Tpsfoto Canon G-series Digital Cameras 4 22nd of February 2010 (Mon) 20:19
error message on A1100IS jimrich Small Compact Digitals by Canon 6 17th of February 2010 (Wed) 00:44
Changing aperture in M mode *special problem* infinite012 Canon EOS Digital Cameras 18 28th of September 2008 (Sun) 10:41
Problem with changing light jack Sparrow General Photography Talk 4 16th of February 2008 (Sat) 20:52
Anyone else having a problem changing sigs? Radtech1 Forum Talk 11 23rd of December 2007 (Sun) 01:12
