Reply
Thread Tools Display Modes
Old 25th of March 2003 (Tue)   #1
lenser
Default Telephoto lense
Hi all. I have a telephoto lense from a Canon Rebel 2000 EOS (35 mm film SLR). It is the Canon Zoom Lense EF 75-300mm, 1:4-5.6 III, 58mm. Is it possible to use this lense with the G3 with the Canon Conversion Lens adapter, LA-DC58B? Or ... to use it with the Lensmate adapters (which I'd have yet to purchase). And then... if it could be used with the Lensmate, what is the size to get (the 58mm, right?) It is a great lense and cost $250 and works great with the Rebel 2000. It would be great to know that this could be possible. Or do I have to go out and buy the lenses that Canon supplies with their Conversion Adapter? Did Canon make all this compatible?
lenser is offline   Reply With Quote
Old 26th of March 2003 (Wed)   #2
BruceW
Default Re: Telephoto lense
lenser,
Sorry to disappoint you but your lenses are not suitable for the G3. They are only of use on a Canon DSLR, such as the D10, D30, D60, etc.
With the G3, there is no option to take the current lens off the camera and replace it with another lens.
What the G3 does allow is to place either a Teleconverter or Wideconverter on the front of the existing lens. The adapter (Canon or Lensmate or other brand) is simply a means of attaching the Teleconverter or Wideconverter, and is just a barrel around the existing lens, offering a screw thread for attaching the converters, or for that matter, threaded filters.
There is already a short protection barrel around the lens, but it does not have the thread on the end. It is a bayonet fit to the camera. When the camera is turned on, the lens extends beyond this protection. The optional adapter is long enough to protect the fully extended lens, and has a thread on the end.
There are non Canon Teleconverters and and non Canon Wideconverters available for the G3, which tend to have different characteristics to the Canon. Typically, a Teleconvertor will range between x1.5 and x2. I guess a Wideconverter will range between x0.5 and 0.75, but I am only guessing.
Regards
Bruce
BruceW is offline   Reply With Quote
Old 28th of March 2003 (Fri)   #3
lenser
Ok. Thanks. Does that mean that lenses from any 35 mm film SLR's are not interchangeable with the G3 at all ... you must use the teleconverter and buy the special wide-angle or telephoto lenses designed for the G3?
Old 28th of March 2003 (Fri)   #4
zakabog
The only lenses you can use on a powershot G3 are threaded, so if you have a threaded 58mm lens you can use that (you need a lens adapter though.) So you can't use any of the Canon EF lenses.
zakabog is offline   Reply With Quote
Old 30th of March 2003 (Sun)   #5
lenser
Ok. Thanks!
Old 14th of December 2009 (Mon)   #6
Azoutdrman
Yes, as that is exactly what Im using by god! Works great so why not save big money! To the point if I can find a huge monster cheap.It will be mine for shooting the man in the moon hows that for cheesy! To wild animals and hey women! As some you should stay far away from! IF smart its not the teeth that get you! Ya you know it by god. Randy
Azoutdrman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Telephoto lense, anyone tried it? mvermoot Canon G-series Digital Cameras 4 16th of December 2009 (Wed) 00:48
which telephoto lense for me woodentom Canon EF and EF-S Lenses 8 14th of June 2007 (Thu) 10:41
telephoto lense aryashahin Canon EF and EF-S Lenses 8 27th of September 2005 (Tue) 08:09
Telephoto lense for A-75 A.Seven.Five Small Compact Digitals by Canon 1 20th of May 2005 (Fri) 00:54
Telephoto Lense Chardyboy Canon G-series Digital Cameras 1 14th of March 2003 (Fri) 00:43
