Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 11th of July 2010 (Sun)   #1
Flytyer
Flytyer's Avatar
Default Monopod
I have never owned a Monopod and know nothing about them. What I would like to know is. Is it necessary to use a head on one or does the top screw into the camera socket. I am referring to one like the Manfrotto 680B. TIA jb
jb
Flytyer is offline   Reply With Quote
Old 11th of July 2010 (Sun)   #2
lannes
lannes's Avatar
Default Re: Monopod
You can just screw the camera onto the monopod without a head, makes taking a supported portrait shot difficult though.
lannes is offline   Reply With Quote
Old 11th of July 2010 (Sun)   #3
RPCrowe
RPCrowe's Avatar
Default Screws into tripod socket
The monopod screw will screw directly into the tripod socket of your camera. Most monopod screws are convertible from 3/8" to 1/4" size.
However, I prefer using a swivel head. I like having my monopod perpindicular to the ground directly under the camera. I get better support this way, A swivel will allow me to tilt the camera up or down without having the pod at other than a 90 degree angle to the ground.
IMO, the ultimate attaching system for a monopod or tripod is a swivel with an Arca Compatible quick release clamp with an L-bracket. This will allow you to hold the camera in either portrait or landscpe position without haveing it hanging cantilevered over the side.
See my images at http://rpcrowe.smugmug.com/
EQUIPMENT: Two Canon 7D cameras plus Canon D60 camera modified for full-time IR; Tokina 12-24mm f/4, 50mm f/1.8 Mark-I, 17-55mm f/2.8 IS, Tamron 90mm f/2.8 Macro, 135mm f/2.8 Soft Focus, 70-200mm f/4L IS, 300mm f/4L IS, and 400mm f/5.6L lenses;
RPCrowe is offline   Reply With Quote
Old 11th of July 2010 (Sun)   #4
RayHff
Default Re: Monopod
Worth a look:
http://www.nikonians.org/monopods/what_monopod_3.html
RayHff is offline   Reply With Quote
Old 11th of July 2010 (Sun)   #5
Flytyer
Flytyer's Avatar
Default Re: Monopod
Yes that is worth a look. Thank you very much. jb
jb
Old 11th of July 2010 (Sun)   #6
Lowner
"I'm the original idiot"
Lowner's Avatar
Default Re: Monopod
I use a cheap(ish) ballhead, because I find it easier to put the monopod base between or even behind my feet. Using it this way makes it easier to pan with a moving subject but forces me to use a swivel of some kind.
The head does not need to be expensive, mines an old Manfrotto 486 that I had hanging around.
Richard
http://rcb4344.zenfolio.com
Lowner is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Review: Gitzo GM2541 Monopod, RRS High Capacity Monopod Head w/ RRS B2 Pro II Clamp ben_r_ Accessories & Storage 137 22nd of June 2010 (Tue) 04:51
How useful is MonoPod? Tigerkn Accessories & Storage 21 19th of May 2009 (Tue) 18:39
monopod use ? Mike414 General Photography Talk 3 3rd of May 2009 (Sun) 19:09
Monopod ECD General Photography Talk 5 17th of September 2007 (Mon) 20:15
