#1 |
I have a Canon 40D, Canon 580EX, and a Canon 430EX flash. I borrowed 3 Pocket Wizards from a friend. How do I connect the triggers to the flash, or can I? Am I missing something here. The connection I thought was for the flash is for a bracket mount, so says the manual. Thanks in advance. Stephen.
Stephen Shell Canon G12. |
| sponsored links |
#2 |
Stephen, we're going to need to know which pocket wizards it was that you borrowed before we can help you as there are different ones that connect in different ways.
#3 |
Sorry.....Pocket Wizard Plus II Transceivers. Thanks....Stephen.
| sponsored links |
#4 |
Flash Zebra has everything that you need. If you need help picking the right cable, just email Lon, the owner.
http://www.flashzebra.com/wizardcables/index.shtml I use this adapter. http://www.flashzebra.com/products/0126/index.shtml I removed the loose hotshoe that came with my umbrella bracket and replaced it with this. It has a threaded socket in the bottom that screws right in the bracket post. No need to worry if your flash has a sync port. Just slide it into this adapter and plug the cable into your trigger and fire away.
Dale Last edited by dedsen : 23rd of July 2010 (Fri) at 21:23. |
| Thread Tools | |
| Display Modes | |
| So, What have you LOST lately? | Jimmer411 | The POTN Lounge | 53 | 3rd of February 2009 (Tue) 18:29 |
| Please help im lost | ImShane | Canon G-series Digital Cameras | 3 | 8th of June 2007 (Fri) 23:49 |
| Lost Within | Dragos Jianu | People | 22 | 25th of January 2006 (Wed) 10:50 |
| Lost files - well maybe not lost | dewmuw | RAW, Post Processing and Printing | 0 | 1st of April 2005 (Fri) 04:35 |
| Help I am LOST! | Mark0159 | Canon EOS Digital Cameras | 13 | 16th of January 2004 (Fri) 09:26 |
