#1 |
"Suck these toes"
I have picked up a small job in a local studio doing some product photography.
I normally only used strobes myself and bring in my own kit but I would rather not use mine. I have had a look at there set up they use: 2x"Elemental" 1000 watt continuous lights both have 24x24 softboxes. They also have a white backdrop. Grey low ceiling and two white walls either side. The space is around 8ft wide which is very tight for the bigger products and 16ft back. I'm wondering what the best way to white wash the background out while keeping the lighting on the product fairly. Would you shoot one at full power onto the ceiling? Another one at half power positioned on the left side of the product and a reflector the right side. Just wondering how you would do it?
"The goal is not to change your subjects, but for the subject to change the photographer." "Sedit qui timuit ne non succederet" |
| sponsored links |
#2 |
ugly when I'm sober
I've not done any studio work but if it were me I wouldn't bounce one off the ceiling - that is a small flash trick do diffuse the light - they have softboxes so the light produced from them should be nice and diffuse anyway. I'd position the heads either side of the products you are shooting and slightly in front.
www.mikegreenphotography.co.uk Gear UK South Easterners flickr Blog 5∞px Quis custodiet ipsos custodes? ::: A closed mouth gathers no foot. |
#3 |
"Suck these toes"
If the heads are eitherside of the products the background wont be white washed thats the only problem.
| sponsored links |
#4 |
Is that just glossy poster board under a pane of glass?
#5 |
It is hard for me to visualize your work space, but if you can try to put one light behind the product facing the background directly (so that it wouldn't be seen in the frame of course) and give it full power. If you notice that the product's edges suffer from it, reduce the light power of that light until you are satisfied with the results.
#6 |
It may help if you give us some idea as to *what* you will be shooting?
If it's *small* products - then you won't be using a wall as a backdrop anyway - the products will be on a "product table" with suitable paper background - and may even be inside a Light Tent. More info = more help! TJ
1DsMkIII | 1DMkIIN | 20D + grip | 70-200 f/2.8L IS | 24-70 f/2.8L | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea |
| Thread Tools | |
| Display Modes | |
| Product Photography & Studio Lighting Setup Shots | fensterbme | Still Life, B/W & Experimental | 5 | 23rd of January 2010 (Sat) 13:55 |
| Photography studio lighting | JakeCanon400D | Small Flash and Studio Lighting | 1 | 20th of January 2010 (Wed) 07:37 |
| Studio Photography Lighting Help | JMC489 | Small Flash and Studio Lighting | 14 | 30th of July 2009 (Thu) 08:45 |
| Studio lighting recommendations for food photography | glitch | Small Flash and Studio Lighting | 4 | 29th of June 2007 (Fri) 09:06 |
| Wedding Photography - Mobile Studio Lighting | Jason Cole | Critique Corner | 17 | 5th of November 2006 (Sun) 20:49 |
