Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Transportation
Reply
Thread Tools Display Modes
Old 10th of August 2005 (Wed)   #1
formula4speed
Default Can this be saved?
I took this shot at a car show last weekend and overall I really like the shot, but the tree in the corner and the very dark chair in the bottom are bothering me. I'm not really proficient with photo editing software, I have Paint Shop Pro 7 but I'm not really sure how people clone things out of pictures. Any PS gurus want to shed some light on this for me?
I'm taking pictures of everything, so go ahead and take this place away from me.
5DII, 16-35mm f/2.8L II, ZE 28mm f/2, 35mm f/1.4L, ZE 50mm f/1.4, 100mm f/2.8L IS, 580 EX
formula4speed is offline   Reply With Quote
Old 10th of August 2005 (Wed)   #2
Ballen Photo
Moderator
Ballen Photo's Avatar
Default Re: Can this be saved?
The quick fix for the tree at the top would be to just crop the whole top of the photo just to the point where you loose the tree, and turning the shot into a sort of "Panoramic". I dont use PSP 7, but I think there are a couple of folks here that do (and quite well if memory serves), so hopefully one of them will show up here.
-Bruce
The Captain and crew finally got their stuff together, now if we can only remember where we left it.
Ballen Photo is offline   Reply With Quote
Old 10th of August 2005 (Wed)   #3
Sathi
Sathi's Avatar
I would leave the tree..it doesn't seem too bad and probably woudln't be worth the trouble. The chair should be cloned out. Couldn't tell you how to do it in paint shop though, but I am sure it must have a clone tool?
20d / Tamron 28-75 2.8 / Canon 10-22 / Canon 100mm macro
Sathi is offline   Reply With Quote
Old 10th of August 2005 (Wed)   #4
formula4speed
I didn't want to crop the tree as I want a print of this and was hoping to keep the correct ratio. As for the clone tool in PSP I can't find it but as I said I'm not proficient with it, I basically use it just to resize my photos and add USM occasionally.
Old 10th of August 2005 (Wed)   #5
PhotosGuy
Moderator
PhotosGuy's Avatar
It's your pic, but it would be a better with every bit of sky cropped out. Scroll it up on your screen & you'll see what I mean. Besides, the "correct ratio" is whatever you decide it should be, not the size of the box the paper comes in.
You'll get a better answer re PSP if you take the ? to the "Post Processing" area. Good luck!
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 10th of August 2005 (Wed)   #6
Ballen Photo
Moderator
You know? That DOES look even better than my idea of just below the tree.
-Bruce
Old 10th of August 2005 (Wed)   #7
formula4speed
You may have a point about cropping out the entire sky, I'll print one of each...photo paper is cheap enough.
Old 10th of August 2005 (Wed)   #8
Vetteography
Vetteography's Avatar
Ooops... nevermind.
David "Preacher" Slocum
My (Non-photo) Blog
My Model Mayhem
My Flickr
Vetteography is offline   Reply With Quote
Old 10th of August 2005 (Wed)   #9
formula4speed
the red was actually put there by me, i thought it looked better like that for some reason
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
saved Courierman Macro 4 18th of April 2007 (Wed) 14:05
Can this be Saved??? cntry RAW, Post Processing and Printing 8 16th of November 2006 (Thu) 11:33
Can this be saved? carriel_miller People 25 2nd of February 2006 (Thu) 21:03
Can this be saved? mbellot General Photography Talk 13 4th of August 2005 (Thu) 15:04
I wonder if he saved it!!? RTMiller Canon EOS Digital Cameras 14 9th of June 2005 (Thu) 10:48
