Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 21st of July 2010 (Wed)   #1
pete crawford
Default Football Managers
Couple of pics I shot today. Any comments welcomed, I learn every time I shoot.
Thanks,
Pete
pete crawford is offline   Reply With Quote
Old 22nd of July 2010 (Thu)   #2
MJPhotos24
MJPhotos24's Avatar
Default Re: Football Managers
...exposure is off for the setting, not very interesting poses, and second one is bad photoshop.
Expose for the background, then adjust light for the people...
MJPhotos24 is online now   Reply With Quote
Old 22nd of July 2010 (Thu)   #3
pete crawford
On the photoshop issue, did I mess up taking the shadows out??
As far a s exposure, I'm lost! Ha Ha
Old 22nd of July 2010 (Thu)   #4
TeeJay
TeeJay's Avatar
Pardon me, but what's the link with "Football Managers"?
TJ
1DsMkIII | 1DMkIIN | 20D + grip | 70-200 f/2.8L IS | 24-70 f/2.8L | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea
TeeJay is offline   Reply With Quote
Old 22nd of July 2010 (Thu)   #5
pete crawford
They manage the footballs on Friday nights, LOL!!
Old 22nd of July 2010 (Thu)   #6
MJPhotos24
MJPhotos24's Avatar
They look like they're floating on the grass since it's so unnatural not to have shadows in harsh light...
As for exposure, find your background, expose for it (i.e. grass is green, not yellow), then put the person where you want them and adjust your light to fit. Right now your background is extremely hot...usually what I'll try to do is go to AV or TV mode and play around trying to find the starting point, go back to M and under exposure the background a little bit (-1/3 or so), then you put the person where you want them and adjust the light.
With something like this should go easy, when doing 30 people in a row exposure can change on you in a heart beat so have to re-adjust or live with the background being off a bit. Last night went from bright sun to black storm clouds so in a few photos the exposure is off, it's going to happen, but something like this (small group) should be able to adjust.
Note when NOT using lights/flash then you have to over exposure the background when shooting into the sun like that. It's what drives me nuts when I see people not use a fill and just over expose on head shots/portraits, makes no sense if you have a flash to use.
...and yes, those footballs need managing, you give one an inch and it'll take a mile.
Old 22nd of July 2010 (Thu)   #7
pete crawford
MJ, you give great instruction. I'll definately need to play with this. I understand the concept of the exposure on the background, I just need to try and grasp it!
Oh, I did think when I photoshopped the photo that it looked as if they were drug into the scene! I'll re edit!
Old 22nd of July 2010 (Thu)   #8
MJPhotos24
MJPhotos24's Avatar
...and here's an EXTREME example...exposed for the grass (which is over making it yellow-ish, but getting there), turned on the lights and had my assistant stand there. Took this shot and realized the lights were on full blast when they needed to be turned all the way down. Just shows you have to play around until getting it right...Casper the friendly ghost...
Once getting them right...perfect no...but "right"...actually on day two...most of day one was slightly off in some way or another with the non-stop changing lighting.
Old 25th of July 2010 (Sun)   #9
pete crawford
Hey Mike, Thanks! It was a little fight but I got my wife in the sun today. I did a quick practice. I didn't set up an umbrella, I just used an on camera flash!
The 1st pic is iso 100, f6.3, and 1/320, no flash.
The second is all the same except 1/2 power on the flash.
Old 25th of July 2010 (Sun)   #10
Fstop-Ian
Your second images looks like 2 images, one in studio and one of a field and then cut and pasted... and not done very well. Is this just one image? the main problem area is the feet.
First looks fine but could use a little less ambient as mentioned.
If you have support related questions regarding F-Stop Gear, please email ian@fstopgear.com or visit www.fstopgear.com
Fstop-Ian is offline   Reply With Quote
Old 25th of July 2010 (Sun)   #11
pete crawford
LOL, It is one picture but I photoshopped the shadows out! I kept the original and got rid of the phot above. It really does look like they were placed on a background!
Old 25th of July 2010 (Sun)   #12
pete crawford
This is the original. I shadowed the edges to cut down on some of the background lite.
Old 25th of July 2010 (Sun)   #13
asysin2leads
I'm kissing arse
asysin2leads's Avatar
The photo w/ the shadows gives the image depth, which the first one that was PS'd lacked.
asysin2leads is offline   Reply With Quote
Old 25th of July 2010 (Sun)   #14
pete crawford
I learnedthat the hard way!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Font Managers aram535 RAW, Post Processing and Printing 9 18th of April 2010 (Sun) 17:04
Plug-in managers Photo Gib RAW, Post Processing and Printing 0 22nd of October 2006 (Sun) 22:19
image file managers KCook RAW, Post Processing and Printing 18 6th of June 2003 (Fri) 16:35
