Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography
Reply
Thread Tools Display Modes
Old 29th of July 2010 (Thu)   #1
.Joel
Question What's a good film camera for college classes? Please help...
Hi everyone,
I'm a Graphic Design major in college and starting in the fall, I'll be taking a few film-photography courses. I've been shooting digital for years but never tried film. I have a Rebel XSi so I was thinking about getting a film SLR from Canon as well.
I just don't know what to get or what to look for... I want something that's fairly simple to use, takes good pictures (considering this will be for a grade), and hopefully affordable (not too much over $100, if possible).
I was looking at the Canon AE-1. What do you guys think? I could really use your help/suggestions.
Thanks a lot!! I appreciate it!!
Joel . 18. Florida
flickr
.Joel is offline   Reply With Quote
Old 29th of July 2010 (Thu)   #2
NeverFollow
Default Re: What's a good film camera for college classes? Please help...
from my experience.... Nikon seems to be the best for 35mm film cameras I also really like my Minolta SRT 202. The AE-1 isnt bad, I think since this is your first film class you will be spending much more time developing and enlarging than actually taking photos. So the camera isnt going to be as important as you think...... (you will understand what I mean when you start enlarging) .
KEH.com is a great store that sells used film equipment
also check out craigslist.
** The most important thing to look for when purchasing a used camera is that the light meter works. To verify that one works I would take your digital with you and meter the same object to see if the meter is in correct working order.**
NeverFollow is offline   Reply With Quote
Old 29th of July 2010 (Thu)   #3
.Joel
Thanks!! I'll definitely take a look into them. Any particular Nikon model you're fond of?
Any more recommendations/tips? =]
Joel . 18. Florida
flickr
Old 29th of July 2010 (Thu)   #4
matonanjin
Originally Posted by .Joel View Post
Hi everyone,
I just sold my AE-1 on fleabay and have regretted it from the second I listed it. It's a great camera. If you can come across an F-1 that is sort of comparable to the 1DMk series. Pro level durability and high frame rate. I put thousands of rolls of film through both of these.
Another thought is an old medium format camera. Mamiya or Bronica or Hasselblad. But you may not be able to find one of these for <$100.
matonanjin is offline   Reply With Quote
Old 29th of July 2010 (Thu)   #5
sandpiper
sandpiper's Avatar
The AE-1 is a great camera, I have one and also it's bigger brother the A-1. Both should be available for under $100. Do bear in mind though, that these are old cameras (over 25 years I would think) and may well need seals replacing (particularly the foam around the mirror assembly, which can start to crumble) also shutter speeds may be a bit off due to lubrication being needed. So check out any potential purchase very carefully and allow for the possible need for some servicing.
An alternative may be an EOS film body as that may take the lens(es) that you have with the Rebel, so that could save you some money, plus any lenses you may buy in the future could be compatible with both. The key is whether they are EF (any EOS body) or EF-S (certain crop digital bodies only). If you get an old (pre- EOS) body such as the AE-1, A-1, F-1 etc., then it will need FD mount lenses.
If you don't have any EF lenses though, the AE-1 will be a nice camera to use (if it has been properly maintained) and lenses won't be expensive on the used market, as most people want digital compatible gear, but again will be fairly ancient so test them carefully.
sandpiper is offline   Reply With Quote
Old 31st of July 2010 (Sat)   #6
dontcallmeash
used nikon fm2.
dontcallmeash is offline   Reply With Quote
Old 12th of August 2010 (Thu)   #7
brian00321
Check out KEH, browse the different brands and lenses, and see what you like. Either brand you pick, you can't go wrong.
http://www.keh.com/camera?s=1
brian00321 is offline   Reply With Quote
Old 14th of September 2010 (Tue)   #8
kfreels
kfreels's Avatar
In case you haven't done this yet....Get a Canon Eos Elan IIe from ebay for about $50-$75. Great camera, pro-sumer with the thumb-dialon the back just like the more expensive cameras. They made them into the late 90s so they aren't "that" old and any lenses you buy for it will work on your Rebel as well (with a 1.6 crop factor)
Canon 7D, T2i-gripped |Canon EF-S 15-85mm f/3.5-5.6 IS USM, EF-S 55-250 f4/5.6 IS, EF 50mm f1.8 | Σ 10-20 F4-5.6 EX DC HSM, 30mm f1.4 EX DC HSM, 17-70 f2.8-4 DC macro OS HSM, 150mm f2.8 APO Macro DG EX HSM, APO 70-200 f2.8 EX DG OS HSM |Σ EF-610 DG Super, Yongnuo YN-560| Yongnuo RF 603s|Marumi Super DHG ND4, ND8, CPL|Ravelli pro CF ball head tripod
kfreels is offline   Reply With Quote
Old 8th of February 2011 (Tue)   #9
MARTIN2011
CANON EOS A2E would be my choice-check it out.
MARTIN2011 is offline   Reply With Quote
Old 8th of February 2011 (Tue)   #10
tohara
Nikon Fm2
tohara is offline   Reply With Quote
Old 10th of February 2011 (Thu)   #11
MARTIN2011
CANON AE1,CANONA2,PENTAX K1000
Old 10th of February 2011 (Thu)   #12
airfrogusmc
Canon F-1...Its a tank and its all manual. Maybe the best camera Canon ever made.
airfrogusmc is offline   Reply With Quote
Old 10th of February 2011 (Thu)   #13
bbgeekchic
I have a Pentax and Canon EOS, both 35mm of course. Same thing...needed em since I am attending for my bachelor in digital photography.... actually only needed one but friends were willing to donate for edjumication lol
Life is nothing without the love of a friend
bbgeekchic is offline   Reply With Quote
Old 22nd of February 2011 (Tue)   #14
elevenbangbang
Oh man this thread makes me miss my AE-1 so much.
-Joshua Yabut, Wicker Photo LLC
elevenbangbang is offline   Reply With Quote
Old 26th of February 2011 (Sat)   #15
TheBrick3
TheBrick3's Avatar
If you can't use your Canon lenses on the Nikon, I wouldn't get one of those.
1D III 5D II 5D | 580 EX II x 2
17-40L | 35L | 100L | 70-200 II | 17-35 f/2.8-f/4
Website
TheBrick3 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
College photography classes? DerekRob General Photography Talk 38 26th of September 2008 (Fri) 00:09
what would be a good inexpensive film camera 2005GLI The POTN Lounge 19 31st of December 2006 (Sun) 08:52
what's a good Canon film camera? hmongstang The POTN Lounge 10 25th of January 2006 (Wed) 18:55
Good Film camera to supplement 20D the7ferret Canon EOS Digital Cameras 24 12th of April 2005 (Tue) 17:53
Good camera backpack for a college student? elbirth Canon EOS Digital Cameras 5 7th of November 2004 (Sun) 19:04
