Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 24th of June 2010 (Thu)   #1
fromSF
fromSF's Avatar
Default Recomposing Shot
Just wanted to know how many of you click halfway on the shutter to focus on whatever your focusing on and then recompose the shot. Or do you guy just focus and take a big wide enough photo to just crop later on.
thanks.
canon 7D | ef18-55mm | ef75-300mm | canon 24-70 f2.8L | Canon 85mm 1.8 | Tokina 11-16 2.8mm | canon 430ex | 1x AB800
www.rklisephotography.com
www.flickr.com/rklisesf
www.rklisesf.tumblr.com
fromSF is offline   Reply With Quote
Old 24th of June 2010 (Thu)   #2
nicksan
Man I Like to Fart
nicksan's Avatar
Default Re: Recomposing Shot
I use the AF point closest to the subject. I don't focus recompose.
nicksan is offline   Reply With Quote
Old 24th of June 2010 (Thu)   #3
jurgenph
most of the time i focus/recompose.
if i have plenty of time and my subject is not moving, i'll select a different focus point instead.
if there's no time, i just center focus the subject, shoot, and i'll crop it later.
so... all of the above
J.
jurgenph is offline   Reply With Quote
Old 24th of June 2010 (Thu)   #4
tonylong
....winded
tonylong's Avatar
It really depends on what you are shooting. I can focus and recompose if the shot allows it, but I'm also in the habit of selecting a focus point if I'm shooting with a wide aperture. And sometimes, <gasp>, I'll even dash off a shot with center point focus and not recomposing! and sometimes, I'll even dash off a shot with the camera in landscape orientation even if I'll need to crop it into portrait orientation, just to get the quick shot! Not the way to get a large print, though!
Tony
Tony Long Photos on PBase
Wildlife project pics here, Biking Photog shoots here, "Suburbia" project here! Mount St. Helens, Mount Hood pics here
tonylong is offline   Reply With Quote
Old 24th of June 2010 (Thu)   #5
fromSF
fromSF's Avatar
the only reason i ask is because i usually just keep it at center focusing i dont know im in a habit thinking its just the sharpest point.
Old 24th of June 2010 (Thu)   #6
gonzogolf
One of the strengths of the 7D is supposed to be the accuracy of its focusing system on the outer points. Use them.
gonzogolf is offline   Reply With Quote
Old 24th of June 2010 (Thu)   #7
jurgenph
that depends on your lens.
J.
Old 24th of June 2010 (Thu)   #8
Digital_zen
Digital_zen's Avatar
+1 Jurgenph
You will find no more zen at the top of a mountain, than the zen that you bring there with you.
~zen proverb~
Digital_zen is offline   Reply With Quote
Old 24th of June 2010 (Thu)   #9
Wilt
Wilt's Avatar
There was a focus-recompose poll done within the past half year or so. Majority engaged in the practice, if I recall correctly.
[edit] found it...
http://photography-on-the.net/forum/...ts&pollid=3694
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is online now   Reply With Quote
Old 24th of June 2010 (Thu)   #10
yogestee
"hangs around male genitalia"
yogestee's Avatar
I never do..
I do what nicksan does..
Jurgen
50D~20D~EOS M~S95
http://www.pbase.com/jurgentreue
yogestee is offline   Reply With Quote
Old 24th of June 2010 (Thu)   #11
Veemac
I select my focus point most of the time. Using the joystick to select makes it plenty fast and dead easy.
Mac
-Stuff I Use-
Veemac is offline   Reply With Quote
Old 25th of June 2010 (Fri)   #12
fromSF
fromSF's Avatar
thanks for the replies guys. Ill definently try to get used to just adjust the AF point. Im just so used to learning using the center point to get the sharpest photo. I guess ill just have to trust my 7D more which i love very much =)
Old 25th of June 2010 (Fri)   #13
hsmoscout
hsmoscout's Avatar
I always focus/recompose unless I'm in AI Servo.
˙ʇsod uı ʇı xıɟ
hsmoscout is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
recomposing? habenero Canon EOS Digital Cameras 29 2nd of March 2009 (Mon) 20:19
recomposing the shot ? Please explain. Nightowl64 Canon EOS Digital Cameras 15 30th of December 2008 (Tue) 11:20
recomposing a shot- when and how mllinden Canon EOS Digital Cameras 12 15th of July 2008 (Tue) 18:31
Recomposing question twinsrus Small Flash and Studio Lighting 21 6th of June 2008 (Fri) 15:07
Recomposing?? kekoa General Photography Talk 11 13th of February 2008 (Wed) 21:02
