Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Weddings and Other Family Events Talk
Reply
Thread Tools Display Modes
Old 28th of June 2010 (Mon)   #1
jcRocket
jcRocket's Avatar
Default using the Pingol method?
I've seen reference to this all over FM forums, and am wondering if anyone else here on Potn is using the Ed Pingol method to hold their camera(s)...
(Pingol method is basically Carabiners on a belt with an eye hook screwed into your camera's tripod mount) which can be seen in this potn post... http://photography-on-the.net/forum/...19&postcount=8
I've tried it out and like it but i need a better belt. I'm wondering what belt other people are using and how they've modified it to fit the needs of a working photographer. I'd like to get a belt set up to hold a flash, extra batteries & cards, and perhaps one long lens like the 135L or 70-200 so I could travel with a bride & groom and not worry about leaving something that I need back at the reception location.
jcRocket is offline   Reply With Quote
Old 28th of June 2010 (Mon)   #2
RT McAllister
Default Re: using the Pingol method?
I've seen Pingol's setup. He has to "unclip" each camera from the eyelet that's screwed into the base of the cam.
My opinion... if you're going to use this method get something designed to do it properly like a black rapid strap (or similar products on the market).
I just use the neck straps myself.
RT McAllister is offline   Reply With Quote
Old 28th of June 2010 (Mon)   #3
Peacefield
Peacefield's Avatar
Likewise, I just wear two with traditional straps, though I only feel the need to have two cameras actually on me during the ceremony. If I wanted something better, I would sooner wear my Cotton Carrier, but a pair of conventional straps meet the need for this 30 minutes of the day.
5D3, 5D2, 50D, 350D * 16-35 2.8 II, 24-70 2.8, 70-200 2.8 IS, 100-400 IS, 100 L Macro, 35 1.4, 85 1.2 II, Tokina 10-17 fish * 580 EX II (3) Stratos triggers * Other Stuff plus a Pelican 1624 to haul it all
Peacefield is offline   Reply With Quote
Old 28th of June 2010 (Mon)   #4
jcRocket
jcRocket's Avatar
thanks for the input guys but I'm already pretty much sold on the pingol method and not considering alternatives.
I stared this thread just to see how others are using or modding pingol's method, and what belt they choose.
Old 9th of August 2012 (Thu)   #5
ontopofm
I just found out about this method and I'd like to share my version. I shoot with two Nikon D800s and have the nikon 24mm 1.4 and sigma 50mm 1.4 mount on each. It works quite well. I reinforced my belt by adding 2 rivets. I used to use the dual camera strap but I like this method better.
Phuc
Flickr
ontopofm is offline   Reply With Quote
Old 9th of August 2012 (Thu)   #6
ontopofm
rivets added
Phuc
Flickr
Old 9th of August 2012 (Thu)   #7
scorpio_e
scorpio_e's Avatar
I'm not using it. For wedding and events, it looks unprofessional. I never heard of it before.
www.steelcityphotography.com
scorpio_e is online now   Reply With Quote
Old 9th of August 2012 (Thu)   #8
rob0225
I gotta agree...looks kinda tacky to me.
rob0225 is offline   Reply With Quote
Old 10th of August 2012 (Fri)   #9
fotojennik
fotojennik's Avatar
Spend the money and get a Spider Holster Belt. Worth it. If you have expensive camera gear why cheap out on accessories?
fotojennik is offline   Reply With Quote
Old 10th of August 2012 (Fri)   #10
scorpio_e
scorpio_e's Avatar
The Spider Holster Belt get a 10 for the coolness factor. It is very well designed.
Old 11th of August 2012 (Sat)   #11
RangersForever
That looks not only tacky but like a whole lot of effort that is needless to say the least.
Scotland Wedding Photographer
RangersForever is offline   Reply With Quote
Old 11th of August 2012 (Sat)   #12
form
"inadequately equipped"
form's Avatar
I would not want to add that kind of weight to my waist on account of the lower back pain it would cause and the shearing on my skin by my belt. I might consider using straps that go across the chest for camera slinging.
Las Vegas Wedding Photographer: http://www.joeyallenphoto.com
form is offline   Reply With Quote
Old 13th of August 2012 (Mon)   #13
fotojennik
fotojennik's Avatar
I could be wrong, but I think ergonomically, having straps across your shoulders is worse for your back than having the weight dangling from your belt.
I use the Spider Holster with 2 bodies/lenses attached at all times and it feels very comfortable.
Old 13th of August 2012 (Mon)   #14
snakeman55
snakeman55's Avatar
I wear one camera around my neck and one over my right shoulder all day. I do this at portrait shoots too. Usually one 50 1.4 and the other 24 1.4. I don't mind it at all.
-Adam
Wedding Photographers in Maryland
Gear
snakeman55 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What would be the best method TaDa RAW, Post Processing and Printing 4 24th of January 2009 (Sat) 05:46
trying new to me b&w method. strmrdr Critique Corner 9 17th of September 2008 (Wed) 22:06
Best method for ST77 Canon EOS Digital Cameras 0 17th of June 2008 (Tue) 16:05
Hoverflies, new pp method pxl8 Macro 12 30th of October 2005 (Sun) 19:06
B&W method 4walls Critique Corner 5 25th of June 2004 (Fri) 10:15
