Thread started 18 Aug 2010 (Wednesday) 08:32
Prev/next
How do I securely hang a gallery wrap?
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
North Carolina
Aug 18, 2010 08:32 |  #1
In commercial environments, matted/framed prints are hung with a secure locking mount system to prevent theft and also keep the piece from falling off the wall and hitting somebody.
I need a way to securely hang (unframed) gallery wraps on a wall. I've googled it to death and have found nothing. If you know of a method, I would appreciate the help.
Website (external link) |
Mike-DT6
Mike-DT6's Avatar
The Jurassic Coast, Dorset, England.
Aug 18, 2010 09:22 |  #2
This might provide a couple of ideas:
http://www.ehow.com ...s-wall-prevent-theft.htmlexternal link
Mike
Gear list
Gaaaaa! DOH!! Oops!
North Carolina
Aug 19, 2010 07:30 as a reply to Mike-DT6's post |  #3
Thanks, Mike. I appreciate the info. I spent at least 2 full hours googling and could not find anything. This gives me a start.
PhotosGuy
Moderator
PhotosGuy's Avatar
Joined Feb 2004
Middle of Michigan
Aug 19, 2010 08:25 |  #4
IMO, make sure that they are insured & let them steal all they want! After all, a "sale" is a sale! :D
New Image Size Limits: Image must not exceed 1280 pixels on any side.
Gaaaaa! DOH!! Oops!
North Carolina
Aug 19, 2010 11:06 |  #5
PhotosGuy wrote in post #10749538external link
LOL! An easy sale, too - (other than the paperwork and time it takes to get a check from the ins. company ;) )
Unfortunately, that "easy sale option" is not available. They're hanging in a commercial environment and the customer wants to be sure that their customers don't (a) walk out with one, and (b) don't get beaned on the head with one. :)
Wilt
Wilt's Avatar
Belmont, CA
Aug 20, 2010 12:54 |  #6
Simple...as shown in the photo.
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/Canvashanging.jpg
The brown block is afixed to the wall with nail or screws, the black metal or plastic L bracket is afixed to the brown block. The blue metal or plastic L bracket is afixed to the canvas frame. You merely hook the L brackets over each other to provide secure attachment which 'locks' the canvas on the wall.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
Gaaaaa! DOH!! Oops!
North Carolina
Aug 20, 2010 22:43 as a reply to Wilt's post |  #7
Thanks, Wilt. I appreciate that.
It actually looks like a good system for the home. Very simple and easy to hang.
Unfortunately, I don't think it would work in a commercial environment.
The smallest problem is that somebody may bump the piece from the bottom upward which would bring it up and over that hook.
But the largest problem is there is no theft-deterrent. It's hard to comprehend, but even in a busy waiting room/area full of people, there are scuzzbags who will lift a piece of artwork off a wall and calmly walk out the door with it.
Wilt
Wilt's Avatar
Belmont, CA
Aug 20, 2010 23:54 |  #8
CannedHeat wrote in post #10759997external link
Short of glueing it to the wall, or screwing it on with an odd head (Torx is one example) to prevent opportunistic theft, I don't think you're going to find something. I missed your OP comment about theft, and I did not expect an issue with people bumping into the piece.
Wilt
Wilt's Avatar
Belmont, CA
Aug 21, 2010 00:16 |  #9
I just came up with the thought that the idea in my prior drawing will work to foil thieves simply by addition of two screws immediately above the canvas frame which serve to prevent the canvas from being lifted up and released from the opposing L brackets. Yes if they had a screwdriver, they could remove the screws, but one could simply drive the square socket heads used for securing deck planking to make it somewhat more difficult (to have the right driver type and size on hand) especially if they are above the eye level of the typical person and therefore not immediately visible.
Gaaaaa! DOH!! Oops!
North Carolina
Aug 21, 2010 21:28 |  #10
Wilt wrote in post #10760307 (external link)
Wilt wrote in post #10760387 (external link)
Interesting. You've got a good brain. Must be an engineer. ;)
Since the OP, I've found some commercially available locking systems, but you've generated some ideas I think may be better.
I've modified things a little.
Using the "S" bracket eliminates the need to mount a block to the wall and a bracket to the block. The "S" bracket is affixed to the wall with a screw (red) and anchor if needed. A little easier.
For security, the "L" and "S" brackets have opposing holes. After hanging your frame, rotate the bottom out, squeeze your hands up and under and run a piece of wire/cable (gray) thru the holes and then secure with some sort of crimping tool. The advantage here is the security is hidden. The thief sees no security, tries to lift the frame, is stopped by the wire which makes a noise, the on-site security guard beans him, drags him to the curb and the problem is dispensed with. ;)
Jokes aside, there's one other advantage of your brackets I like: leveling. No hooks or hangers or hanging picture wires. You mount with two "S" brackets - one on either side of the frame. You put up a "S" bracket, grab your level, put up a second one, and everything is level. Easy and quick.
Appreciate your help.
Heath
Heath's Avatar
Joined Sep 2009
NYC, NY
Aug 21, 2010 22:04 |  #11
I would add a block at the bottom on the inside that would secure the canvas wrap. This way the photo could not be bumped off the top hangers.
I believe it will be very difficult to get the wires attached as you have shown on the top.
Using the lower block, you could either screw in from the bottom of the frame up into the block to secure the piece, or you could put a block on top as someone else already mentioned.
Edit: If you never need to be able to remove the canvas wraps from the walls, I have an idea for that. Basically a z clip configuration that snaps together.
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blogexternal link-Twitterexternal link-Zenfolioexternal link-500pxexternal link-Pinterestexternal link-Gear List
8,673 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00496 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is wshooter
483 guests, 363 members online
