Thread started 23 Jun 2010 (Wednesday) 20:44
20D Not recognized by EOS Utility
996gt2
Jun 23, 2010 20:44 |  #1
I just got a 20D off POTN, and the RAW files have the old owner's name in the EXIF. I connected the 20D to my PC via USB and started EOS utility to change the owner's name, but the program would not recognize the 20D. I tried Normal and PTP communications modes, but in both modes the "Camera settings/Remote shooting" option was greyed out. Does anyone know what I can do to make the camera detectable?
I'm running Win 7 Pro x64 and have a relatively new version of EOS Utility that came with my 40D./
Buy/Sell Feedback
5Dc, 50D, Tokina 12-24 f/4, Tamron 28-75 f/2.8, Sigma 50mm f/1.4, 430EX
deadpass
Jun 23, 2010 20:47 |  #2
go into your camera's settings and change the connection setting from PC to PTP (i think, whatever the other setting is) and it should work. Officially I'm pretty sure win 7 64 doesn't support the 20D, nor the 5D but when I changed that setting on my 5D I was able to use the EOS utility.
a camera
http://www.deadpass.co​m (external link)
996gt2
Jun 23, 2010 20:48 |  #3
deadpass wrote in post #10415927 (external link)
I changed it to PTP, and while Windows 7 recognizes the camera, EOS Utility's "Camera settings" option is still grayed out...the only option I can access in EOS utility is "monitor folder", which isn't useful for changing the owner name.
Buy/Sell Feedback
dpds68
Jun 23, 2010 20:50 |  #4
I am having the same problem with my 20D and XP , as we are on this topic should I install the software that I got with the 7D and have all 3 Body's work with it 7D,20D and XT ?
Thank You
David
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
deadpass
Jun 23, 2010 20:52 |  #5
Hmm..... I had the problem with my mkIIn with win 7 if i used the usb instead of the firewire, but the 20 only has usb. It's possible the lack of win 7 support prevents that option from being changed. Do you have access to any other computers?
a camera
deadpass
Jun 23, 2010 20:54 |  #6
dpds68 wrote in post #10415949 (external link)
Thank You
David
It's worth a shot, same goes to the OP, download the newest verions of EOS utility, it's possible the 40D version doesn't like win 7
a camera
Gregg.Siam
Joined Jun 2010
Jun 23, 2010 20:56 as a reply to  @ deadpass's post |  #7
Can you change the owners name through the camera menu?
5D MKIII | 24-105mm f/4 L| 50mm f/1.8 | 600EX-RT [FONT=Tahoma][COLOR=bl​ue][FONT="]|
∞ 500px (external link)
deadpass
Jun 23, 2010 21:02 |  #8
lostpacket wrote in post #10415986 (external link)
No, it has to be done via EOS utility on your computer.
a camera
vilamor
1 post
Aug 01, 2010 07:01 |  #9
I have the same problem with my 20D. I thought it was something with win7 x64, but today I installed XP SP3 on a virtual machine and I still have the same problem. I use PTP mode which works ok with transfering pics... . In normal mode, windows doesn't detect camera at all.
I also have tried different versions of EOS utility....no difference.
Can someone help plzZZZ?!
Jim_T
Joined Nov 2003
Aug 01, 2010 07:48 |  #10
PTP stands for Picture Transfer Protocol.. It's a common communication protocol used by agreement by many camera manufacturers. Using this protocol allows operating systems like Windows to communicate with a variety of camera makes without the need for installing any special camera specific drivers.
PTP is only designed for getting images off the memory card within the camera and little else.
Canon uses their own proprietary protocol to facilitate communication between the camera and the their software. This protocol allows you to do camera specific things, like tethered shooting and changing memory settings.. You should have the communication choice set to 'Normal' when you're trying to talk to Canon's own software.
Note that newer cameras no longer have a communication setting in the menu... The software and camera seem to 'know' what communication setting to use by context.
Also.. Make sure you've installed all the drivers that came on the disks that was packaged with the camera. Pay particular attention to make sure the EOS 20D USB WIA driver is installed.
BluewookieJim
Aug 01, 2010 13:21 |  #11
Win 7 64bit does not support the driver for the 20D, thats why EOS utility won't see it. The only thing changing the PTP setting will do is allow you to get images of the card while still in camera, and you're much better suited using a card reader for that purpose.
Sorry for the bad news, but it's not just the 20D either, its also the 5D (classic), 30D, and others.
On the bright side, since you are using the pro version of Win7 64 bit, if you are willing to install "XP Mode", you can actually install EOS utility in that "virtual machine" and get that functionality back, at least within the virtual machine... its better than nothing, and I can confirm it works, from personal experience.
My Gear and Stuff :: My Zenfolio Gallery (external link) :: My Flickr (external link) :: http://photos.kodanja.​net (external link)
Monica35
May 30, 2011 17:29 |  #12
Thanks ! this worked for me !
Monica35
May 30, 2011 17:32 |  #13
Thanks so very much...this worked for me !:)
dunnewold
Jul 18, 2011 17:07 |  #14
I have the same issue from the OP on my 5D. In PTP mode, I can use EOS Utility, but it won't allow me to change camera settings. It says to switch to PC Connect. Am I missing something?
I am using EOS Utility 2.0.2.28 (though the download said 2.6???) and the 5D driver version 6.1.7600.16385 (obtained number while in PTP mode).
BluewookieJim
Jul 18, 2011 17:39 |  #15
The only thing the PTP mode setting will do for a 20D/5D under windows 7 64 is allow you to use it as a glorified card reader. If you need to use EOS utility for tethering, updating owner data, etc, you will need to run some sort of virtual machine, whether it be XP mode in Win 7 64 Pro, or VMware or similar.
15,480 views & 0 likes for this thread
version 2.0 /
Latest registered member is Nidge
709 guests, 394 members online
