Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 13th of July 2010 (Tue)   #1
Brandon Anderson Photos
Brandon Anderson Photos's Avatar
Default will this work??
I just picked up a 50d and is needing to hook up a pc cord to it, I dont want to use the pc sockett that is on the camera as I dont want to expose the other inputs to the dust in the air from the race track. All the other shooters out there us Nikon stuff and they use this adaptor on their bodies.
http://cgi.ebay.com/NIKON-AS-15-FLAS...item53dc81175e
I was wondering if these would work on the Canon hotshoes or is it Nikon only? if its only Nikon is there a Canon version?
thanks
BA
Gear: 1D MkIII | 1D MkII | 50D Gripped | 70-200L F2.8 MkI |17-40 L F4 | 28-135 3.5/5.6 IS | Nifty Fifty |Rokinon 8mm F3.5 Fisheye | 430 ExII | Some Studio Lighting | Go Pro Hero | Go Pro Hero 2
Web Site www.ba-photos.com
Brandon Anderson Photos is offline   Reply With Quote
Old 13th of July 2010 (Tue)   #2
Roobaix
Default Re: will this work??
What are you trying to do? It'll be easier to give you an answer with that info...
Roobaix is offline   Reply With Quote
Old 13th of July 2010 (Tue)   #3
TTk
TTk's Avatar
The Nikon one on E-Bay will not work and might damage your 50D, as the other poster has asked what do you want to do?
TTk is offline   Reply With Quote
Old 13th of July 2010 (Tue)   #4
i want to hook up my flash using the pc cords that way i can mount off the camera a bit. i already use the pc cord to hook up the flash on my 30d but the pc sockett is in a diffrent location on the 50d and I would have to uncover more of the other inputs on the 50 than I do on the 30
Old 13th of July 2010 (Tue)   #5
dedsen
dedsen's Avatar
Just exactly what data do you have to support your claim?
We use a Nikon adapter that looks a lot like the ebay one on our Canon cameras all the time. They are just a plastic block that adapts the hotshoe connection to a PC connection. There are no electronics in it, just a basic connection. I would love to hear how that can damage a camera.
I would checkout the adapters at Flash Zebra instead. He is a reliable seller and can help you get what you need for probably less money.
http://www.flashzebra.com/products/0154/index.shtml
Dale
dedsen is offline   Reply With Quote
Old 13th of July 2010 (Tue)   #6
thanks, i just called the local camera shop here and they said it will work just fine, im still a bit worried on the voltage though so I think im goin to just get the wein safe sync.... ive had no issues with it being hooked up to my 30d without the safe sync but dont know if I really want to risk it on the new 50d
Old 13th of July 2010 (Tue)   #7
SkipD
SkipD's Avatar
You have not yet told us what flash unit you want to connect to the 50D.
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 13th of July 2010 (Tue)   #8
The Ran
The only way you could damage your camera is if the trigger voltage on the flash is too high for the camera, however if it's been working fine on the 30D it'll work on the 50D. Honestly if I was in your position I'd jsut use the PC sync connection already on the camera, just put some gaffa tape round it and the covering the other connections to keep out any dirt.
The Ran is offline   Reply With Quote
Old 13th of July 2010 (Tue)   #9
I was hooking up the Norman 200b.....yea it worked fine on the 30d and the 10d without any problems... just with the 50d they relocated the pc port on it and it would mean id have to take the whole rubber cover off of it resulting exposing it to the dirt and dust. I just went out and got the Wein Safe Sync.... like momma always says its better to be safe than sorry.
Old 13th of July 2010 (Tue)   #10
SkipD
SkipD's Avatar
If the trigger voltage from the flash unit is down around 5 or 6 volts, you could experience a mess of problems with the Safe Sync adapter. Been there, done that.
Skip Douglas
Old 14th of July 2010 (Wed)   #11
Skip if i tested the voltage right it was about 26 volts when the flash was fired
Old 14th of July 2010 (Wed)   #12
SkipD
SkipD's Avatar
That voltage should be absolutely no problem if you directly connect the flash to the camera. Hopefully the voltage is high enough to make the circuitry in the Wein Safe Sync work properly. If you have any grief firing the flash, though, the first thing to try would be a conventional (connection only, no intermediate circuitry) hotshoe-to-PC adapter.
If you can return the Wein Safe Sync to the store for a refund and get a conventional adapter, you'd save a bundle of cash that you didn't need to spend.
Skip Douglas
Old 14th of July 2010 (Wed)   #13
auto-clicker
auto-clicker's Avatar
You should be fine i use it to trigger 600ws monohead, connected to a 7D. I've been using this since my EOS3 days.
auto-clicker is offline   Reply With Quote
Old 14th of July 2010 (Wed)   #14
yea i got the wein safe at the local camera shop just incase something went goofy with it, they said i could bring it back. so far it works just fine flash fires every time i press the shutter but we will see this weekend when i put it to some real use, still wont have it on the 50 yet I dont get to pick that up til the 21st
The wein safe as $60 and the Nikon one was $26 but I did notice that they had there store brand for only $12
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
My raw images work on my pc but not at work DonJuanMair RAW, Post Processing and Printing 3 6th of February 2010 (Sat) 13:59
Check out this work great work RichR Glamour & Nude Talk 1 2nd of December 2008 (Tue) 22:00
Not ANOTHER day of work... Bad Iron People 11 3rd of December 2005 (Sat) 09:23
My Break at Work... Yeah I bring a camera to work. cjm Urban Life & Travel 20 15th of September 2005 (Thu) 22:30
